[OpenFOAM.org] Moving OF-bin from fedora over to ubuntu 19.10 |
December 10, 2019, 17:14 |
Jon Elvar Wallevik
Rep Power: 20 |
I usually compile openfoam on a fedora pc and thereafter just tarball the whole thing and put it (i.e. the OF) on the computer it needs to be on. Recently, I have set up ubuntu 19.10 on one of the pc at work. However, moving binaries between fedora and ubuntu requires only few mods and the following is what I have done,...
(1) sudo ln -s /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi.so.40.10.3 /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi.so.20 (2) ...and to make paraview work as before, then... sudo ln -s /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi_cxx.so.40.10.0 /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi_cxx.so.20 (3) Finally in .bash_alias, then I but... alias of6='export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu/openmpi/lib/:$LD_LIBRARY_PATH && source $HOME/OpenFOAM/OpenFOAM-6/etc/bashrc && PS1="[of6][\W] " ' This has worked on OpenFOAM 6, as well as on OpenFOAM 2.3.1 (haven't tested this on other versions).NB! This might also work if you are working with opensuse/ubuntu as well. Hope this is of some help cheers |
December 27, 2019, 17:22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: But are you now able to compile new custom code with OpenFOAM on the Ubuntu machine?
Because that is usually the only problem that can happen in this kind of installation transfer between two different Linux Distributions and/or versions. Another detail to keep in mind is that the symbolic links you are creating should be for compatible MPI libraries. Beyond this, if you're willing to look into it, there is something named AppImage https://appimage.org/ - which allows compiling an application in one distribution and deploy it in any other. I have been wanting to look into this myself, but haven't found the time to do it, but for OpenFOAM it's less straight forward as well, given that OpenFOAM does not provide only a single executable...
December 30, 2019, 17:33 |
#3 | |
Jon Elvar Wallevik
Rep Power: 20 |
Hi and sorry for the late reply Yes, new solvers can be compiled. The funny thing is, before I made the link to the mpilibs, nothing worked, not even what had already been compiled. What I got for any app I tried was... [2.3.1][~] foamToVTK -help foamToVTK: error while loading shared libraries: libmpi.so.20: cannot open shared object file: No such file or directory I guessing many of the classes either has-a or is-a base-class that includes mpi stuff (?) Cheers J. P.S. I will look at the stuff you recommended above, thanks for the info. |
January 20, 2020, 10:05 |
moving Fedora 29 bins over to fresh install of Fedora 31
Jon Elvar Wallevik
Rep Power: 20 |
Dear fedora folks:
...same problem when moving bins from f29 over to f31 (i.e. with fresh install of f31). Do... sudo ln -s /usr/lib64/openmpi/lib/libmpi.so.40.20.2 /usr/lib64/openmpi/lib/libmpi.so.20 sudo ln -s /usr/lib64/openmpi/lib/libmpi_cxx.so.40.20.1 /usr/lib64/openmpi/lib/libmpi_cxx.so.20 ...and with .bashrc (at least this works for me)... alias of23x='export PATH=/usr/lib64/openmpi/bin/:$PATH && export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH && source $HOME/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc && PS1="[2.3.x][\W] " ' Hope this helps cheers J. New info: I was bit too fast here this works for OF2.3.1, but not for higher versions. Fedora 31 is apparently little bit more trouble than ubuntu 19.10. |
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 20:55 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 24, 2012 00:41 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 07:54 |
Moving mesh in Fluent | fivos | FLUENT | 0 | April 2, 2010 10:45 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 06:32 |
