[OpenFOAM.com] Error compiling paraview using MESA
Like Tree2Likes
  • 2 Post By zordiack
Old   October 30, 2019, 13:11
Default Error compiling paraview using MESA
xuegy is on a distinguished road
Hello all,
I'm trying to compile OpenFOAM v1906 in a CentOS 8 virtual machine. The OpenFOAM it self goes well(even easier than CentOS 7 thanks to the latest toolchain). However I can not compile paraview with MESA.
The command I used:
./makeParaView -python -mpi -mesa -mesa-include /usr/include/GL -mesa-lib /usr/lib64/libOSMesa.so -qt > log.makePV 2>&1
Here's the information
Python information:
    executable     : /usr/bin/python
    version        : 3.6m
    include path   : /usr/include/python3.6m
    library        : /lib64/libpython3.6m.so.1.0
Using qmake=/usr/bin/qmake-qt5
ParaView_SOURCE_DIR=/home/gux215/OpenFOAM/ThirdParty-v1906/ParaView-v5.6.0
ParaView_BUILD_DIR=/home/gux215/OpenFOAM/ThirdParty-v1906/build/linux64Gcc/ParaView-5.6.0
ParaView_DIR=/home/gux215/OpenFOAM/ThirdParty-v1906/platforms/linux64Gcc/ParaView-5.6.0
Build stages selected
    -patch    true
    -config   true
    -make     true
    -install  true
Features selected
    mesa      true
    mpi       true
    python    true
    qt        true
Version information
    paraview  5.6.0
    major     5.6
    build     Release
    qt        5.11.1
no patch found for paraview-5.6.0
Using cmake=/usr/bin/cmake
removing old build directory
Configuring paraview-5.6.0 (major version: 5.6)
    MPI    support : true
    Python support : true
    MESA   support : true
    GL2  rendering : true
    QT dev support : true
    Source         : /home/gux215/OpenFOAM/ThirdParty-v1906/ParaView-v5.6.0
    Build          : /home/gux215/OpenFOAM/ThirdParty-v1906/build/linux64Gcc/ParaView-5.6.0
    Target         : /home/gux215/OpenFOAM/ThirdParty-v1906/platforms/linux64Gcc/ParaView-5.6.0
    cmake          : /usr/bin/cmake
    Build suffix   : none
/usr/bin/cmake -DCMAKE_INSTALL_PREFIX=/home/gux215/OpenFOAM/ThirdParty-v1906/platforms/linux64Gcc/ParaView-5.6.0 -DBUILD_SHARED_LIBS=ON -DBUILD_TESTING=OFF -DPARAVIEW_INSTALL_DEVELOPMENT_FILES=ON -DVTK_USE_X=OFF -DPARAVIEW_USE_MPI=ON -DPARAVIEW_ENABLE_PYTHON=ON -DPYTHON_INCLUDE_DIRS=/usr/include/python3.6m -DPYTHON_LIBRARY=/lib64/libpython3.6m.so.1.0 -DVTK_OPENGL_HAS_OSMESA=ON -DOSMESA_INCLUDE_DIR=/usr/include/GL -DOSMESA_LIBRARY=/usr/lib64/libOSMesa.so -DVTK_RENDERING_BACKEND=OpenGL2 -DPARAVIEW_BUILD_QT_GUI=ON -DPARAVIEW_QT_VERSION=5 -DQt5_DIR=/usr/lib64/cmake/Qt5 -DCMAKE_BUILD_TYPE=Release /home/gux215/OpenFOAM/ThirdParty-v1906/ParaView-v5.6.0
And the first error is
/bin/sh: line 0: cd: /home/gux215/OpenFOAM/ThirdParty-v1906/build/linux64Gcc/ParaView-5.6.0/Plugins/MOOSETools/doc: No such file or directory
make[2]: *** [Plugins/MOOSETools/CMakeFiles/MooseXfemClip.dir/build.make:78: Plugins/MOOSETools/doc/MooseXfemClip.qch] Error 1
make[1]: *** [CMakeFiles/Makefile2:55891: Plugins/MOOSETools/CMakeFiles/MooseXfemClip.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
I tried to google this error message but no result.
Anyone knows how to fix it?
Thanks.
xuegy is offline   Reply With Quote
Old   December 3, 2019, 09:49
Pekka Pasanen
zordiack is on a distinguished road
Hi, I recently stumbled on the same compilation error myself on CentOS 7. I think this is some kind of a bug in either ParaView, CMake or CentOS or some combination of those, I don't really know at this point.
However, as you can see CMake is complaining about missing /doc folders under specific ParaView plugin directories. For me there were two plugins that refused to compile, MOOSETools and SurfaceLIC.
As a quick and dirty fix that worked (at least for me) you can copy the /doc folders from source dir to build dir and it will resume compiling, like this:
 cp -R ParaView-v5.6.3/Plugins/SurfaceLIC/doc/ build/linux64Gcc/ParaView-v5.6.3/Plugins/SurfaceLIC/
 cp -R ParaView-v5.6.3/Plugins/MOOSETools/doc/ build/linux64Gcc/ParaView-v5.6.3/Plugins/MOOSETools/
You need to do this in ThirdParty root directory and you need to modify the paths according to your setup, but I hope you get the idea.
BR, zordiack
Yuusha and HPE like this.
zordiack is offline   Reply With Quote
Old   October 31, 2022, 08:13
Default Same on AlmaLinux 9 (RHEL 9) with OpenFOAM v10 and ParaView-5.6.3
Klaus
klausb will become famous soon enough
The problem still exists on AlmaLinux 9 (RHEL 9) with OpenFOAM v10 and ParaView-5.6.3:
Fix:
1: After starting the installation with ./makeParaView wait until ParaView is downloaded
2: Copy the contents of the directory ThirdParty-10/ParaView-5.6.3/Plugins/MOOSETools to the corresponding directory in the build directory i.e. ThirdParty-10/build/linux64Gcc/ParaView-5.6.3/Plugins/MOOSETools
3: Do the same with the contents of the ParaView-5.6.3/Plugins/SurfaceLIC directory to the corresponding directory
Even so, the error refers to the missing /doc sub-directory, it`s necessary to copy the entire content of the MOOSETools and SurfaceLIC directories.
You can apply this fix while the ParaView installation runs as it takes a while to reach the point that causes the issue.
klausb is offline   Reply With Quote
Old   November 14, 2022, 06:06
Retired Super Moderator
Bruno Santos
Quick answer: I'm somewhat late to answering this, but the somewhat simpler fix is to run the following command:
sed  -i -e 's=\(arg_TABLE_OF_CONTENTS}")\)=\1\n  file(MAKE_DIRECTORY  "${arg_DESTINATION_DIRECTORY}")='  ParaView-5.6.3/CMake/ParaViewMacros.cmake
  • Note: This will only work if the ParaView source code package was already unpacked.
If your build already failed, then run the makeParaView command with the following additional options:
-make -install
so that it will continue from where it left off, instead of starting from zero.
Old   March 26, 2023, 11:54
amin.z's Avatar
Amin
amin.z is on a distinguished road
-make -install
You're a life saver Bruno!
Thanks for your both hints
amin.z is offline   Reply With Quote
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) dslbkxd OpenFOAM Installation 1 February 3, 2018 01:56
Installing OpenFoam on windows 7-64 Dadou OpenFOAM Installation 10 February 11, 2014 17:20
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 03:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
