[OpenFOAM.com] Permanent sourcing of OpenFOAM 19.06
Like Tree1Likes
  • 1 Post By Rasmusiwersen
Old   October 14, 2019, 11:44
Default Permanent sourcing of OpenFOAM 19.06
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
HI all,
I have just successfully installed OpenFOAM 19.06 (finally) as well as building paraview successfully.
One curious thing keeps happening. It seems as if my souring of OpenFOAM v19.06 is only temporary. I have previously installed and used OpenFOAM verision 7 (openfoam.org). If i open a terminal from my desktop and change directory to $FOAM_TUTORIALS i automatically move to /opt/openfoam7/tutorials where i installed OpenFOAM 7.
Sourcing OpenFOAM to source ~/OpenFOAM/OpenFOAM-v1906/etc/bashrc makes me able to change directory through $FOAM_TUTORIALS to the $HOME directory where I have installed OpenFOAM v19.06. If i then close the terminal, and open it again, the source leads me back to tutorials from OpenFOAM version 7.. Is there a way that i can permanently run OpenFOAM version 19.06?
Thank you!
Rasmusiwersen is offline   Reply With Quote
Old   October 15, 2019, 03:14
Default Solved!
Rasmus Iwersen
Hi all,
So I figured out the problem, pretty stupid one at that...
As i did before, sourcing the OpenFOAM version 19.06
source $HOME/OpenFOAM/OpenFOAM-v1906/etc/bashrc
i just forgot to run the following command:
source $HOME/.bashrc
The cd $FOAM_TUTORIALS now takes me to the correct directory.
/Rasmus
gcengineer likes this.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
