[OpenFOAM.org] Install OpenFOAM 2.3.x on Mac OS
Like Tree1Likes
  • 1 Post By HPE
Old   September 17, 2019, 13:08
Exclamation Install OpenFOAM 2.3.x on Mac OS
Guido
gxuk is on a distinguished road
Dear Forum,
I will start using OpenFOAM for my master thesis project regarding simulation of wind turbine.
I am having some difficulties in finding an optimal solution for installing OpenFOAM 2.3.x on Mac OS Mojave 10.14.6.
  1. Do you suggest me to switch absolutely to Linux or is it ok to work on Mac OS?
  2. Even if suggested, is there a way to avoid using docker and compile directly on Mac OS OpenFOAM 2.3.x ?
Thanks
Best Regards,
Guido
gxuk is offline   Reply With Quote
Old   September 22, 2019, 09:23
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
I kindly suggest you to forget about OF 2.3.x, which is not being maintained anymore since the new versions are available.
Either OpenFOAM 1906 or OpenFOAM v7 should be used.
The full maintenance support is for Linux, I would always use Linux instead of Unix or Windows. But the new versions afaik are compatible with Mac and Windows.
gcengineer likes this.
HPE is offline   Reply With Quote
Old   September 22, 2019, 12:11
Guido
Thanks for your reply HPE. As you can imagine I am very beginner.
At the moment I should work on a previous code written in OpenFOAM 2.3.x and I have been told that the next versions cannot compile the very same code.
Question 1 : do you suggest a beginner to migrate to the last version or do you think is better to just compile OpenFOAM 2.3.x ?
Question 2 : is there a docker container of OpenFOAM 2.3.x ?
Old   September 22, 2019, 14:25
HPE
HPE's Avatar
"the next versions cannot compile the very same code."
I rephrase their remark as that they are not able to refactor their code, so that it can be compiled with the new version, because they have no clue in coding simple tweaks (since OpenFOAM always take care of backward compatibility for years but not a decade), but they cannot admit it.
"Question 1 : do you suggest a beginner to migrate to the last version or do you think is better to just compile OpenFOAM 2.3.x ?"
IMHO, you must forget OF 2.3 for your long-term good. Attending a programming course, or a self thought course will enable you to perform the code tweaks you need for the code compilation.
"Question 2 : is there a docker container of OpenFOAM 2.3.x ?"
I don't know I am afraid.
Old   September 26, 2019, 06:44
Glenn Carlson, PE, PhD (ret)
gcengineer is on a distinguished road
Especially for a beginner, I suggest using the latest version of OF -- OF7 or OFv1906 -- in Ubuntu 18.04. OF in Ubuntu is well tested. Is there a utility or feature for OF 2.3 that you need but doesn't exist for OF7 or OFv1906? If not, use the latest version.
I run OF7 and OFv1906 with Paraview 5.6 in Ubuntu 18.04. A Qt version mismatch error that I and others have seen when building Paraview 5.6 is solved: Qt5, OpenFOAM-7 and -v1906, and Ubuntu 18.04
Good luck.
gcengineer is offline   Reply With Quote
docker, mac os, openfoam 2.3.x
[OpenFOAM.org] Install OpenFOAM without admin right OpenFoamlove OpenFOAM Installation 1 December 31, 2017 12:45
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] OpenFOAM 2.3.x for Mac at GitHub ajmas OpenFOAM Installation 2 April 20, 2015 17:23
Any Parallel install procedure on Mac OS JinZhiyi SU2 Installation 2 March 11, 2014 02:12
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
