[OpenFOAM.org] Error message is not showing in the terminal |
FaRa
Rep Power: 7 ![]() |
Hello everyone. I am using OpenFoam v-2.4.0 on windows 10 for linux subsystem. When I started a simulation to check whether everything went well, it stopped without showing any error report. The simulation should stop showing the message below which I got using OpenFoam in ubuntu in virtualbox.
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? main_qsub.sh: line 3: 2722 Floating point exception(core dumped) interThermalPhaseChangeFoam > interThermal_log.txt |
#2 | |
Parth
Rep Power: 5 ![]() |
Did you find the solution? |
#3 | |
Amirhossein Taran
Rep Power: 9 ![]() |
the best way is to check all your entries including mesh and try to check them one by one. If you give me more details on a case that you try to simulate, maybe ill be able to help. Amirhossein. |
error text, openfoam, windows 10 |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
[PyFoam] unknown or ambiguous terminal type x11 | Tobi | OpenFOAM Community Contributions | 6 | August 13, 2020 11:09 |
Showing fluent residuals on terminal | Eman. | FLUENT | 0 | July 16, 2017 18:08 |
[PyFoam] doesn't plot residuals | immortality | OpenFOAM Community Contributions | 4 | June 28, 2015 10:13 |
[swak4Foam] on run time object | hchen | OpenFOAM Community Contributions | 6 | December 4, 2014 15:39 |
