[OpenFOAM.org] Installation on Ubuntu Subsytem - Failed to fetch
Like Tree1Likes
  • 1 Post By engingreed
Old   June 28, 2019, 12:52
Unhappy Installation on Ubuntu Subsytem - Failed to fetch
Semih
engingreed is on a distinguished road
Hello everyone,
Manytimes, I installed OpenFoam on my home computer and office pc. However, nowadays I can not re-install OpenFoam on my home pc. I tried everything and look at every forum. But I could not solve the problem. While I tried to install OF, I follow the instructures. But after, sudo apt-get update; I write the sudo apt-get -y install openfoam6 and I get this:
E: Failed to fetch https://netix.dl.sourceforge.net/pro...0620_amd64.deb  Could not handshake: The TLS connection was non-properly terminated. [IP: 87.121.121.2 443]
E: Failed to fetch https://netix.dl.sourceforge.net/pro...0221_amd64.deb  Could not handshake: The TLS connection was non-properly terminated. [IP: 87.121.121.2 443]E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
In upper lines I saw this:
Need to get 153 MB/318 MB of archives.
After this operation, 1929 MB of additional disk space will be used.
Get:3 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libgstreamer1.0-0 amd64 1.14.4-1~ubuntu18.04.1 [862 kB]Err:1 https://netix.dl.sourceforge.net/pro...am/foam/ubuntu bionic/main amd64 openfoam6 amd64 20190620
Err:2 https://netix.dl.sourceforge.net/pro...am/foam/ubuntu bionic/main amd64 paraviewopenfoam56 amd64 0-20190221
Get:4 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libgstreamer-plugins-base1.0-0 amd64 1.14.4-1ubuntu1.1~ubuntu18.04.1 [684 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-libc-dev amd64 4.15.0-54.58 [1004 kB]
Get:6 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 gstreamer1.0-plugins-base amd64 1.14.4-1ubuntu1.1~ubuntu18.04.1 [585 kB]
Fetched 3136 kB in 12s (257 kB/s)
Last edited by wyldckat; July 9, 2019 at 19:55. Reason: Added [CODE][/CODE] markers
engingreed is offline   Reply With Quote
Old   July 9, 2019, 19:56
Retired Super Moderator
Bruno Santos
Quick answer: After a quick search for:
ubuntu wsl Could not handshake: The TLS connection was non-properly terminated.
it seems that it's due to a proxy error for HTTPS handling. Brief instructions on how to fix that are provided here: https://askubuntu.com/a/1014978
Old   August 3, 2019, 11:45
Semih
OK the problem was occured becaouse of my antivir-software. It solved now. Thank you.!!
wyldckat likes this.
Old   October 7, 2020, 15:06
VVN
Vijay
VVN is on a distinguished road
I am getting the same error. Do I need to restart the process of installation from beginning or do we have any other solution? Please help
VVN is offline   Reply With Quote
Old   October 8, 2020, 08:58
Petros Ampatzidis
petros is on a distinguished road
The error related to the initial post was due to the fact that an antivirus tool was blocking the installation.
If this is not the case for you, clean everything and restart the installation following step by step the respective guides. See here.
Best,
Petros
petros is offline   Reply With Quote
Old   October 8, 2020, 14:26
VVN
Vijay
Thank you for reply. The error was due to bad network. But I restarted the process by entering:
sudo apt-get update
sudo apt-get -y install openfoam8
and it worked
Old   June 17, 2021, 15:40
Manaf Muhammed
manafaero is on a distinguished road
First Uninstall the OpenFOAM
https://askubuntu.com/questions/1246...g-from-openfoa
sudo apt-get clean
Then try Using
1. sudo apt-get update
2. sudo apt-get upgrade
Then try to reinstall Openfoam
manafaero is offline   Reply With Quote
err, openfoam6, windows 10
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
