[OpenFOAM.com] Installing v1812 on Windows 10
Like Tree1Likes
  • 1 Post By ellen13
Old   June 13, 2019, 17:58
Default Installing v1812 on Windows 10
Ellen
ellen13 is on a distinguished road
Good afternoon,
I am working on installing OpenFOAM v1812 for Windows 10. I have followed the instructions in the readme file linked from this page, but am hitting the following error when I click the "OF_Create_Env" shortcut:
Error checking TLS connection: Host is not running
Starting "default"...
(default) Check network to re-create if needed...
(default) Waiting for an IP...
Too many retries waiting for SSH to be available.  Last error: Maximum number of retries (60) exceeded
Error checking TLS connection: ssh command error:
command : ip addr show
err     : exit status 255
output  :
/root/../c/Users/ellenpt1:/root/../home/ofuser/workingDir
output  :
exit status 255
When I manually open Docker Quickstart terminal, it does appear to have my default machine running:
ellenpt1@EWRE155PC5 MINGW64 /c/Program Files/Docker Toolbox
$ docker-machine status default
Running
$ docker-machine ip default
192.168.99.100
And when I open VirtualBox manually, the default machine shows up and is currently powered off.
A few additional notes that may be helpful:
1 - I have successfully installed v1812 on my personal laptop (also a Windows 10 machine) by following the readme instructions without hitting any issues.
2 - I have tried uninstalling OpenFOAM, Docker, VirtualBox, and git and started the install from scratch a few times, but I always get stuck at the same place.
3 - I am on a computer shared among my lab group at my university.
Please let me know if I can provide any additional information. Thank you in advance for your help.
Best,
Ellen
ellen13 is offline   Reply With Quote
Old   June 18, 2019, 17:17
Default Workaround: Ubuntu Bash
Ellen
I ended up successfully installing OpenFOAM v1812 using Ubuntu Bash instead of the Windows Installer using Docker. I'm still unsure what was wrong with my Docker/OpenFOAM install from my previous post, but this alternate solution is working well.
Best,
Ellen
wyldckat likes this.
[Other] Installing OpenFoam on Windows 7, 32 bit Operating System Khan82 OpenFOAM Installation 5 April 22, 2017 08:43
Installing Ansys License on mac (Parallels - Windows 7) cfluid ANSYS 0 February 14, 2014 20:41
correction of Grub after installing Windows XP and 8 immortality Lounge 20 January 5, 2014 18:41
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Help Installing Gambit on Windows XP Dave FLUENT 0 May 23, 2002 18:08
