June 12, 2019, 16:22 |
Foam-Extend with existing OpenFoam
Sujay
Rep Power: 8 |
New user here, not sure of correct terminology.
I have been using openfoam for some weeks. Now I need to install foam extend. I'm trying to solve some issues with the installation. 1. Is it possible/ recomended to install foam extend on a system where openfoam is already installed? 2. If yes, when we execute a command, for example pisoFoam, how do we know if the command is executed by openfoam or foam extend? |
June 24, 2019, 08:49 |
Andreas P.
Rep Power: 9 |
Everytime you start the console, you have to source the bashrc file of the openFOAM/foam-extend version you want to use by typing
source /*openFoamInstallationFolder*/etc/bashrc Only then you are able to use the compiled applications. You should always just source a bashrc file of one version at a time in order to ensure you are using only applications from this specific version. |
June 24, 2019, 17:04 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick note: You can also use aliases, namely a command that allows you to activate a specific environment, as instructed here: https://openfoamwiki.net/index.php/I...nFOAM_versions
June 29, 2019, 07:57 |
Sujay
Rep Power: 8 |
Thanks! I have been able to use both with the help of aliases.
foam-extend-4.0, linux, openfoam |
Difference between OpenFOAM and FOAM extend | ce73stargazer | OpenFOAM | 9 | November 10, 2019 11:00 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 09:51 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 23:07 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
