[OpenFOAM.org] Offline installation of OpenFOAM6 on windows 10 |
February 13, 2019, 15:09 |
mohsen kh
Rep Power: 14 |
Dear FOAMers
Due to ip blocking I faced following error for online installing OpenFOAM6 on windows 10. Code:
Err:1 http://downloads.sourceforge.net/pro...am/foam/ubuntu bionic/main amd64 openfoam6 amd64 20190108 403 Forbidden [IP: 216.105.38.13 80] Err:2 http://downloads.sourceforge.net/pro...am/foam/ubuntu bionic/main amd64 paraviewopenfoam56 amd64 0-20181220 403 Forbidden [IP: 216.105.38.13 80] E: Failed to fetch http://downloads.sourceforge.net/pro...0108_amd64.deb 403 Forbidden [IP: 216.105.38.13 80] E: Failed to fetch http://downloads.sourceforge.net/pro...1220_amd64.deb 403 Forbidden [IP: 216.105.38.13 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? any help and suggestion is really appreciated. Kind Regards, Mohsen Last edited by wyldckat; February 17, 2019 at 17:15. Reason: Added [CODE][/CODE] markers |
February 15, 2019, 02:25 |
Daniel
Rep Power: 21 |
Dear Mohsen,
Well I would suggest contacting your service provider and ask to resolve the issue with sourcforge as I had the same problem a few months ago. Meanwhile, you may try to use a vpn connection and check if that will resolve the ip blockage. Unfortunately I don't have any experience with building OpenFOAM from source on windows platform. I think only the nextRelease branch of foam-extend natively supports building from source on windows. Last edited by Daniel_Khazaei; February 15, 2019 at 08:06. |
February 17, 2019, 17:18 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer @m5m5kh: You can find detailed installation steps for building from source code from here: https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04
Nonetheless, have you tried downloading the links that the error messages have given you? Namely the last two links are linking directly to the Deb files it's trying to download. Perhaps you are able to download them through your web browser?
February 22, 2019, 10:23 |
#4 | |
mohsen kh
Rep Power: 14 |
I resolved it through the use of a vpn. the installation completed successfully. thanks again for your hints. |
[Other] How to install OpenFOAM under Windows? | lzgwhy | OpenFOAM Installation | 19 | October 7, 2023 05:27 |
[OpenFOAM.com] v1606+ Installation on Windows 7 | LennyZ | OpenFOAM Installation | 3 | December 4, 2016 10:07 |
[OpenFOAM.com] Installation issue OpenFOAM for Windows after restart | TomKopp | OpenFOAM Installation | 16 | July 14, 2016 03:15 |
SU2 Installation on Windows 32 bit | niddaas | SU2 Installation | 3 | May 6, 2016 18:03 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
