[OpenFOAM.org] FATAL Error Paraview
Like Tree3Likes
  • 2 Post By student666
  • 1 Post By dlcdlcdlc
Old   January 1, 2019, 14:20
Default FATAL Error Paraview
M. C.
student666 is on a distinguished road
Hi all,
I'm having this trouble with paraview and I can't run it.
If I type:
$ paraFoam
FATAL ERROR: The official reader module for OpenFOAM data does not exist on
your system.  This means that the version of ParaView you are using was not
compiled with OpenFOAM, or distributed with a packaged version of OpenFOAM.
For information on packaged versions of OpenFOAM/ParaView and compilation of
OpenFOAM/ParaView, see https://openfoam.org/download
Alternatively, you might be able to view your OpenFOAM data with the reader
module provided with ParaView by running:
    paraFoam -builtin
If I type:
paraFoam -builtin
Created temporary 'run.foam'
ParaView failed to open using available graphics hardware.
Trying fallback to software rendering using MESA.
/opt/openfoam-dev/bin/paraFoam: 67: /opt/openfoam-dev/bin/paraFoam: paraview: not found
I just followed the steps on openfoam.org but I can't see any problem during installation.
I'm using LinuxMint 19.1 cinnamon.
thx for any help
student666 is offline   Reply With Quote
Old   January 1, 2019, 14:58
Default [Solved]
M. C.
ok, problem solved by installing manually the .deb package from
http://dl.openfoam.org/ubuntu/dists/.../binary-amd64/
Regards.
wyldckat and Frost like this.
Old   April 27, 2020, 10:09
denglichuan
dlcdlcdlc is on a distinguished road
Regards.
I wonder which .deb package you installed. Tell me in detail, please.
sunflowers likes this.
dlcdlcdlc is offline   Reply With Quote
Old   May 28, 2020, 05:29
Default still confused
sunflowers is on a distinguished road
since you haven't told us which .deb package you downloaded, I downloaded the newest version of openfoam and paraview...
turns out I'm still not able to solve my problem: I installed the paraview package, because I thought this is what wasn't working... openfoam couldn't be installed due to unmet dependencies
can anybody help?
and how do I make sure, that the new installed packages are at the right place from my earlier installed openfoam / directory?
sunflowers is offline   Reply With Quote
Old   May 28, 2020, 18:32
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- Could you please clarify your question? I didn't understand whether you try to install ParaView version with whatsoever.
Thank you.
HPE is offline   Reply With Quote
Old   June 5, 2020, 07:57
I'm sorry, I'm totally new to ubuntu and my first error was like the one in this thread:
tessa@tessa-MacBook:~/OpenFOAM/tessa-7/run/cavity$ paraFoam &
[1] 2472
tessa@tessa-MacBook:~/OpenFOAM/tessa-7/run/cavity$ FATAL ERROR: The official reader module for OpenFOAM data does not exist on
paraFoam -builtin
second message:
tessa@tessa-MacBook:~/OpenFOAM/tessa-7/run/cavity$ paraFoam -builtin
Created temporary 'cavity.foam'
/home/tessa/OpenFOAM/OpenFOAM-7/bin/paraFoam: 67: paraview: not found
so I thought my problem is the same... but I'm not sure what's the problem and downloading the package didn't solve my problem - although I'm not sure whether what and how I did it was right...
Sorry for so less knowledge. Hoping somebody can help me (:
Old   November 23, 2020, 13:08
Default Follow Up.
malcolm
locutus is on a distinguished road
I have the same problem that's in this thread and haven't been able to resolve it. I followed the instructions here: https://openfoam.org/download/8-ubuntu/
and have the same error message as the original poster. I'm in the same point as sunflowers. Can anyone offer a solution?
locutus is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 08:53
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected Djub OpenFOAM Meshing & Mesh Conversion 0 July 15, 2014 05:43
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
