[OpenFOAM.org] OpenFOAM 3.0.1 in Ubuntu 18.04 |
Rep Power: 8 ![]() |
I've been trying to install OpenFOAM 3.0.1 in Ubuntu 18.04 with no success... Unfortunately, there are still no instructions in openfoamwiki.net. This is from the $WM_PROJECT_DIR/Allwmake log when attempting installing through the official instructions at https://openfoam.org/download/3-0-1-source/ Code:
ensight/part/ensightPart.C: In member function ‘bool Foam::ensightPart::isFieldDefined(const Foam::List<double>&) const’: ensight/part/ensightPart.C:54:39: error: ‘isnan’ was not declared in this scope if (id >= field.size() || isnan(field[id])) ^~~~~ ensight/part/ensightPart.C:54:39: note: suggested alternative: In file included from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/doubleFloat.H:32:0, from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/floatScalar.H:38, from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/scalar.H:39, from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/IOstream.H:49, from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/Ostream.H:39, from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/OSstream.H:39, from /opt/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/OFstream.H:38, from lnInclude/ensightFile.H:36, from ensight/part/ensightPart.H:40, from ensight/part/ensightPart.C:26: /usr/include/c++/7/cmath:639:5: note: ‘std::isnan’ isnan(_Tp __x) ^~~~~ /opt/OpenFOAM-3.0.1/wmake/rules/General/transform:8: recipe for target '/opt/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Opt/src/conversion/ensight/part/ensightPart.o' failed make: *** [/opt/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Opt/src/conversion/ensight/part/ensightPart.o] Error 1 The wiki instructs running $WM_THIRD_PARTY_DIR/makeParaView4 before $WM_PROJECT_DIR/Allwmake. This also results in a compilation error Code:
CMake Error at VTK/CMake/vtkCompilerExtras.cmake:47 (if): if given arguments: "gcc: error: ARGS: Ficheiro ou directoria inexistente I've also tried to follow some of the instructions for compiling OpenFOAM 2.3.1 for Ubuntu 18.04 at https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04 for example changing the compiler to g++5, but it didn't have any success either. Thank you in advance for any help provided Last edited by jlr; December 21, 2018 at 06:39. |
#2 | |
Mark Olesen
Rep Power: 40 ![]() ![]() |
The OpenFOAM version that you are trying to use is several years old and some of it will simply not compile with newer compilers. I'd suggest that you obtain a new version. OpenFOAM-v1812 is coming out today. The website (www.openfoam.com) is still being updated, but the source files are already available https://sourceforge.net/projects/ope...s/files/v1812/ One of my coworkers compiled it from source on ubuntu 18.04 yesterday and had no issues. Cheers, /mark |
I already use several versions of OpenFOAM for different projects who make use of custom code written for different versions. Right now, I need to use OpenFOAM 3.0.1.
It should be possible to compile since OpenFOAM 2.3.1, which is older, apparently can be compiled in Ubuntu 18.04 (I haven't tried it yet though) |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings to all!
@jlr: I've now finished writing and testing the instructions for building OpenFOAM 3.0.1 on Ubuntu 18.04, by relying on GCC 5: https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04 @Mark: Congrats on the early release of v1812! In order for people to adhere always to the more recent versions, we'll need to make it easier to port their old inherited code to work with the more recent code, so please do keep up with the good work at: https://www.openfoam.com/documentati...rade-guide.php But they'll also need to confirm if the results are still at least similar to the more recent versions, so we need a way to run tests with the older versions. Hence me having written up instructions for them at openfoamwiki.net along with the requests as they come in. That said, I am thinking of relying on AppImage in the future, but it's sometime away for me to do this... Best regards, Bruno |
I got it working! Thank you wyldckat!
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[OpenFOAM.org] Issues installing openfoam 6 on Ubuntu 18.04 | rnburne | OpenFOAM Installation | 2 | October 20, 2018 16:29 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
OpenFOAM Foundation releases OpenFOAMŪ 3.0.1 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 3 | January 4, 2016 17:15 |
