[OpenFOAM.org] Issues installing openfoam 6 on Ubuntu 18.04 |
October 20, 2018, 11:33 |
Ron Burnett
Rep Power: 13 |
I'm upgrading to openfoam 6 on a newly installed Ubuntu 18.04.1
using the instructions at openfoam.org, which have worked well in the past. In response to the following commands....... Code:
sudo sh -c "wget -O - http://dl.openfoam.org/gpg.key | apt-key add -" sudo add-apt-repository http://dl.openfoam.org/ubuntu Code:
r@sys:~$ sudo apt-get update Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease Hit:2 http://archive.canonical.com/ubuntu bionic InRelease Get:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Get:5 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB] Get:4 http://dl.openfoam.org/ubuntu bionic InRelease [6,337 B] Get:6 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Reading package lists... Done E: Release file for http://us.archive.ubuntu.com/ubuntu/...ates/InRelease is not valid yet (invalid for another 1h 50min 44s). Updates for this repository will not be applied. E: Release file for http://dl.openfoam.org/ubuntu/dists/bionic/InRelease is not valid yet (invalid for another 2h 35min 9s). Updates for this repository will not be applied. E: Release file for http://security.ubuntu.com/ubuntu/di...rity/InRelease is not valid yet (invalid for another 1h 50min 33s). Updates for this repository will not be applied. E: Release file for http://us.archive.ubuntu.com/ubuntu/...orts/InRelease is not valid yet (invalid for another 1h 51min 9s). Updates for this repository will not be applied. Code:
r@sys:~$ sudo apt-get update Hit:1 http://archive.canonical.com/ubuntu bionic InRelease Hit:3 http://us.archive.ubuntu.com/ubuntu bionic InRelease Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB] Hit:8 http://us.archive.ubuntu.com/ubuntu xenial InRelease Get:7 http://dl.openfoam.org/ubuntu bionic InRelease [6,337 B] Get:4 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB] Get:5 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Get:6 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Get:9 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB] Get:10 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB] Reading package lists... Done E: Release file for http://security.ubuntu.com/ubuntu/di...rity/InRelease is not valid yet (invalid for another 1h 25min 1s). Updates for this repository will not be applied. E: Release file for http://dl.openfoam.org/ubuntu/dists/bionic/InRelease is not valid yet (invalid for another 2h 9min 37s). Updates for this repository will not be applied. E: Release file for http://security.ubuntu.com/ubuntu/di...rity/InRelease is not valid yet (invalid for another 1h 25min 39s). Updates for this repository will not be applied. E: Release file for http://us.archive.ubuntu.com/ubuntu/...ates/InRelease is not valid yet (invalid for another 1h 25min 12s). Updates for this repository will not be applied. E: Release file for http://us.archive.ubuntu.com/ubuntu/...orts/InRelease is not valid yet (invalid for another 1h 25min 38s). Updates for this repository will not be applied. E: Release file for http://us.archive.ubuntu.com/ubuntu/...orts/InRelease is not valid yet (invalid for another 1h 27min 37s). Updates for this repository will not be applied. E: Release file for http://us.archive.ubuntu.com/ubuntu/...ates/InRelease is not valid yet (invalid for another 1h 52min 46s). Updates for this repository will not be applied. Code:
r@sys:~$ sudo apt-get -y install openfoam6 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: openfoam6 : Depends: libreadline-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages. Ron Last edited by wyldckat; October 20, 2018 at 16:09. Reason: Added [CODE][/CODE] markers |
October 20, 2018, 16:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I've Google'd for:
ubuntu "Release file for" "is not valid yet" As far as I can figure out, this is a safety measure to avoid machines using a repository that is still syncing up with another server. Allegedly:
October 20, 2018, 17:29 |
Ron Burnett
Rep Power: 13 |
That was indeed the case........I had the correct
local time but the wrong time zone. The installation is working properly, thank you for the help Bruno. Ron |
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 | JGadelho | OpenFOAM Community Contributions | 36 | April 27, 2024 17:46 |
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 | AHutchison | OpenFOAM Installation | 6 | June 4, 2013 13:11 |
Installing OpenFOAM 1.6-ext on Ubuntu 11.10 | immortality | OpenFOAM Installation | 17 | May 6, 2013 18:43 |
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 | yoddha24 | OpenFOAM | 7 | November 22, 2012 12:46 |
Trouble with installing OpenFOAM on Ubuntu | Milos | OpenFOAM Installation | 16 | November 16, 2009 03:44 |
