[OpenFOAM.org] Installing metis on OpenFOAM-5.x
Like Tree1Likes
  • 1 Post By olesen
Old   October 5, 2018, 13:09
Default Installing metis on OpenFOAM-5.x
So Anon
redbullah is on a distinguished road
Hi all,
To use metis, I downloaded the metis-5.1.0 version here, but not sure if this is a compatible version and how to install it. Is there a procedure to install it with full compatibility within OF-5.x?
Thanks in advance
redbullah is offline   Reply With Quote
Old   October 7, 2018, 13:52
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I've used http://glaros.dtc.umn.edu/gkhome/fet...s-5.1.0.tar.gz with OpenFOAM-1712 and 1806. There is amakeMETIS ThirdParty script, a wmake `have_metis` detection/selection script and of course a corresponding etc/config.sh/metis file.
I did some testing comparisons between metis, scotch and kahip, trying to push them to produce bad decompositions. Eg, take the motorBike tutorial and try to decompose on a silly number of processors (512, 1024, 2048, ...). As quality metrics I then looked at the number of processor neighbours and the number of neighbour faces. For a wide range they performed quick similarly, but scotch did produce some odd decompositions too (ie, suddenly the worst processor had 65 neighbours and the rest had 30 or so). Didn't observe this for metis or kahip.
Nonetheless, one argument for scotch could be pt-scotch if you have large meshes. Otherwise you run into the problem that the indices for the adjacency lists overflow. In that case, it could also be reasonable to use a multi-level decomposition with hierarchical for the first level and metis for the subsequent levels.
wyldckat likes this.
olesen is offline   Reply With Quote
Old   October 8, 2018, 14:08
Retired Super Moderator
Bruno Santos
Quick answer:
  1. Unpack the "metis-5.1.0" package inside the "ThirdParty-5.x" folder.
  2. Make sure that the unpacked folder is named "metis-5.1.0" and that is does not contain only one folder inside that one (i.e. it didn't unpack into "metis-5.1.0/metis-5.1.0").
  3. Run the Allwmake script in the "OpenFOAM-5.x" folder and it should automatically build Metis along with the libraries and applications that use it.
I know this because:
  1. It's pre-configured in this file: https://github.com/OpenFOAM/OpenFOAM...onfig.sh/metis
  2. The Allwmake script in the "ThirdParty-5.x" folder is already configured to do the trick on its own: https://github.com/OpenFOAM/ThirdPar.../Allwmake#L312
The same should work with OpenFOAM 6 and OpenFOAM-dev.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
metis decompose OpenFoam 2.0.0 sebastianweiper OpenFOAM Installation 11 December 29, 2020 12:59
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
[waves2Foam] A few notes about problems and solutions when installing with OpenFOAM v1712 oceanFoam OpenFOAM Community Contributions 0 June 22, 2018 09:52
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
