[OpenFOAM.org] Install OpenFOAM 2.3.1 on cluster with Intel Compiler |
August 26, 2018, 03:40 |
Ehsan Asgari
Rep Power: 18 |
Dear All,
I have faced some issues in installing OpenFOAM 2.3.1 on a HPC cluster with CentOS 7, non-root access, and Intel Compiler. In the first place, I did the following: Code:
export FOAM_INST_DIR=$HOME/ch_openfoa/Tetralith/OpenFOAM mkdir -p $FOAM_INST_DIR cd $FOAM_INST_DIR Then I did the following modifications: Code:
cp -r $FOAM_INST_DIR/OpenFOAM-2.3.1/wmake/rules/linux64Icc $FOAM_INST_DIR/OpenFOAM-2.3.1/wmake/rules/linux64IccHani sed -i s/fPIC/"fPIC -Nmpi -Nmkl -xCORE-AVX512"/g $FOAM_INST_DIR/OpenFOAM-2.3.1/wmake/rules/linux64IccHani/c++ Code:
alias OF231T='export FOAM_INST_DIR=/home/x_vache/ch_openfoam/Tetralith/OpenFOAM; module load buildenv-intel/2018a-eb; export MPI_ROOT=$I_MPI_ROOT; . /home/x_vache/ch_openfoam/Tetralith/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc WM_COMPILER=IccHani WM_MPLIB=INTELMPI' I checked the outputs of the following commands: Code:
mpirun --version Intel(R) MPI Library for Linux* OS, Version 2018 Update 1 Build 20171011 (id: 17941) Copyright (C) 2003-2017, Intel Corporation. All rights reserved. which mpirun /software/sse/easybuild/prefix/software/impi/2018.1.163-iccifort-2018.1.163-GCC-6.4.0-2.28/bin64/mpirun mpicc --version icc (ICC) 18.0.1 20171018 Copyright (C) 1985-2017 Intel Corporation. All rights reserved. which mpicc /software/sse/easybuild/prefix/software/impi/2018.1.163-iccifort-2018.1.163-GCC-6.4.0-2.28/bin64/mpicc I have attached the log file to the following link to further investigate the problem. https://www.dropbox.com/s/6lshhxyj0tybv6a/log.make?dl=1 I would appreciate if you help me to do proper installation. Regards, Syavash |
August 26, 2018, 11:27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: The very first error message is this:
icpc ERROR: Unsupported compiler mpiicpc. Try -Nhelp. My guess is that in whichever way you load in the ICC environment, you also need to load in the Intel-MPI environment as well, so that mpiicpc is ready to be used.... no wait... what? The compiler mpiicpc is indeed found, it's just that it's not compatible with the compiler options you've chosen?! OK, new guess: "-Nmpi" is not supported, hence the error. Side note: You better edit the file "$FOAM_INST_DIR/OpenFOAM-2.3.1/wmake/rules/linux64IccHani/c++" manually and remove the duplicate entries, along with removing "-Nmpi".
August 26, 2018, 12:33 |
#3 | |
Ehsan Asgari
Rep Power: 18 |
Dear Bruno, Thank you very much for your reply. Actually, I tried to do a fresh install using the general guide provided here (Neglect first three steps): https://openfoamwiki.net/index.php/I...HEL#CentOS_7.0 with replacing the command in step 8 with the following: Code:
module load buildenv-intel/2018a-eb || export PATH=$PATH:/software/sse/easybuild/prefix/software/impi/2018.1.163-iccifort-2018.1.163-GCC-6.4.0-2.28/intel64/bin Code:
FOAM_INST_DIR=$HOME/ch_openfoam/Tetralith/OpenFOAM Code:
cp -r $FOAM_INST_DIR/OpenFOAM-2.3.1/wmake/rules/linux64Icc $FOAM_INST_DIR/OpenFOAM-2.3.1/wmake/rules/linux64IccHani sed -i s/fPIC/"fPIC -Nmpi -Nmkl -xCORE-AVX512"/g $FOAM_INST_DIR/OpenFOAM-2.2.x/wmake/rules/linux64IccHani/c++ Code:
source $FOAM_INST_DIR/OpenFOAM-2.3.1/etc/bashrc WM_NCOMPPROCS=4 WM_COMPILER=IccHani WM_MPLIB=INTELMPI echo "alias OF231T='export FOAM_INST_DIR=/home/x_vache/ch_openfoam/Tetralith/OpenFOAM; module load buildenv-intel/2018a-eb; export MPI_ROOT=$I_MPI_ROOT; source $HOME/ch_openfoam/Tetralith/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc Compile OF2.1 with Intel Icc and Intel MPI Compile OF2.1 with Intel Icc and Intel MPI And modified etc/config/settings.sh according to the following post: Failed to compile OpenFOAM 3.0.1 with icc The settings.sh now looks like the following: Code:
INTELMPI) # no trailing slash [ "${MPI_ROOT%/}" = "${MPI_ROOT}" ] || MPI_ROOT="${MPI_ROOT%/}" export FOAM_MPI="${MPI_ROOT##*/}" export MPI_ARCH_PATH=$MPI_ROOT if [ ! -d "$MPI_ROOT" -o -z "$MPI_ARCH_PATH" ] then echo "Warning in $WM_PROJECT_DIR/etc/config/settings.sh:" 1>&2 echo " MPI_ROOT not a valid mpt installation directory or ending in a '/'." 1>&2 echo " Please set MPI_ROOT to the mpt installation directory." 1>&2 echo " MPI_ROOT currently set to '$MPI_ROOT'" 1>&2 fi if [ "$FOAM_VERBOSE" -a "$PS1" ] then echo "Using INTEL MPI:" 1>&2 echo " MPI_ROOT : $MPI_ROOT" 1>&2 echo " FOAM_MPI : $FOAM_MPI" 1>&2 fi _foamAddPath $MPI_ARCH_PATH/bin64 _foamAddLib $MPI_ARCH_PATH/lib64 ;; *) export FOAM_MPI=mpi #export FOAM_MPI=dummy ;; https://www.dropbox.com/s/k2coamml4s....make_new?dl=1 Regards, Syavash |
September 1, 2018, 17:28 |
Bruno Santos
Rep Power: 128 |
Greetings Syavash,
From what I can see, the changes you've made to "settings.sh" were not necessary... but if it's partially working now, I guess you may have changed something else too. Based on the log file you provided, my guess is that the problem is related to the "libPstream.so" that was built to use Intel-MPI is being picked up when it should not. I suspect that the following trick might work, so with the OpenFOAM 2.3.1 environment activated, run the following commands: Code:
cd $WM_PROJECT_DIR mv $FOAM_LIBBIN/$FOAM_MPI $FOAM_LIBBIN/${FOAM_MPI}_tmp applications/Allwmake > log.make.applications 2>&1 mv $FOAM_LIBBIN/${FOAM_MPI}_tmp $FOAM_LIBBIN/$FOAM_MPI Hopefully this will solve the problem. Best regards, Bruno |
September 2, 2018, 05:21 |
#5 | |
Ehsan Asgari
Rep Power: 18 |
Dear Bruno, Thanks for your reply. I did as you suggested and attached the log file at the following link: https://www.dropbox.com/s/cf7x1buwjk...lications?dl=1 I also removed changes in settings.sh but made no difference! I really appreciate your help. Regards, Syavash |
September 2, 2018, 10:16 |
Bruno Santos
Rep Power: 128 |
Quick answer: How did the file "platforms/linux64IccHaniDPOpt/lib/libPstream.so" come into existence? It should not exist... please delete that file, which can be done with the following commands:
cd $WM_PROJECT_DIR rm platforms/linux64IccHaniDPOpt/lib/libPstream.so |
September 3, 2018, 05:46 |
#7 | |
Ehsan Asgari
Rep Power: 18 |
Dear Bruno, Thank you! I removed that file and OpenFOAM was installed without problem. However, after I executed the following command to move back MPI_FOAM I received an error when I entered "pimpleFoam" in the terminal. Code:
mv $FOAM_LIBBIN/${FOAM_MPI}_tmp $FOAM_LIBBIN/$FOAM_MPI Code:
pimpleFoam: symbol lookup error: /home/x_vache/ch_openfoam/Tetralith/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64IccHaniDPOpt/lib/2018.1.163-iccifort-2018.1.163-GCC-6.4.0-2.28/libPstream.so: undefined symbol: ompi_mpi_op_sum Code:
mpprun info: Starting impi run on 3 node ( 96 rank X 1 th ) for job ID 101262 --> FOAM FATAL ERROR: Trying to use the dummy Pstream library. This dummy library cannot be used in parallel mode From function UPstream::init(int& argc, char**& argv) in file UPstream.C --> FOAM FATAL ERROR: Trying to use the dummy Pstream library. This dummy library cannot be used in parallel mode From function UPstream::init(int& argc, char**& argv) in file UPstream.C at line 37. FOAM exiting --> FOAM FATAL ERROR: Trying to use the dummy Pstream library. P.S. I had removed changes in settings.sh prior to installation. |
September 4, 2018, 06:53 |
Bruno Santos
Rep Power: 128 |
Quick answer:
September 4, 2018, 10:08 |
#9 | |
Ehsan Asgari
Rep Power: 18 |
Dear Bruno, Thank you for the reply. As I was thinking I had messed with the settings and addresses, I did again a fresh install and this time did not change any things. Before installing OpenFOAM I also moved back ${FOAM_MPI}_tmp to $FOAM_MPI. I followed the instructions given in WIKI again and OpenFOAM was installed successfully without a problem and did not complain about libPstream either! I tried a parallel run and it was OK. Though paraFoam was not installed (which I guess it could be due to qmake!) it should be all rights for now. Thank you for your time and patience. I have posted the alias in the .bashrc file as somebody may find it helpful: Code:
alias OF231T='export FOAM_INST_DIR=/home/.../OpenFOAM; module load buildenv-intel/2018a-eb; export MPI_ROOT=/.../software/impi/2018.1.163-iccifort-2018.1.163-GCC-6.4.0-2.28; source /home/.../OpenFOAM/OpenFOAM-2.3.1/etc/bashrc WM_NCOMPPROCS=4 WM_COMPILER=Icc WM_MPLIB=INTELMPI' Syavash Last edited by syavash; September 4, 2018 at 11:10. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[foam-extend.org] foam-extend-3.1 installation on cluster using system mpi and intel compiler | mmmn036 | OpenFOAM Installation | 3 | February 12, 2019 11:26 |
Parallel cluster solving with OpenFoam? P2P Cluster? | hornig | OpenFOAM Programming & Development | 8 | December 5, 2010 17:06 |
How to install the OpenFoam in the cluster. Please help me! | flying | OpenFOAM Installation | 6 | November 27, 2009 04:00 |
How to run Openfoam in a cluster after I install it | xiuying | OpenFOAM Installation | 5 | May 5, 2008 13:54 |
