June 7, 2018, 18:32 |
Multiple users using same docker?
D.Evans
Good evening everyone. First day using OpenFOAM and I'm afraid I already have some silly questions.
We want to start exploring OpenFOAM in my company and for that reason the IT people set up a virtual machine using CenTOS 7.x and a dockers installation. From this point we, non-IT experts, will manage the system. In the future, if everything goes fine we expect to scale the system. So, first basic doubts:
Regards and thanks for your time. Last edited by Void; June 8, 2018 at 03:56. |
June 8, 2018, 05:35 |
matej forman
Rep Power: 17 |
1) it is possible. You need, however to isolate the users somehow. There are several methods how to approach this. System nice way is to use http://singularity.lbl.gov , darker easier way is to follow this: https://askubuntu.com/questions/9397...multiple-users where you need to change the script with witch you are accessing the container. 2) I would personally opt for a compilation. If you feel you are facing troubles, you could use Spack. you only need to install it and call a command which will download and install OpenFOAM and all the necessary libs. Just follow the instructions from here:https://www.openfoam.com/releases/op...hp#build-spack happy foaming Matej |
June 13, 2018, 13:43 |
D.Evans
Thank you very much for the detailed answer, Matej.
OpenFoam+Paraview manually compiled now and working fine but definitely I'll try Spack as soon as possible. It sounds really promising. Regards |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
Error in run Batch file | saba1366 | CFX | 4 | February 10, 2013 01:15 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
OF installation for multiple users | mirko | OpenFOAM Installation | 0 | June 24, 2010 10:52 |
