[OpenFOAM.com] Build problem with OF 1712
Like Tree1Likes
  • 1 Post By olesen
Old   June 6, 2018, 10:49
Default Build problem with OF 1712
P.A.
blaise is on a distinguished road
Hello all,
I am facing a problem when trying to compile OF 1712. OS is CentOS 6.4, gcc is 4.8.5, and compilation runs to the very end, giving the following errors shortly before the end:
g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DUSE_OMP -fopenmp -I/usr/local/OpenFOAM/OpenFOAM-v1712/src/fileFormats/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-v1712/src/surfMesh/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-v1712/src/meshTools/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c utilities/meshes/polyMeshGenModifier/polyMeshGenModifierZipUpCells.C -o /usr/local/OpenFOAM/OpenFOAM-v1712/build/linux64Gcc48DPInt64Opt/modules/cfmesh/meshLibrary/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierZipUpCells.o
In file included from lnInclude/DynList.H:254:0,
from lnInclude/VRWGraph.H:41,
from lnInclude/meshSubset.H:40,
from lnInclude/polyMeshGenPoints.H:41,
from lnInclude/polyMeshGenFaces.H:40,
from lnInclude/polyMeshGenCells.H:40,
from lnInclude/polyMeshGen.H:40,
from utilities/meshes/polyMeshGenModifier/polyMeshGenModifier.H:40,
from utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.C:26:
lnInclude/DynListI.H: In Instanziierung von »Foam::Module:ynList<T, staticSize>:ynList(const ListType&) [with ListType = int; T = long int; long int staticSize = 16l]«:
lnInclude/helperFunctionsTopologyManipulationI.H:600:34: von hier erfordert
lnInclude/DynListI.H:218:21: Fehler: Abfrage des Elementes »size« in »l«, das vom Nicht-Klassentyp »const int« ist
setSize(l.size());
lnInclude/DynListI.H:221:32: Fehler: indizierter Wert ist weder ein Feld noch ein Zeiger
this->operator[](i) = l[i];
lnInclude/DynListI.H: In Instanziierung von »Foam::Module:ynList<T, staticSize>:ynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6l]«:
lnInclude/helperFunctionsGeometryQueriesI.H:1144:37: von hier erfordert
setSize(l.size());
make[1]: *** [/usr/local/OpenFOAM/OpenFOAM-v1712/build/linux64Gcc48DPInt64Opt/modules/cfmesh/meshLibrary/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.o] Fehler 1
make[1]: *** Warte auf noch nicht beendete Prozesse...
make: *** [cfmesh] Fehler 2
I suppose the error is related to the cfMesh library, but I do not know how to overcome it.
I have half a dozen different versions of OF installed, and the only other version containing the file DynListI.H is foam-extend-4.0, which compiles fine. The respective code line is the same in both versions, if that helps. The faulty method is:
template<class T, Foam::label staticSize>
template<class ListType>
inline Foam::Module::DynList<T, staticSize>::DynList(const ListType& l)
    dataPtr_(nullptr),
    nAllocated_(0),
    staticData_(),
    nextFree_(0)
    setSize(l.size());
    for (label i = 0; i < nextFree_; ++i)
        this->operator[](i) = l[i]; // <== this is line 221
    # ifdef DEBUG
    checkAllocation();
    # endif
Any idea, how to get over this? I tested some tutorials, and they run correctly.
Best regards,
Pascal.
blaise is offline   Reply With Quote
Old   June 7, 2018, 11:02
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by blaise View Post
Hello all,
g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 --
Problems with 64-bit labels were fixed 5-Jan-2018. The changes in the commit are fairly small, so you can very easily make the changes yourself too.
The commit is here:
https://develop.openfoam.com/Communi...367fd9565ad8ae
As an alternative, you could also just use 32-bit labels. AFAIK this is what foam-extend has anyhow.
blaise likes this.
olesen is offline   Reply With Quote
Old   June 12, 2018, 09:12
P.A.
Great, that did the trick!
Thanks a lot!
Cheers,
Pascal.
Building from Source on Windows using Cygwin64 ericthefatguy SU2 2 May 12, 2015 19:23
QT creator build option problem bluenail OpenFOAM Programming & Development 2 July 22, 2014 14:30
Hardware build review/advise for student desktop AerE Hardware 10 July 5, 2013 07:03
Build problem Jeff CFX 0 July 31, 2003 14:21
CFX4.3 Build problem cfx4.3 user CFX 4 January 2, 2003 15:18
