[Other] OpenFOAM failing to read binary files
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 12, 2018, 03:30
Default OpenFOAM failing to read binary files
me3840 is on a distinguished road
I have a cluster I'm compiling OpenFOAM on. I have tried both the foam-extend 4.0 and OpenFOAM 5.0 which have the same issue, so I suspect I'm doing something wrong.
The compilation of both is successful, however when I try to read any binary file, I get errors similar to:
Expected a '}' while reading binaryBlock...
if I write meshes with ASCII they will read and decompose just fine.
Since my compilation on my workstation (Centos 5) works just fine, and the cluster is based on Scientific Linux (which is pretty similar to Centos 5) I imagine most of what I do should be pretty similar. No errors get thrown during compilation after I load all the needed modules.
How can I test what could be the issue here?
Thanks
me3840 is offline   Reply With Quote
Old   April 15, 2018, 18:49
Retired Super Moderator
Bruno Santos
Greetings me3840,
That's a pretty bizarre error message, within the context of what you described. My guesses would be:
  1. That the header files being used during compilation, do not match the libraries being used at runtime.
    • For example, this could make sense if the cluster is using Big Endian byte order for binary data, while your workstation is using Little Endian: https://en.wikipedia.org/wiki/Endianness - and this is assuming you were then using the simulation case on both machines, e.g.: decomposing on the workstation and then simulating on the cluster.
    • The same could happen, if the case is decomposed on the login node of the cluster, but then simulated on the cluster nodes, in case they use different Endianness.
  2. There could be some library contamination when launching the case on the cluster nodes, for example, the shell environment on the login node does not match the same environment on the cluster nodes.
To figure out what exactly is going on, it's fairly simple:
  1. Copy the tutorial case "$FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity". This case is so simple, that the results should be pretty much identical on any machine.
  2. Configure the file "system/controlDict" to write as binary.
  3. Run the case in serial mode on the following machines:
    1. The workstation.
    2. The login node on the cluster.
    3. On a normal cluster node (via job scheduler?).
  4. Then take the 3 cases, place them in your workstation and use an hexadecimal editor to look into the file "0.5/p" on each case. With luck, you can pinpoint what bytes are different and how exactly different they are.
Beyond this, it would be good to know which compiler name and version you used and how you compiled on each machine. For example, if you compiled on the workstation and then copied to the cluster, or vice-versa; or if you simply used the same installation instructions on both machines.
And it would be nice to know which installation instructions you've followed
Best regards,
Bruno
PS: Caution: RHEL and CentOS 5 are no longer maintained, so use it at your own risk
Saikumar Bunni likes this.
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
