[Other] blueCFD-Core-2016 user compiled solvers not running in parallel |
April 3, 2018, 07:17 |
Bence Somogyi
Rep Power: 17 |
Dear All,
I am facing the issue, that the solvers I compile in blueCFD-Core-2016 are not running in parallel. E.g. running the pitzDaily example with the original simpleFoam solver works: Code:
$ mpirun -np 4 simpleFoam.exe -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 4.x-f59a08eaaf41 Exec : simpleFoam.exe -parallel Date : Apr 03 2018 Time : 12:10:01 Host : "KTMATRDWS635" PID : 9668 Case : E:/TESTS/OPENFOAM/mpi/pitzDaily nProcs : 4 Slaves : 3 ( "KTMATRDWS635.10192" "KTMATRDWS635.6884" "KTMATRDWS635.12208" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Starting time loop streamLine streamlines: automatic track length specified through number of sub cycles : 5 Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0522766, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0297192, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.09078, No Iterations 17 time step continuity errors : sum local = 1.58846, global = 0.224934, cumulative = 0.224934 smoothSolver: Solving for epsilon, Initial residual = 0.198074, Final residual = 0.00900106, No Iterations 3 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.044153, No Iterations 3 ExecutionTime = 0.093 s ClockTime = 0 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.449772, Final residual = 0.0335978, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0.276751, Final residual = 0.026266, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0514668, Final residual = 0.00405939, No Iterations 16 time step continuity errors : sum local = 3.67803, global = 0.176707, cumulative = 0.401641 smoothSolver: Solving for epsilon, Initial residual = 0.142642, Final residual = 0.0092437, No Iterations 3 bounding epsilon, min: -103.176 max: 18221.7 average: 81.1715 smoothSolver: Solving for k, Initial residual = 0.397026, Final residual = 0.0304835, No Iterations 3 ExecutionTime = 0.109 s ClockTime = 0 s Code:
user@machine MINGW64 OpenFOAM-4.x e/TESTS/OPENFOAM/mpi/pitzDaily $ mpirun -np 4 testSimpleFoam.exe -parallel user@machine MINGW64 OpenFOAM-4.x /e/TESTS/OPENFOAM/mpi/pitzDaily $ Has any of you experienced this issue? With Best Regards, Bence |
April 4, 2018, 06:46 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
April 4, 2018, 07:15 |
Bence Somogyi
Rep Power: 17 |
Dear Bruno,
This does not help. Code:
foamJob -p -s testSimpleFoam Code:
runParallel testSimpleFoam Code:
mpirun -np 4 testSimpleFoam.exe -parallel BR, Bence |
April 4, 2018, 08:40 |
Bence Somogyi
Rep Power: 17 |
Yes, it runs as expected:
user@machine MINGW64 OpenFOAM-4.x /e/TESTS/OPENFOAM/mpi/pitzDaily $ testSimpleFoam.exe /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 4.x-f59a08eaaf41 Exec : C:/PROGRA~1/BLUECF~1/ofuser-of4/platforms/mingw_w64GccDPInt32Opt/bin/testSimpleFoam.exe Date : Apr 04 2018 Time : 13:39:03 Host : "KTMATRDWS635" PID : 7876 Case : E:/TESTS/OPENFOAM/mpi/pitzDaily nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Starting time loop streamLine streamlines: automatic track length specified through number of sub cycles : 5 Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0522766, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0297192, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0953742, No Iterations 22 time step continuity errors : sum local = 1.66885, global = -0.318567, cumulative = -0.318567 smoothSolver: Solving for epsilon, Initial residual = 0.198029, Final residual = 0.00891435, No Iterations 3 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0434833, No Iterations 3 ExecutionTime = 0.314 s ClockTime = 0 s Time = 2 |
April 4, 2018, 09:53 |
Bruno Santos
Rep Power: 128 |
Greetings Bence,
OK, now I remember what might be making this problem. It's possible that you have at least 2 MPI libraries installed, where the one installed in your system is in conflict with the one that blueCFD-Core uses. If you run the following commands: Code:
where msmpi.dll where msmpi.dll | sed -e 's=\\=/=g' | xargs -I {} ls -l "{}" Code:
C:\Program Files\blueCFD-Core-2016\ThirdParty-4.x\platforms\mingw_w64Gcc\MS-MPI-7.1\bin\msmpi.dll C:\Windows\System32\msmpi.dll -rwxr-xr-x 1 Bruno Santos None 1300688 Jul 27 2016 C:/Program Files/blueCFD-Core-2016/ThirdParty-4.x/platforms/mingw_w64Gcc/MS-MPI-7.1/bin/msmpi.dll -rwxr-xr-x 1 Bruno Santos None 1300688 Jun 13 2016 C:/Windows/System32/msmpi.dll In your case, I suspect that the second one has a different size, implying that it's another version. The solution for this is explained on this FAQ: http://bluecfd.github.io/Core/FAQ/mp...y-the-dll-file - see section "Solution 1 - Simply copy the DLL file". If this doesn't solve the issue, then the other possibility is that the Windows Firewall might be getting in the way. Although this is a bit strange, because if that were the case, Windows should have complained about it and asked for permissions... On the other hand... I've tested just now to go through the same steps you've described, but I've gotten the following error message: Code:
ERROR: Failed RpcCliCreateContext error 1722 Aborting: mpiexec on MACHINE_NAME is unable to connect to the smpd service on machine_name:8677 Other MPI error, error stack: connect failed - The RPC server is unavailable. (errno 1722) Edit: OK, the problem was that I had an old "machines" file that was referencing a machine that isn't turned on, hence the problem. Please let me know if the descriptions above help and/or if you now get on this same error message. Best regards, Bruno
April 4, 2018, 11:02 |
Bence Somogyi
Rep Power: 17 |
Hello Bruno,
Thanks, copying the dll solved the issue! I have seen this FAQ, but it did not look relevant. Sorry about that! BR, Bence |
April 4, 2018, 11:30 |
Bruno Santos
Rep Power: 128 |
I'm very glad that solved the problem! I don't remember ever getting the symptom you had, which was why I wasn't at first thinking about it either.
I've created a report to document this situation sometime in the near future: https://github.com/blueCFD/Core/issues/95 |
December 3, 2018, 12:32 |
parallel compilation with BlueCFD-core 2017
#9 |
Alberto
Rep Power: 13 |
Hi Bruno, I have a question.
I have used the BlueCFD terminal to compile c++ code before (compile codes independently of OpenFOAM) using: Code:
c++ myCode.c Code:
mpic++ myParallelCode.c, mpicxx myParallelCode.c Thanks. |
December 4, 2018, 06:10 |
#10 |
Bruno Santos
Rep Power: 128 |
Quick answer:
app cd test/parallelMin wmake Code:
Making dependency list for source file Test-parallelMin.C $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath x86_64-w64-mingw32-g++) -std=c++11 -Dmingw_w64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DWIN64 -DLITTLE_ENDIAN -DWIN64 -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O2 -DNDEBUG -gdwarf -DNoRepository -ftemplate-depth-100 -D_FILE_OFFSET_BITS=64 -D_MODE_T_ -I/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/include @/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/applications/test/parallelMin/includeHeaderPaths -IlnInclude -I. -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OSspecific/MSwindows/lnInclude -c Test-parallelMin.C -o D:/DEVELO~1/Core/BLUECF~2/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/applications/test/parallelMin/Test-parallelMin.o In file included from Test-parallelMin.C:37:0: Test-parallelMin.C: In function 'int main(int, char**)': D:/DEVELO~1/Core/BLUECF~2/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/include/mpi.h:367:35: warning: use of old-style cast [-Wold-style-cast] #define MPI_COMM_WORLD ((MPI_Comm)0x44000000) ^ Test-parallelMin.C:44:17: note: in expansion of macro 'MPI_COMM_WORLD' MPI_Comm_size(MPI_COMM_WORLD, &numprocs); ^~~~~~~~~~~~~~ D:/DEVELO~1/Core/BLUECF~2/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/include/mpi.h:367:35: warning: use of old-style cast [-Wold-style-cast] #define MPI_COMM_WORLD ((MPI_Comm)0x44000000) ^ Test-parallelMin.C:45:17: note: in expansion of macro 'MPI_COMM_WORLD' MPI_Comm_rank(MPI_COMM_WORLD, &rank); ^~~~~~~~~~~~~~ $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath windres) /home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/applications/test/parallelMin/version_of_build.rc /home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/applications/test/parallelMin/version_of_build.o $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath x86_64-w64-mingw32-g++) -std=c++11 -Dmingw_w64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DWIN64 -DLITTLE_ENDIAN -DWIN64 -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O2 -DNDEBUG -gdwarf -DNoRepository -ftemplate-depth-100 -D_FILE_OFFSET_BITS=64 -D_MODE_T_ -I/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/include @/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/applications/test/parallelMin/includeHeaderPaths -IlnInclude -I. -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OSspecific/MSwindows/lnInclude -Wl,--enable-auto-import,--force-exe-suffix @/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/applications/test/parallelMin/objectList -L/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib \ -L/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/lib -lmpi \ -lm -o /home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin/Test-parallelMin_MSMPI71.exe /home/ofuser/blueCFD/ThirdParty-5.x/cv2pdb/cv2pdb.exe /home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin/Test-parallelMin_MSMPI71.exe || \ (strip --strip-unneeded /home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin/Test-parallelMin_MSMPI71.exe; \ /home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/infoCV2PDBworkaround) OK, pretty lengthy and hard to sift through, but here is the summary command you need, based on your example: Code:
g++ -I/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/include -L/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/lib myParallelCode.c -lmpi And yes, the "-lmpi" has to come last, so that the compiler knows the list of dependencies on a need basis.
December 5, 2018, 09:44 |
#11 |
Alberto
Rep Power: 13 |
It worked. I was able to compile and run my code in parallel from the BlueCFD-core's terminal.
Thanks Bruno. |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 17:38 |
User fortran error when running CFX-10 in parallel | CFDworker | CFX | 3 | September 22, 2015 09:59 |
[solidMechanics] Running contactStressFoam in Parallel | Hisham | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 2 | October 16, 2012 11:34 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
FEDORA CORE and PARALLEL processing | Tuks | CFX | 2 | August 20, 2005 12:05 |
