[OpenFOAM.org] problem installing ParaView with openFoam5
Like Tree2Likes
  • 2 Post By aerospain
Old   February 28, 2018, 07:03
Default problem installing ParaView with openFoam5
power
enginpower is on a distinguished road
Hello guys,
I've installed successfully openfoam5 (using this deb package found on this page) on Ubuntu 16.04 LTS.
I've tried some tutorials and all seems to work correctly.
But when I wanted to check some results, I got this:
paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
So I did:
engine@power:/opt/openfoam5/applications/utilities/postProcessing/graphics/PVReaders$ ./Allwclean
wclean libso vtkPVblockMesh
wclean libso vtkPVFoam
engine@power:/opt/openfoam5/applications/utilities/postProcessing/graphics/PVReaders$ ./Allwmake
Allwmake applications/utilities/postProcessing/graphics/PVReaders
    ERROR: ParaView not found in /opt/paraviewopenfoam54
So, how could I solve?
I found something similar to my issue here, but it doesn't work for me
enginpower is offline   Reply With Quote
Old   February 28, 2018, 18:15
Retired Super Moderator
Bruno Santos
Quick answer: If you use apt-get to install "openfoam5", then run:
sudo apt-get install paraviewopenfoam54
If you forcefully installed the "openfoam5" deb package, then you must do the same for the "paraviewopenfoam54" deb package.
Old   March 26, 2018, 11:23
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi wyldckat,
I've followed your suggestions for installing both softwares by "sudo apt-get install", and still not able to run paraFoam.
OpenFOAM works fine since I've been able to run "icoFoam -help" (standard check out command suggested everywhere)
ParaView can be run by launching the executable from within the directory where installed.
But, paraFoam not able to run due to environment variable not defined.
Message is:
>>> ./Allwclean
>>> ./Allwmake
Therefore, I try to build following the steps suggested. And, I get the following error message:
>>> ./Allwmake : PV_PLUGIN_PATH not valid - it is unset
Any suggestion?
Thanks
C.
aerospain is offline   Reply With Quote
Old   March 26, 2018, 11:34
aerospain
PROBLEM SOLVED!!!!!
Wyldckat, I found another thread where you suggested to check .bashrc file. I didn't comment out any lines, I just activated the appropriate environment. Now, paraFoam runs.
paraView reader module build problem
Regards!
C.
wyldckat and tonnykz like this.
installation of open foam, openfoam5, paraview
[General] Problem opening paraview (remote) alexvaleije ParaView 0 June 23, 2016 13:03
[OpenFOAM.org] paraview and python install problem laurent98 OpenFOAM Installation 16 December 13, 2014 16:12
ParaView Execute problem insta OpenFOAM Installation 2 June 9, 2014 03:37
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
[OpenFOAM] paraview split screen problem ziemowitzima ParaView 1 March 16, 2011 15:07
