[Other] $WM_PROJECT_DIR command
Like Tree2Likes
  • 2 Post By Lisandro Maders
Old   November 22, 2017, 13:14
Default $WM_PROJECT_DIR command
A. Min
alimea is on a distinguished road
Hi friend
I have a basic question!
what is the meaning of :
$WM_PROJECT_DIR
is it just for openFoam or this is a general command in linux?
why do we use $ in the start point of some addresses?
what is under lines between those words?
and finally, what is WM_PROJECT_DIR?
thanks
alimea is offline   Reply With Quote
Old   November 30, 2017, 23:17
Lisandro Maders
Lisandro Maders is on a distinguished road
Hi A.Min,
I suggest you to take a first look in this link before start using OpenFOAM: http://openfoamwiki.net/index.php/In...with_the_Shell
Regarding your question, when you are working with the shell in the Linux terminal, any $ is a environment variable. If you want to which is the return of this variable, you can use the command
echo $WM_PROJECT_DIR
and it should return, for this specific environment variable, a path to the installation directory of the current OpenFOAM sourced. This is an OpenFOAM environment variable. You should not have anything returned with the command above if you didn't source OpenFOAM yet.
The " _ " between the words is only to separate it instead of using spaces (because you can't).
Other OpenFOAM environment variables are $FOAM_RUN, $WM_PROJECT_USER_DIR, $FOAM_APP, $FOAM_SRC, ..
Good luck !
Regards,
Lisandro Maders
wyldckat and ZhangPikai like this.
Lisandro Maders is offline   Reply With Quote
command, linux
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
