[OpenFOAM.org] OpenFOAM v5 on ubuntu 14.04 - Problem with ParaFoam
Like Tree2Likes
  • 2 Post By lin
Old   October 30, 2017, 10:43
Default OpenFOAM v5 on ubuntu 14.04 - Problem with ParaFoam
giorgos
giorgos is on a distinguished road
Hello everybody,
I used to work with OpenFOAM in the past and now I am trying to install OpenFOAM v5 to make a fresh start with it. I am having a problem with paraFoam and I would be grateful if somebody can help me resolve it and be able to continue.
My linux distribution is Ubuntu 14.04
I followed the guidelines here:
https://openfoam.org/download/5-0-ubuntu/
The process goes well up until the "Getting started" section where a case of simpleFoam is to be run.
blockMesh and simpleFoam work well but paraFoam no. It gives the following message:
 ~/OpenFOAM/giorgos-5.0/run/pitzDaily paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
When following the instructions ./Allwclean runs well but for ./Allwmake I get the following error.
/opt/openfoam5/applications/utilities/postProcessing/graphics/PVReaders ./Allwmake
Allwmake applications/utilities/postProcessing/graphics/PVReaders
wmake vtkPVblockMesh
mkdir: cannot create directory ‘/opt/openfoam5/platforms/linux64GccDPInt32Opt/applications’: Permission denied
/bin/sh: 1: cannot create /opt/openfoam5/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/vtkPVblockMesh/options: Directory nonexistent
make: *** No rule to make target `/opt/openfoam5/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/vtkPVblockMesh/options'.  Stop.
make: *** No rule to make target `/opt/openfoam5/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/vtkPVblockMesh/options', needed by `all'.  Stop.
wmake error: file '/opt/openfoam5/platforms/linux64GccDPInt32Opt/applications/utilities/postProcessing/graphics/PVReaders/vtkPVblockMesh/sourceFiles' could not be created in /opt/openfoam5/applications/utilities/postProcessing/graphics/PVReaders/vtkPVblockMesh
When doing:
echo $PV_PLUGIN_PATH
I get this:
/opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/paraview-5.4
but this:
 ls -l /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/paraview-5.4
gives:
ls: cannot access /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/paraview-5.4: No such file or directory
Can anybody help me out with this issue?
Thanks a lot
Giorgos
giorgos is offline   Reply With Quote
Old   October 30, 2017, 21:45
lin
Hua Zen
lin is on a distinguished road
I remembered I have encountered this issue.
First, I vaguely remembered that I have to install newer cmake, please install cmake3 package .
Second, after source the openfoam environment, you should issue these commands with root account.
francescomarra and giorgos like this.
lin is offline   Reply With Quote
Old   October 31, 2017, 08:55
giorgos
Hello Lin,
thank you very much for your response!
As you said, I needed a new version of cmake.
Thanks a lot
openfoam v5.0, parafoam problem
[Other] Which versions of OpenFoam and Paraview are suitable for Ubuntu 14.04 LTS Trusty Tahr Asghari_M OpenFOAM Installation 4 February 4, 2015 16:47
[OpenFOAM.org] Installing OpenFOAM 2.3.x on Ubuntu 14.04 samiam1000 OpenFOAM Installation 4 January 26, 2015 03:44
[OpenFOAM] Problem running Paraview on Ubuntu 14.04 aminthefresh ParaView 0 November 4, 2014 13:34
[Other] Problem in Open foam installation in ubuntu 14.04 zannatul OpenFOAM Installation 2 November 3, 2014 21:56
How to Install Openfoam 2.2.2 in Ubuntu 14.04? satty_00 OpenFOAM Installation 7 May 18, 2014 11:04
