[OpenFOAM.org] openFoam 2.3.x install on Ubuntu 16.04 in windows 10
Like Tree1Likes
  • 1 Post By R.Mah
Old   October 19, 2017, 08:12
Default openFoam 2.3.x install on Ubuntu 16.04 in windows 10
Andy Grey
AndyBloke is on a distinguished road
I need to use 2.3.0 because it's the version which my university uses. *sigh*
On doing
sudo apt-get install openfoam230
i get
openfoam230 : Depends: libopenmpi1.3 but it is not installable
               Recommends: libptscotch-dev but it is not going to be installed
libopenmpi1.3 wont install because libopenmpi1.10 is already installed.
I figure I have to downgrade a lot of stuff but I'm having problems. Can anyone help?
AndyBloke is offline   Reply With Quote
Old   December 31, 2017, 13:11
Retired Super Moderator
Bruno Santos
Quick question: I'm really late to your request... have you solved this or do you still need to install OpenFOAM 2.3.0 on Ubuntu 16.04?
If you still do, have you tried the instructions made available at the following page for Ubuntu 14.10: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.10 ?
Old   April 7, 2018, 18:05
Default Errors in Installing OF.2.3.0 in ubuntu 16.04
Bah.Mah
R.Mah is on a distinguished road
Hello everyone.
I really need to install OF.2.3.0 in ubuntu 16.04, I followed the
Installation/Linux/OpenFOAM-2.3.0/Ubuntu
But I got so many errors while doing the making step, I have attached the make.log file.
Please any help and I will be so grateful.
Best regards
R.Mah is offline   Reply With Quote
Old   April 8, 2018, 14:51
Bruno Santos
Quick answer: I've started the instructions for OpenFOAM 2.3.0 on Ubuntu 16.04, although I haven't tested it yet. Please see this section: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04 - and continue following the instructions from step #11.
In other words, use the current state of your installation and try to continue it from there. Since you stopped midway, Don't forget to activate the OpenFOAM shell environment by running the following command on a new terminal window:
of230
Old   April 8, 2018, 18:39
Bah.Mah
Many thanks, it worked .
wyldckat likes this.
Old   April 8, 2018, 18:57
Bruno Santos
Excellent, that fixes that!
In case you need to use foamyHexMesh, I've finished testing/fixing the instructions for it as well: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
  • In step #3, I've added the "libcgal-dev" package.
  • There is a new step #7, for setting up the correct CGAL version.
  • In step #10 there is a fix for not building CGAL.
  • And as a side note, the old step #11 on my previous post is now #12.
[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 haydii OpenFOAM Installation 5 December 27, 2018 11:56
[OpenFOAM.org] OpenFOAM 3.0.1 from source in Ubuntu 16.04 jandrey OpenFOAM Installation 4 April 10, 2017 05:28
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 17:22
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
