[OpenFOAM.org] Problem for OF-dev on linuxMint 18.2 Sonya
Like Tree1Likes
  • 1 Post By wyldckat
Old   July 7, 2017, 17:23
Default Problem for OF-dev on linuxMint 18.2 Sonya
M. C.
student666 is on a distinguished road
it's first time I'm using Mint, but I thought it was quite straight forward to install, just like Ubuntu, but...
when I follow instruction at
https://openfoam.org/download/dev-ubuntu/
I got the following message when I try to install
Unable to locate package openfoam-dev
If I follow this instruction
https://openfoam.org/download/4-1-ubuntu/
I have no problem.
Why? What can I do?
I would like to have -dev branch
thanks
student666 is offline   Reply With Quote
Old   July 8, 2017, 21:15
Retired Super Moderator
Bruno Santos
Quick answer: Run the following commands:
echo "deb http://dl.openfoam.org/ubuntu xenial dev" | sudo tee -a /etc/apt/sources.list.d/openfoam.list
sudo sh -c "wget -O - http://dl.openfoam.org/gpg.key | apt-key add -"
sudo apt-get update
sudo apt-get -y install openfoam-dev
The reason is that Mint uses other names and therefore it doesn't have straight forward support. The trick shown above relies on adding the repository as if it were Ubuntu 16.04 "Xenial".
edit: I didn't notice before that it had worked for you to add the repository for OpenFOAM 4.1. Did you really use:
sudo add-apt-repository http://dl.openfoam.org/ubuntu
and it worked without problems?
If it did, I guess that the problem was the name of the sub-repository? Because the default is "main", but for OpenFOAM-dev, it needs to use the "dev" sub-repository...
Old   July 10, 2017, 07:34
M. C.
Thank you Bruno.
This lines
sudo apt-get update
worked for me, but no paraFoam have been installed.
I think any package for paraview have been downloaded.
Should I download apart and run
./Allwmake
inside?
/opt/openfoam-dev/applications/utilities/postProcessing/graphics/PVReaders
Old   July 10, 2017, 08:06
Bruno Santos
Quick answers:
Try running:
sudo apt-get install paraviewopenfoam50
If it fails to install, then you might need to also add the "main" repository:
echo "deb http://dl.openfoam.org/ubuntu xenial main" | sudo tee -a /etc/apt/sources.list.d/openfoam.main.list
sudo apt-get update
./Allwmake
inside?
Should not be necessary.
Old   July 10, 2017, 13:21
M. C.
Hi Bruno,
indeed it was suceffully with both instructions you provided, but then I had the same problem.
I looked for a solution on the web and I found an old post from yours.
ThirdParty-2.1.0 installation error
After
wmSet
which paraview
it started working, sorry to ask about, but what in the specific I did?!?
Thanks
Old   July 10, 2017, 18:30
Bruno Santos
After
wmSet
which paraview
Quick answer: It sort-of refreshed the environment. Essentially it did the usual command for loading/sourcing the OpenFOAM environment. You can check it by running:
alias wmSet
You can see all currently loaded aliases by running:
alias
If you're curious and want to learn more, see this wiki page: http://openfoamwiki.net/index.php/In...with_the_Shell
student666 likes this.
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem sultzan ANSYS Meshing & Geometry 0 December 13, 2018 18:41
Ansys 18.2 graphical problem centOS 7.5 rfmendes ANSYS 0 November 27, 2018 09:01
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 14:52
Problem diverges when exhaust valve opens swerner0711 AVL FIRE 0 September 21, 2018 08:14
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
