[OpenFOAM.com] [Windows] How to move/change the Working Folder to Another Drive?
Like Tree5Likes
  • 3 Post By pgh
  • 2 Post By pgh
Old   July 3, 2017, 10:08
Default [Windows] How to move/change the Working Folder to Another Drive?
LThomes is on a distinguished road
Greetings everyone,
I'm using OpenFOAM for Windows, and the current /home/ofuser/workingDir folder is shared with the C:/Users/myName folder. But now I have a SSD ( S: ). So I would like to run OpenFOAM inside this drive, that is, I would like to set S:/someFolder as the workingDir shared folder.
Could anybody help me?
Thanks in advance.
LThomes is offline   Reply With Quote
Old   July 3, 2017, 11:25
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Originally Posted by LThomes View Post
Greetings everyone,
Thanks in advance.
To access other drive , new scripts is needed and which will create a new container
I have provided a link below i.e at end to download tar file which has 4 files in it .
What you need to changed
i) Open the Virtual Machine and then close the default which is running
ii) Go to setting and add new drive which you want to share. As shown in attached image
i shared new drive E i.e e:\ to e/ folder in virtual box . Please do same with your drive
iii) Open the file of_start_container.ps1
and edit 4th line
docker-machine.exe ssh default "sudo mount -t vboxsf -o uid=1000,gid=50 e/ /root/../mountedDrive
(This is used by me . You need to replace e/ with your drive name (see attached image i.e for me e/ e:\ i.e e:\ is my directory which i mount)
Launching and creating container.
i) Click on the create_OF_plus.bat and it will create a new container
Close the terminal when process end
ii) Click on the startOF_plus . It will open container and now you can see two folder there
workingDir_mounted and workingDir . You need to use this script to launch openfoam .
You can click it multiple times and it will open the new terminal and you can work in multiple terminal with
openfoam environment set.
Download link:
https://ftpbox.esi-group.com/?u=fOb2...fv1612plus.tgz
Mojtaba.a, fondexx and LThomes like this.
pgh is offline   Reply With Quote
Old   July 4, 2017, 09:22
It worked just fine!!! Thank you very much pgh for always helping me!
P.S.: Is there any way I could run this in a terminal-like window (just like the original OpenFOAM_Start)? It's running in PowerShell, but I like the good old black background
Old   March 11, 2018, 07:56
Default File
Michael Pucher
MIchael_P is on a distinguished road
I would like to do a similar thing. Could one of you share with me scripts that were used?
Much appreciated!
Thanks,
Michael
MIchael_P is offline   Reply With Quote
Old   November 13, 2018, 04:40
Arvid Dujardin
arvid is on a distinguished road
Dear Pawan,
I have the same question as LThomes (or as in the posts of rudolf.hellmuth or garumple).
It seems none of the links to the zipped-files are accessible at this moment? Could you be so kind to provide, once again, a new link?
I understand you changed the settings in the Oracle VM VirtualBox Manager and you altered the of_start_container.ps1 file.
Since you renamed the create_OF and start_OF batch files, I suppose you altered these slightly in respect to the ones that come with the openFOAM for Windows installation?
Best regards,
Arvid
arvid is offline   Reply With Quote
Old   January 25, 2019, 14:52
pgh
Pawan Ghildiyal
Ok.. Sure. Here is script. I will upload it soon in openfoam.com website soon
https://ftpbox.esi-group.com/?u=xXst...pt_ofv1806.tgz
wyldckat and arvid like this.
change, drive, folder, ssd, workingdir
[OpenFOAM.com] [Windows] Error message "of_create_container.exe has stopped working" JohnMartinGodo OpenFOAM Installation 6 August 9, 2017 07:26
[OpenFOAM.com] v1612+ [Windows] How to change the workingDir shared folder? LThomes OpenFOAM Installation 4 May 22, 2017 09:16
[OpenFOAM.com] v1606+ Run Folder JSMOKA OpenFOAM Installation 5 December 18, 2016 20:47
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 03:01
