[OpenFOAM.org] icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 7, 2017, 03:45
Default icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10
Febriyan Prayoga
febriyan91 is on a distinguished road
Greetings.
I really need help to solve this problem.
My OS is Ubuntu 16.10.
GCC version is 6.2.0.
mpi version is 1.10.3.
uname -m is x86_64
I installed OpenFOAM 3.0.1 by following this guide https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04. I did not find the guidance for installing Openfoam 3.0.1 on Ubuntu 16.10 so i used this guidance.
I followed step by step of the process, but while i checked the "icoFoam -help" step, i got this message : "icoFoam: command not found". Then i open the log file, it show several report like these:
1. " ‘isnan’ was not declared in this scope
2. "/home/feb/OpenFOAM/OpenFOAM-3.0.1/wmake/rules/General/transform:8: recipe for target '/home/feb/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt64Opt/src/conversion/ensight/part/ensightPartIO.o' failed"
3. "make: *** [/home/feb/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt64Opt/src/conversion/ensight/part/ensightPartIO.o] Error 1"
i attached the gz log file.
I have searched about "isnan" problem that occured in my OF 3.0.1 installation cases and i found this link : https://github.com/xournalpp/xournalpp/issues/167
The link suggest to :
replace
#include <math.h>
with
#include <cmath>
replace all instances of
isnan
with
std:isnan
But i do not understand which file i should edit and i am new on Ubuntu and Openfoam. Or is there any more simple way to fix my OF installation problem.
Any help or clues will help me and i really appreciate it. I am sorry for gramatical errors, english is not my native language.
Thank you in advance
Last edited by febriyan91; June 7, 2017 at 06:21. Reason: i found additional information
febriyan91 is offline   Reply With Quote
Old   June 25, 2017, 14:34
Retired Super Moderator
Bruno Santos
Quick answer: This is already fixed in OpenFOAM 3.0.x, which is the bug fix version of the OpenFOAM 3.0 series. This issue was originally reported here: https://bugs.openfoam.org/view.php?id=2041
The fixes that you need to do are given in the following pages in detail:
febriyan91 likes this.
Old   July 27, 2020, 01:23
Febriyan Prayoga
Thank you very much.
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
[OpenFOAM.org] OpenFOAM 2.40 installation on Ubuntu 12.04 LTS eddykendo OpenFOAM Installation 1 July 18, 2015 18:38
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
