[OpenFOAM.org] Installing OpenFOAM-2.3.x
Like Tree1Likes
  • 1 Post By fertinaz
Old   May 3, 2017, 11:38
Default Installing OpenFOAM-2.3.x
Masoumeh Gharaati
mgharaati is on a distinguished road
Dear all
I 'm trying to instal OpenFOAM-2.3.x on Ubuntu 16 according to this link. "http://www.tfd.chalmers.se/~hani/wikis/haniWiki/index.php?title=Install_Ubuntu_14.04_LTS,_OpenFOAM-2.3.x,_foam-extend-3.1_etc._on_your_own_laptop&oldid=47 "
After entering the following command
./Allwmake
I faced to these errors. Would you please help me how I can solve this.
-lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lm -o /home/gharaati/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam
/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libtriSurface.so: undefined reference to `yyFlexLexer::yywrap()'
collect2: error: ld returned 1 exit status
/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/wmake/Makefile:149: recipe for target '/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam' failed
make[2]: *** [/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam] Error 1
make[2]: Leaving directory '/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/wmake/MakefileApps:39: recipe for target 'solidEquilibriumDisplacementFoam' failed
make[1]: *** [solidEquilibriumDisplacementFoam] Error 2
make[1]: Target 'application' not remade because of errors.
make[1]: Leaving directory '/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/applications/solvers/stressAnalysis'
/home/gharaati/OpenFOAM/OpenFOAM-2.3.x/wmake/MakefileApps:39: recipe for target 'stressAnalysis' failed
make: *** [stressAnalysis] Error 2
make: Target 'application' not remade because of errors.
Also. I 'm new with Ubuntu and openFOAM.
mgharaati is offline   Reply With Quote
Old   May 27, 2017, 07:57
Retired Super Moderator
Bruno Santos
Quick answer: To fix that problem, see this post: Problems installing OpenFOAM 2.4.0 on Fedora 23 - post #3
Old   June 2, 2017, 14:24
Masoumeh Gharaati
Thanks for your help.
Old   April 21, 2018, 13:05
Fatih Ertinaz
fertinaz is on a distinguished road
Hey there Bruno
Never mind. Running from scratch after a wclean all seems to solve the issues!
I am trying to install OF-2.4.0 on a GPU Cluster with Power 8 CPUs. OS is Ubuntu 16.04.
Allwmake fails at the exact same step as above mentioned, however since I applied your fix I don't have any undefined references to flex (currently using version 2.6.0).
I am wondering if you can make any suggestions. Please see log below:
+ wmake libso phaseCompressibleTurbulenceModels
make[2]: Entering directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/multiphase/twoPhaseEulerFoam/phaseCompressibleTurbulenceModels'
'/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libphaseCompressibleTurbulenceModels.so' is up to date.
make[2]: Leaving directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/multiphase/twoPhaseEulerFoam/phaseCompressibleTurbulenceModels'
+ wmake
make[2]: Entering directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/multiphase/twoPhaseEulerFoam'
g++ -m64 -mcpu=power8 -DlinuxPPC64le -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/$WM_PROJECT_DIR/src/transportModels/compressible/lnInclude -I/$WM_PROJECT_DIR/src/thermophysicalModels/basic/lnInclude -I/$WM_PROJECT_DIR/src/finiteVolume/lnInclude -I/$WM_PROJECT_DIR/src/transportModels/incompressible/lnInclude -I/$WM_PROJECT_DIR/src/TurbulenceModels/turbulenceModels/lnInclude -I/$WM_PROJECT_DIR/src/TurbulenceModels/compressible/lnInclude -I/$WM_PROJECT_DIR/src/TurbulenceModels/phaseCompressible/lnInclude -IphaseCompressibleTurbulenceModels/lnInclude -IinterfacialModels/lnInclude -ItwoPhaseSystem/lnInclude -I/$WM_PROJECT_DIR/src/finiteVolume/lnInclude -I/$WM_PROJECT_DIR/src/fvOptions/lnInclude -I/$WM_PROJECT_DIR/src/meshTools/lnInclude -I/$WM_PROJECT_DIR/src/sampling/lnInclude -IlnInclude -I. -I/$WM_PROJECT_DIR/src/OpenFOAM/lnInclude -I/$WM_PROJECT_DIR/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linuxPPC64leGccDPOpt/twoPhaseEulerFoam.o -L/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib \
     -lfluidThermophysicalModels -lspecie -lturbulenceModels -lcompressibleTurbulenceModels -lphaseCompressibleTurbulenceModels -lincompressibleTransportModels -lcompressibleTwoPhaseSystem -lcompressibleEulerianInterfacialModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lOpenFOAM -ldl   -lm -o /$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/bin/twoPhaseEulerFoam
/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libcompressibleTwoPhaseSystem.so: undefined reference to `Foam::TurbulenceModel<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::compressibleTurbulenceModel, Foam::phaseModel>::dictionaryConstructorTablePtr_'
/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libcompressibleTwoPhaseSystem.so: undefined reference to `Foam::turbulenceModel::propertiesName'
/$WM_PROJECT_DIR/wmake/Makefile:149: recipe for target '/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/bin/twoPhaseEulerFoam' failed
make[2]: *** [/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/bin/twoPhaseEulerFoam] Error 1
make[2]: Leaving directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/multiphase/twoPhaseEulerFoam'
/$WM_PROJECT_DIR/wmake/MakefileApps:39: recipe for target 'twoPhaseEulerFoam' failed
make[1]: *** [twoPhaseEulerFoam] Error 2
make[1]: Leaving directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/multiphase'
/$WM_PROJECT_DIR/wmake/MakefileApps:39: recipe for target 'multiphase' failed
make: *** [multiphase] Error 2
make[1]: Entering directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/stressAnalysis'
make[2]: Entering directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/stressAnalysis/solidDisplacementFoam'
make[2]: '/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/bin/solidDisplacementFoam' is up to date.
make[2]: Leaving directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/stressAnalysis/solidDisplacementFoam'
make[2]: Entering directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
make[2]: '/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/bin/solidEquilibriumDisplacementFoam' is up to date.
make[2]: Leaving directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
make[1]: Leaving directory '/gpfs/home/$WM_PROJECT_DIR/applications/solvers/stressAnalysis'
When I do a grep "undefined reference" to the log.Allwmake, I see that it starts with:
1395:Make/linuxPPC64leGccDPOpt/R.o:(.toc+0x1e8): undefined reference to `Foam::incompressible::turbulenceModel::typeName'
1396:Make/linuxPPC64leGccDPOpt/R.o:(.toc+0x200): undefined reference to `Foam::compressible::turbulenceModel::typeName'
1397:Make/linuxPPC64leGccDPOpt/R.o:(.toc+0x208): undefined reference to `typeinfo for Foam::compressible::turbulenceModel'
Then it basically cannot compile:
1843:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libSLGThermo.so: undefined reference to `Foam::solidMixtureProperties::New(Foam::dictionary const&)'
1858:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libDPMTurbulenceModels.so: undefined reference to `Foam::incompressibleTurbulenceModel::mu() const'
1859:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libDPMTurbulenceModels.so: undefined reference to `Foam::incompressibleTurbulenceModel::mut() const'
1860:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libDPMTurbulenceModels.so: undefined reference to `typeinfo for Foam::incompressibleTurbulenceModel'
1861:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libDPMTurbulenceModels.so: undefined reference to `Foam::incompressibleTurbulenceModel::mut(int) const'
1862:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libDPMTurbulenceModels.so: undefined reference to `Foam::incompressibleTurbulenceModel::muEff() const'
1863:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libDPMTurbulenceModels.so: undefined reference to `vtable for Foam::incompressibleTurbulenceModel'
This part repeats a number of times. Before Allwmake completely fails below is the final errors:
1995:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libSLGThermo.so: undefined reference to `Foam::solidMixtureProperties::New(Foam::dictionary const&)'
2023:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libinterfaceProperties.so: undefined reference to `typeinfo for Foam::alphaContactAngleFvPatchScalarField'
2024:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libinterfaceProperties.so: undefined reference to `Foam::alphaContactAngleFvPatchScalarField::typeName'
2033:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libinterfaceProperties.so: undefined reference to `typeinfo for Foam::alphaContactAngleFvPatchScalarField'
2034:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libinterfaceProperties.so: undefined reference to `Foam::alphaContactAngleFvPatchScalarField::typeName'
2146:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libcompressibleTwoPhaseSystem.so: undefined reference to `Foam::TurbulenceModel<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::compressibleTurbulenceModel, Foam::phaseModel>::dictionaryConstructorTablePtr_'
2147:/$WM_PROJECT_DIR/platforms/linuxPPC64leGccDPOpt/lib/libcompressibleTwoPhaseSystem.so: undefined reference to `Foam::turbulenceModel::propertiesName'
Thanks a lot.
wyldckat likes this.
fertinaz is offline   Reply With Quote
openfoam 2.3.x
[Other] Basic questions about OpenFOAM cluster running and installing Fauster OpenFOAM Installation 0 May 25, 2018 16:00
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 arieljeds OpenFOAM Installation 6 August 19, 2015 08:39
[OpenFOAM.org] -bash: fluentMeshToFoam: command not found, after installing OpenFoam 2.3.x on Mac jundong OpenFOAM Installation 1 July 1, 2015 14:31
