[OpenFOAM.com] ParaView installation fails on google compute engine |
March 16, 2017, 15:24 |
K Sai Sharath
Hello Foamers
I'm trying to setup OpenFOAM on google compute engine platform. I'm able to complete all the steps as per OpenFOAM website but the ./makeParaView stops right after the configuration and prints the following -- Configuring done -- Generating done -- Build files have been written to: /home/sai/OpenFOAM/ThirdParty-v1612+/build/linux64Gcc/ParaView-5.0.1 Starting make ./makeParaView: 407: ./makeParaView: time: not found the error itself isn't much descriptive so I'm having trouble trying to find a solution for this. to give more details I have python 2.7.9 cmake verion is 3.0.2 qt4( I ont have much idea about this but I've executed this "sudo apt-get install qt4-dev-tools libqt4-dev libqt4-opengl-dev freeglut3-dev libqtwebkit-dev " Any help would be much appreciated. |
March 25, 2017, 14:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: The application time is not installed in the Linux instance that you are using.
You either need to install that application or run the following commands to remove the call to that command: Code:
cd $WM_PROJECT_DIR sed -i -e 's=time ==' etc/tools/ParaViewFunctions
November 1, 2019, 04:31 |
Gerry Kan
Rep Power: 11 |
I have been looking for the solution for this on my system on and off for months. ParaView is finally compiling!
Thanks, Gerry. |
makeparaview, paraview |
[foam-extend.org] foam-extend 3.2 Paraview installation problem on Ubuntu 18.04 | ordinary | OpenFOAM Installation | 3 | September 1, 2018 22:01 |
[OpenFOAM.com] Ubuntu 16.04 OpenFOAM-v1706 ParaView Installation Error | kaszt | OpenFOAM Installation | 4 | August 25, 2017 18:01 |
[OpenFOAM] compute derivatives in Paraview | cfdsolver1 | ParaView | 1 | June 26, 2016 07:02 |
Paraview installation problem please help | mcjicpm2 | OpenFOAM Installation | 0 | March 9, 2009 06:55 |
Installation problems about Paraview and PV3foamreader | clark_liang | OpenFOAM Installation | 1 | January 12, 2009 06:05 |
