[OpenFOAM.org] Ubuntu 14.04 LTS OpenFoam 4.1 Installation Error
Like Tree1Likes
  • 1 Post By arsalan.dryi
Old   March 3, 2017, 15:27
Default Ubuntu 14.04 LTS OpenFoam 4.1 Installation Error
behzad Ghasemi
behzad-cfd is on a distinguished road
I was trying to compile OF-4.1 on Ubuntu 14.04. I compiled Third Party successfully but i got error while compiling OpenFoam.
(OF:4.1-Opt) behzad@behzad:/opt/OpenFOAM-4.1$ ./Allwmake
make: Nothing to be done for `all'.
Start ThirdParty Allwmake
Build MPI libraries if required
Build Scotch decomposition library scotch_6.0.3
    /opt/ThirdParty-4.1/platforms/linux64GccDPInt32/scotch_6.0.3
    scotch header in /opt/ThirdParty-4.1/platforms/linux64GccDPInt32/scotch_6.0.3/include
    scotch libs   in /opt/ThirdParty-4.1/platforms/linux64GccDPInt32/lib
Build PTScotch decomposition library scotch_6.0.3 (uses MPI)
    ptscotch header in /opt/ThirdParty-4.1/platforms/linux64GccDPInt32/scotch_6.0.3/include/openmpi-system
    ptscotch libs   in /opt/ThirdParty-4.1/platforms/linux64GccDPInt32/lib/openmpi-system
Build Metis decomposition
    optional component Metis was not found
Build CGAL
Using system installation of CGAL
Done ThirdParty Allwmake
+ wmakePrintBuild -check
no git description found
+ wrmo OpenFOAM/global/global.o
removing .o files corresponding to OpenFOAM/global/global.o ...
+ wmakeLnInclude OpenFOAM
+ wmakeLnInclude OSspecific/POSIX
+ Pstream/Allwmake libso
+ wmake libso dummy
/opt/OpenFOAM-4.1/src/Pstream/dummy
'/opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/dummy/libPstream.so' is up to date.
+ set +x
wmake libso mpi
/opt/OpenFOAM-4.1/src/Pstream/mpi
'/opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so' is up to date.
+ OSspecific/POSIX/Allwmake
/opt/OpenFOAM-4.1/src/OSspecific/POSIX
'/opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOSspecific.o' is up to date.
+ wmake libso OpenFOAM
/opt/OpenFOAM-4.1/src/OpenFOAM
sed -e 's!VERSION_STRING!4.1!' -e 's!BUILD_STRING!4.1!' global/global.Cver > /opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/src/OpenFOAM/global/global.Cver.C; g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/src/OpenFOAM -IlnInclude -I. -I/opt/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c /opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/src/OpenFOAM/global/global.Cver.C -o /opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/src/OpenFOAM/global/global.o
make: *** No rule to make target `/opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/src/OpenFOAM/matrices/lduMatrix/solvers/GAMG/GAMGAgglomerations/dummyAgglomeration/dummyAgglomeration.C.dep', needed by `/opt/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/src/OpenFOAM/matrices/lduMatrix/solvers/GAMG/GAMGAgglomerations/dummyAgglomeration/dummyAgglomeration.o'.  Stop.
make: *** Waiting for unfinished jobs....
whats wrong with that?
Regards,
behzad-cfd is offline   Reply With Quote
Old   March 4, 2017, 15:34
Arsalan
arsalan.dryi is on a distinguished road
Hi Behzad,
There is something wrong with your build directory. As a try, prefix your command with: "sudo", or try
sudo bash
this will put you as root, then run Allwmake.
behzad-cfd likes this.
arsalan.dryi is offline   Reply With Quote
Old   March 5, 2017, 03:44
behzad Ghasemi
Originally Posted by arsalan.dryi View Post
Hi Behzad,
sudo bash
Thanks for your kind reply. I installed with binary source pack
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
