[OpenFOAM.org] Problem installation OpenFOAM-dev |
November 25, 2016, 10:34 |
Jean bon
Rep Power: 10 |
I have several problems to install openfoam-dev. I have already installed several version of OpenFOAM (3, 4 and dev once). After a bug in openfoam-dev, I deleted it and I am trying to install the last version of openfoam-dev on a cluster (I have no root rights). I think it is worst than previous installations. I am following: https://openfoamwiki.net/index.php/I...OAM-dev/Ubuntu There are no problem until 11. For 12, this is the log.makeGcc: Code:
--------------- Already built: gmp-5.1.2 --------------- Already built: mpfr-3.1.2 --------------- Already built: mpc-1.0.1 ...... /work/salmon/ThirdParty-dev/gcc-4.8.5/gcc/lto-compress.c:28:18: fatal error: zlib.h: No such file or directory #include <zlib.h> ^ compilation terminated. Makefile:1059: recipe for target 'lto-compress.o' failed make[3]: *** [lto-compress.o] Error 1 make[3]: *** Waiting for unfinished jobs.... rm gcc.pod make[3]: Leaving directory '/work/salmon/ThirdParty-dev/build/linux64/gcc-4.8.5/gcc' Makefile:4156: recipe for target 'all-stage1-gcc' failed make[2]: *** [all-stage1-gcc] Error 2 make[2]: Leaving directory '/work/salmon/ThirdParty-dev/build/linux64/gcc-4.8.5' Makefile:18767: recipe for target 'stage1-bubble' failed make[1]: *** [stage1-bubble] Error 2 make[1]: Leaving directory '/work/salmon/ThirdParty-dev/build/linux64/gcc-4.8.5' Makefile:885: recipe for target 'all' failed make: *** [all] Error 2 Error building: gcc-4.8.5 Thanks. |
November 29, 2016, 17:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: If you don't have root rights, that make things a bit harder to build.
I've checked some old build scripts I've used and please try the following steps:
December 2, 2016, 05:18 |
Jean bon
Rep Power: 10 |
Thank you for your reply. I tried what you said but it did not work: Code:
checking where to find the target windmc... host tool checking whether to enable maintainer-specific portions of Makefiles... no configure: creating ./config.status config.status: creating Makefile + --disable-multilib MAKEINFO=missing ./makeGcc: line 295: --disable-multilib: command not found Error building: gcc-4.8.5 Thank you for your help anyway. |
December 2, 2016, 07:07 |
Bruno Santos
Rep Power: 128 |
Quick answer: One thing is the ZLib library that is ready to be used by all applications; another is having the header and library definitions file, which is what is missing.
In order for that error message to appear... I don't know what happened. I will have to try it out myself to try and reproduce it. Nonetheless, could you please provide the "makeGcc" file that you currently have? I ask this because something else might have changed in the file. |
December 2, 2016, 08:54 |
Jean bon
Rep Power: 10 |
Thanks for your quick reply.
I cannot attach the file so I paste it here: Code:
#!/bin/sh #------------------------------------------------------------------------------ # ========= | # \\ / F ield | OpenFOAM: The Open Source CFD Toolbox # \\ / O peration | # \\ / A nd | Copyright (C) 2011-2016 OpenFOAM Foundation # \\/ M anipulation | #------------------------------------------------------------------------------ # License # This file is part of OpenFOAM. # # OpenFOAM is free software: you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # OpenFOAM is distributed in the hope that it will be useful, but WITHOUT # ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or # FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License # along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. # # Script # makeGcc # # Description # Build script for gmp, mpfr and gcc-[4-9].?.? # #------------------------------------------------------------------------------ # get default GCC, mpfr, gmp and mpc versions . $WM_PROJECT_DIR/etc/config.sh/functions _foamSource $($WM_PROJECT_DIR/bin/foamEtcFile config.sh/compiler) gmpPACKAGE=${gmp_version:-gmp-5.1.2} mpfrPACKAGE=${mpfr_version:-mpfr-3.1.2} mpcPACKAGE=${mpc_version:-mpc-1.0.1} gccPACKAGE=$gcc_version #------------------------------------------------------------------------------ # Run from third-party directory only wmakeCheckPwd "$WM_THIRD_PARTY_DIR" || { echo "Error: Current directory is not \$WM_THIRD_PARTY_DIR" echo " The environment variables are inconsistent with the installation." echo " Check the OpenFOAM entries in your dot-files and source them." exit 1 } . etc/tools/ThirdPartyFunctions #------------------------------------------------------------------------------ usage() { exec 1>&2 while [ "$#" -ge 1 ]; do echo "$1"; shift; done cat<<USAGE usage: ${0##*/} [option] [gmp-VERSION] [mpfr-VERSION] [mpc-VERSION] <gcc-VERSION> options: -no-multilib for 64-bit systems that don't have 32-bit support -help * build combinations of gmp, mpfr, mpc and gcc $gmpPACKAGE $mpfrPACKAGE $mpcPACKAGE $gccPACKAGE USAGE exit 1 } GCC_BUILD_OPTIONS="" # Parse options while [ "$#" -gt 0 ] do case "$1" in -h | -help) usage ;; -no-multilib) GCC_BUILD_OPTIONS="--disable-multilib" shift ;; gmp-[4-9]*) gmpPACKAGE="${1%%/}" shift ;; mpfr-[2-9]*) mpfrPACKAGE="${1%%/}" shift ;; mpc-[0-9]*) mpcPACKAGE="${1%%/}" shift ;; gcc-[4-9]*) gccPACKAGE="${1%%/}" shift ;; *) usage "unknown option/argument: '$*'" ;; esac done if [ -z "$gccPACKAGE" ] then usage "Please specify gcc-VERSION" exit 1 fi # Set 32 or 64 bit ABI case "$WM_ARCH_OPTION" in 32 | 64) ABI=$WM_ARCH_OPTION ;; *) usage "Please set WM_ARCH_OPTION to either 32 or 64'$*'" ;; esac #------------------------------------------------------------------------------ # Build/install without compiler name buildBASE=$WM_THIRD_PARTY_DIR/build/$WM_ARCH$WM_COMPILER_ARCH installBASE=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH GCC_ARCH_PATH=$installBASE/$gccPACKAGE GMP_ARCH_PATH=$installBASE/$gmpPACKAGE MPFR_ARCH_PATH=$installBASE/$mpfrPACKAGE MPC_ARCH_PATH=$installBASE/$mpcPACKAGE # # Build GMP # echo "---------------" if [ -d $GMP_ARCH_PATH ] then echo "Already built: $gmpPACKAGE" else echo "Starting build: $gmpPACKAGE" echo ( sourceDIR=$WM_THIRD_PARTY_DIR/$gmpPACKAGE buildDIR=$buildBASE/$gmpPACKAGE cd $sourceDIR || exit 1 make distclean 2>/dev/null rm -rf $buildDIR mkdir -p $buildDIR cd $buildDIR set -x $sourceDIR/configure ABI=$ABI \ --prefix=$GMP_ARCH_PATH \ --libdir=$GMP_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --enable-cxx \ && make -j $WM_NCOMPPROCS \ && make install \ && echo "Built: $gmpPACKAGE" ) || { echo "Error building: $gmpPACKAGE" exit 1 } fi export LD_LIBRARY_PATH="$GMP_ARCH_PATH/lib:$LD_LIBRARY_PATH" # # Build MPFR # echo "---------------" if [ -d $MPFR_ARCH_PATH ] then echo "Already built: $mpfrPACKAGE" else echo "Starting build: $mpfrPACKAGE" echo ( sourceDIR=$WM_THIRD_PARTY_DIR/$mpfrPACKAGE buildDIR=$buildBASE/$mpfrPACKAGE cd $sourceDIR || exit 1 make distclean 2>/dev/null rm -rf $buildDIR mkdir -p $buildDIR cd $buildDIR set -x $sourceDIR/configure ABI=$ABI \ --prefix=$MPFR_ARCH_PATH \ --libdir=$MPFR_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --with-gmp-include=$GMP_ARCH_PATH/include \ --with-gmp-lib=$GMP_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ && make -j $WM_NCOMPPROCS \ && make install \ && echo "Built: $mpfrPACKAGE" ) || { echo "Error building: $mpfrPACKAGE" exit 1 } fi export LD_LIBRARY_PATH="$MPFR_ARCH_PATH/lib:$LD_LIBRARY_PATH" # # Build mpc # echo "---------------" if [ -d $MPC_ARCH_PATH ] then echo "Already built: $mpcPACKAGE" else echo "Starting build: $mpcPACKAGE" echo ( sourceDIR=$WM_THIRD_PARTY_DIR/$mpcPACKAGE buildDIR=$buildBASE/$mpcPACKAGE cd $sourceDIR || exit 1 make distclean 2>/dev/null rm -rf $buildDIR mkdir -p $buildDIR cd $buildDIR set -x $sourceDIR/configure ABI=$ABI \ --prefix=$MPC_ARCH_PATH \ --libdir=$MPC_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --with-gmp-include=$GMP_ARCH_PATH/include \ --with-gmp-lib=$GMP_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --with-mpfr-include=$MPFR_ARCH_PATH/include \ --with-mpfr-lib=$MPFR_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ && make -j $WM_NCOMPPROCS \ && make install \ && echo "Built: $mpcPACKAGE" ) || { echo "Error building: $mpcPACKAGE" exit 1 } fi if [ -d "$MPC_ARCH_PATH" ] then export LD_LIBRARY_PATH="$MPC_ARCH_PATH/lib:$LD_LIBRARY_PATH" fi # # Build GCC # might need 32-bit glibc-devel headers to compile # E.g. on ubuntu install g++-multilib # echo "---------------" if [ -d $GCC_ARCH_PATH ] then echo "Already built: $gccPACKAGE" else echo "Starting build: $gccPACKAGE" echo ( sourceDIR=$WM_THIRD_PARTY_DIR/$gccPACKAGE buildDIR=$buildBASE/$gccPACKAGE cd $sourceDIR || exit 1 make distclean 2>/dev/null rm -rf $buildDIR mkdir -p $buildDIR cd $buildDIR set -x $sourceDIR/configure \ --prefix=$GCC_ARCH_PATH \ --with-gmp-include=$GMP_ARCH_PATH/include \ --with-gmp-lib=$GMP_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --with-mpfr-include=$MPFR_ARCH_PATH/include \ --with-mpfr-lib=$MPFR_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --with-mpc-include=$MPC_ARCH_PATH/include \ --with-mpc-lib=$MPC_ARCH_PATH/lib$WM_COMPILER_LIB_ARCH \ --with-pkgversion=OpenFOAM \ --enable-languages=c,c++ \ --enable-__cxa_atexit \ --enable-libstdcxx-allocator=new \ --with-system-zlib \ $GCC_BUILD_OPTIONS \ MAKEINFO=missing \ && make -j $WM_NCOMPPROCS \ && make install \ && echo "Built: $gccPACKAGE" ) || { echo "Error building: $gccPACKAGE" exit 1 } fi #------------------------------------------------------------------------------ |
December 3, 2016, 17:29 |
Bruno Santos
Rep Power: 128 |
Greetings Fabien,
OK, you still have the original file. Please run the following commands: Code:
cd $WM_THIRD_PARTY_DIR sed -i -e 's=--with-system-zlib==' makeGcc ./makeGcc -no-multilib > log.makeGcc 2>&1 wmRefresh I've tested just now in Ubuntu 12.04 x86_64, without having the "zlib.h" header file in the system, and it worked without problems with this hack. Best regards, Bruno |
December 5, 2016, 05:11 |
Jean bon
Rep Power: 10 |
Thank you very much, it works, you are great !
However (yes sorry), I have a second error. For this one, perhaps you cannot do anything but I try, I am not sure. I have seen other messages on it but I have not seen any solutions that work for me. When I run "./makeParaView -python -mpi -python-lib /usr/lib/libpython2.7.so.1.0 > log.makePV 2>&1", I have a problem with Qmake: *** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH When I run locate qmake, I have a lot of paths, for example: /work/soft/qt/qt-everywhere-opensource-src-4.8.5/qmake/generators/win32/winmakefile.h So I tried to export this path in the .bashrc file: Code:
PATH=/work/soft/qt/qt-everywhere-opensource-src-4.8.5:$PATH export PATH Again thank you for your help. |
December 27, 2016, 12:48 |
Bruno Santos
Rep Power: 128 |
Quick answer: Sorry for the late reply. You can define the path to qmake directly in the command line, e.g.:
./makeParaView -qmake /work/soft/qt/qt-everywhere-opensource-src-4.8.5/bin/qmake -python -mpi -python-lib /usr/lib/libpython2.7.so.1.0 > log.makePV 2>&1 Code:
ls -l /work/soft/qt/qt-everywhere-opensource-src-4.8.5/bin/qmake find /work/soft/qt/qt-everywhere-opensource-src-4.8.5 -name qmake -type f |
January 3, 2017, 05:32 |
#9 |
Jean bon
Rep Power: 10 |
Thank you,
It works for qmake but there is an other error after. This is the end of the log.makePV: Code:
-- Looking for sqrt - not found -- Looking for strcasecmp -- Looking for strcasecmp - found -- Looking for strchr -- Looking for strchr - found -- Looking for strrchr -- Looking for strrchr - found -- Looking for strstr -- Looking for strstr - found -- Looking for strtol -- Looking for strtol - found -- Looking for strtoul -- Looking for strtoul - found -- Check size of int -- Check size of int - done -- Check size of long -- Check size of long - done CMake Error at /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48/cmake-3.2.1/share/cmake-3.2/Modules/FindPackageHandleStandardArgs.cmake:138 (message): Could NOT find OpenGL (missing: OPENGL_INCLUDE_DIR) Call Stack (most recent call first): /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48/cmake-3.2.1/share/cmake-3.2/Modules/FindPackageHandleStandardArgs.cmake:374 (_FPHSA_FAILURE_MESSAGE) /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48/cmake-3.2.1/share/cmake-3.2/Modules/FindOpenGL.cmake:168 (FIND_PACKAGE_HANDLE_STANDARD_ARGS) VTK/CMake/vtkOpenGL.cmake:63 (find_package) VTK/ThirdParty/glew/vtkglew/CMakeLists.txt:3 (include) -- Configuring incomplete, errors occurred! See also "/work/salmon/OpenFOAM/ThirdParty-dev/build/linux64Gcc48/ParaView-5.0.1/CMakeFiles/CMakeOutput.log". See also "/work/salmon/OpenFOAM/ThirdParty-dev/build/linux64Gcc48/ParaView-5.0.1/CMakeFiles/CMakeError.log". This is the log.make file (just the beginning, where the first error occurs): Code:
Compiling enabled on 4 cores Allwmake /work/salmon/OpenFOAM/OpenFOAM-dev make: Nothing to be done for 'all'. ======================================== Start ThirdParty Allwmake ======================================== ======================================== Build MPI libraries if required have OPENMPI shared library (openmpi-1.10.2) ======================================== Build Scotch decomposition library scotch_6.0.3 /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/scotch_6.0.3 + cd scotch_6.0.3/src + prefixDIR=/work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/scotch_6.0.3 + libDIR=/work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/lib + mkdir -p /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/scotch_6.0.3 + mkdir -p /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/lib + configOpt='prefix=/work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/scotch_6.0.3 libdir=/work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt32/lib' + '[' -f ../../etc/wmakeFiles/scotch/Makefile.inc.i686_pc_linux2.shlib-OpenFOAM ']' + rm -f Makefile.inc + ln -s ../../etc/wmakeFiles/scotch/Makefile.inc.i686_pc_linux2.shlib-OpenFOAM Makefile.inc + '[' -f Makefile.inc ']' + unset configEnv + '[' gcc '!=' gcc ']' + make realclean (cd libscotch ; make realclean) make[1]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/libscotch' rm -f *~ *.o lib*.so parser_yy.c parser_ly.h parser_ll.c *scotch.h *scotchf.h y.output *dummysizes make[1]: Leaving directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/libscotch' (cd scotch ; make realclean) make[1]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/scotch' rm -f *~ *.o acpl amk_ccc amk_fft2 amk_grf amk_hy amk_m2 amk_p2 atst gbase gcv *ggath *gmap gmk_hy gmk_m2 gmk_m3 gmk_msh gmk_ub2 gmtst *gord gotst gout *gpart *gscat *gtst mcv mmk_m2 mmk_m3 mord mtst make[1]: Leaving directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/scotch' (cd libscotchmetis ; make realclean) make[1]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/libscotchmetis' rm -f *~ *.o lib*.so make[1]: Leaving directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/libscotchmetis' (cd check ; make realclean) make[1]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/check' rm -f *~ *.o rm -f \ test_common_thread \ test_scotch_graph_color \ test_scotch_graph_map \ test_scotch_graph_order \ test_scotch_graph_part_ovl \ test_scotch_dgraph_band \ test_scotch_dgraph_check \ test_scotch_dgraph_coarsen \ test_scotch_dgraph_grow \ test_scotch_dgraph_redist \ test_strat_par \ test_strat_seq make[1]: Leaving directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/check' (cd esmumps ; make realclean) make[1]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/esmumps' rm -f *~ common.h *.o lib*.so main_esmumps make[1]: Leaving directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/esmumps' rm -f ../bin/* ../include/* ../lib/* + make -j 8 scotch (cd libscotch ; make VERSION=6 RELEASE=0 PATCHLEVEL=3 scotch && make install) make[1]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/libscotch' make CC="gcc" CCD="gcc" \ scotch.h \ scotchf.h \ libscotch.so \ libscotcherr.so \ libscotcherrexit.so make[2]: Entering directory '/work/salmon/OpenFOAM/ThirdParty-dev/scotch_6.0.3/src/libscotch' gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch.c -o arch.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_cmplt.c -o arch_cmplt.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_cmpltw.c -o arch_cmpltw.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_deco.c -o arch_deco.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_dist.c -o arch_dist.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_hcub.c -o arch_hcub.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_mesh.c -o arch_mesh.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_tleaf.c -o arch_tleaf.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_torus.c -o arch_torus.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_vcmplt.c -o arch_vcmplt.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c arch_vhcub.c -o arch_vhcub.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common.c -DSCOTCH_COMMON_RENAME -o common.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common_file.c -DSCOTCH_COMMON_RENAME -o common_file.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common_file_compress.c -DSCOTCH_COMMON_RENAME -o common_file_compress.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common_file_uncompress.c -DSCOTCH_COMMON_RENAME -o common_file_uncompress.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common_integer.c -DSCOTCH_COMMON_RENAME -o common_integer.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common_memory.c -DSCOTCH_COMMON_RENAME -o common_memory.o gcc -m64 -fPIC -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -shared -c common_string.c -DSCOTCH_COMMON_RENAME -o common_string.o common_file_compress.c:65:18: fatal error: zlib.h: No such file or directory #include "zlib.h" ^ common_file_uncompress.c:65:18: fatal error: zlib.h: No such file or directory #include "zlib.h" ^ compilation terminated. I wanted to try the same thing as you but I do not find any file where we need zlib. If you have an idea. Thank you for your help. Last edited by FlyingCat; January 4, 2017 at 11:26. |
January 11, 2017, 13:06 |
#10 |
Jean bon
Rep Power: 10 |
a little update. zlib has been installed and so I could follow the instrutions. For paraFoam, I cannot install it so far but I think I know why (an other library is not in the cluster). As regards OpenFOAM, I have trouble in the Allwmake. You can forgot the other errors in the other messages. This is the new error: Code:
wclean ptscotchDecomp wmake ptscotchDecomp wmake ptscotchDecomp wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file ptscotchDecomp.C g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -isystem /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48/openmpi-1.10.2/include -I/work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt64/scotch_6.0.3/include/openmpi-1.10.2 -I/work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48DPInt64/scotch_6.0.3/include -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/work/salmon/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/work/salmon/OpenFOAM/OpenFOAM-dev/src/OSspecific/POSIX/lnInclude -fPIC -c ptscotchDecomp.C -o /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt64OptOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o In file included from /opt/sgi/mpt/mpt-2.14/include/mpi.h:1816:0, from ptscotchDecomp.C:36: /opt/sgi/mpt/mpt-2.14/include/mpi++.h:416:6: error: declaration of C function ‘void PMPI::Init()’ conflicts with Init(); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:413:1: error: previous declaration ‘void PMPI::Init(int&, char**&)’ here Init(int& argc, char**& argv); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:440:12: error: declaration of C function ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:433:1: error: previous declaration ‘void PMPI::Register_datarep(const char*, void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:445:12: error: declaration of C function ‘void PMPI::Register_datarep(const char*, void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:438:1: error: previous declaration ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ here Register_datarep(const char *, MPI_Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:445:12: error: declaration of C function ‘void PMPI::Register_datarep(const char*, void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:433:1: error: previous declaration ‘void PMPI::Register_datarep(const char*, void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:450:12: error: declaration of C function ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:443:1: error: previous declaration ‘void PMPI::Register_datarep(const char*, void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:450:12: error: declaration of C function ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:438:1: error: previous declaration ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ here Register_datarep(const char *, MPI_Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:450:12: error: declaration of C function ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:433:1: error: previous declaration ‘void PMPI::Register_datarep(const char*, void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(void*, PMPI::Datatype&, int, void*, PMPI::Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:899:7: warning: ‘class PMPI::Comm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Comm : public Comm_Null { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1184:7: warning: ‘class PMPI::Intracomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Intracomm : public Comm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1220:7: warning: ‘class PMPI::Cartcomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Cartcomm : public Intracomm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1269:7: warning: ‘class PMPI::Graphcomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Graphcomm : public Intracomm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1313:7: warning: ‘class PMPI::Intercomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Intercomm : public Comm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1642:29: warning: declaration of ‘void MPI::Init(int&, char**&)’ with C language linkage [enabled by default] Init(int& argc, char**& argv); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:416:1: warning: conflicts with previous declaration ‘void PMPI::Init()’ [enabled by default] Init(); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1645:6: error: declaration of C function ‘void MPI::Init()’ conflicts with Init(); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1642:1: error: previous declaration ‘void MPI::Init(int&, char**&)’ here Init(int& argc, char**& argv); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1651:54: error: declaration of C function ‘int MPI::Init_thread(int&, char**&, int)’ conflicts with int Init_thread(int& argc, char**& argv, int required); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1650:5: error: previous declaration ‘int MPI::Init_thread(int)’ here int Init_thread(int); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1684:12: warning: declaration of ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ with C language linkage [enabled by default] void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:448:1: warning: conflicts with previous declaration ‘void PMPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const PMPI::Datatype&, PMPI::Aint&, void*), void*)’ [enabled by default] Register_datarep(const char *, MPI_Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1688:12: error: declaration of C function ‘void MPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1682:1: error: previous declaration ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1692:12: error: declaration of C function ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1686:1: error: previous declaration ‘void MPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ here Register_datarep(const char *, MPI_Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1692:12: error: declaration of C function ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1682:1: error: previous declaration ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1696:12: error: declaration of C function ‘void MPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1690:1: error: previous declaration ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1696:12: error: declaration of C function ‘void MPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1686:1: error: previous declaration ‘void MPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ here Register_datarep(const char *, MPI_Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1696:12: error: declaration of C function ‘void MPI::Register_datarep(const char*, int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), int (*)(void*, MPI_Datatype, int, void*, MPI_Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ conflicts with void *); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1682:1: error: previous declaration ‘void MPI::Register_datarep(const char*, void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(void*, MPI::Datatype&, int, void*, MPI::Offset, void*), void (*)(const MPI::Datatype&, MPI::Aint&, void*), void*)’ here Register_datarep(const char *, Datarep_conversion_function *, ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:2734:7: warning: ‘class MPI::Comm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Comm : public Comm_Null { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:3245:7: warning: ‘class MPI::Intracomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Intracomm : public Comm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:3448:7: warning: ‘class MPI::Cartcomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Cartcomm : public Intracomm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:3529:7: warning: ‘class MPI::Graphcomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Graphcomm : public Intracomm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:3607:7: warning: ‘class MPI::Intercomm’ has virtual functions and accessible non-virtual destructor [-Wnon-virtual-dtor] class Intercomm : public Comm { ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h: In function ‘void PMPI::Init(int&, char**&)’: /opt/sgi/mpt/mpt-2.14/include/mpi++.h:4102:41: warning: declaration of ‘void PMPI::Init(int&, char**&)’ with C language linkage [enabled by default] _REAL_MPI_::Init(int& argc, char**& argv) ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:1645:1: warning: conflicts with previous declaration ‘void MPI::Init()’ [enabled by default] Init(); ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:4102:41: error: declaration of C function ‘void PMPI::Init(int&, char**&)’ conflicts with _REAL_MPI_::Init(int& argc, char**& argv) ^ /opt/sgi/mpt/mpt-2.14/include/mpi++.h:416:1: error: previous declaration ‘void PMPI::Init()’ here Init(); ^ /work/salmon/OpenFOAM/OpenFOAM-dev/wmake/rules/General/transform:25: recipe for target '/work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt64OptOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o' failed make: *** [/work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt64OptOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o] Error 1 Thank you for your help. |
January 13, 2017, 06:51 |
#11 |
Jean bon
Rep Power: 10 |
I succeeded to avoid this error thanks to a modification: I move "#include <mphi.h>" from extern "C" to the rest of include in the file src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.C
Now, I have an other error, I think there is a link with the first. When I try to compile solvers, I cannot (this is the same message for each solver): Code:
/work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `op_intercept(void*, void*, int*, unsigned int*)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `PMPI::Request::ignored_status' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `mpi_sgi_status_ignore' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `MPI::Op::Is_commutative() const' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `MPI::Op::Init(void (*)(void const*, void*, int, MPI::Datatype const&), bool)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `PMPI::Comm::mpi_comm_map' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `MPI::Is_initialized()' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `MPI::Op::Reduce_local(void const*, void*, int, MPI::Datatype const&) const' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `MPI::Op::Free()' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/openmpi-1.10.2/libPstream.so: undefined reference to `PMPI::Comm::ignored_status' |
January 13, 2017, 09:46 |
#12 |
Jean bon
Rep Power: 10 |
Update:
-lfiniteVolume -lfvOptions -lcompressibleTransportModels -lfluidThermophysicalModels -lspecie -lrhoCentralFoam -lturbulenceModels -lcompressibleTurbulenceModels -lmeshTools -lOpenFOAM -ldl \ -lm -o /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/bin/rhoCentralFoam /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64/gcc-4.8.5/lib/gcc/x86_64-unknown-linux-gnu/4.8.5/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libtriSurface.so, needed by /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libfiniteVolume.so, not found (try using -rpath or -rpath-link) /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64/gcc-4.8.5/lib/gcc/x86_64-unknown-linux-gnu/4.8.5/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libsurfMesh.so, needed by /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so, not found (try using -rpath or -rpath-link) /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64/gcc-4.8.5/lib/gcc/x86_64-unknown-linux-gnu/4.8.5/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libfileFormats.so, needed by /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so, not found (try using -rpath or -rpath-link) /work/salmon/OpenFOAM/ThirdParty-dev/platforms/linux64/gcc-4.8.5/lib/gcc/x86_64-unknown-linux-gnu/4.8.5/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libPstream.so, needed by /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so, not found (try using -rpath or -rpath-link) Code:
/work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::OBJstream::write(Foam::line<Foam::Vector<double>, Foam::Vector<double> const&> const&)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::fileName const&)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so: undefined reference to `Foam::reduce(Foam::Vector2D<double>&, Foam::sumOp<Foam::Vector2D<double> > const&, int, int)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::OBJstream::~OBJstream()' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::freePstreamCommunicator(int)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface()' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libfiniteVolume.so: undefined reference to `Foam::UPstream::finishedRequest(int)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::scalePoints(double)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::OBJstream::write(Foam::Vector<double> const&)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::fileName const&)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::abort()' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::geometricSurfacePatch::operator==(Foam::geometricSurfacePatch const&) const' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::subsetMesh(Foam::List<bool> const&, Foam::List<int>&, Foam::List<int>&) const' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::resetRequests(int)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::allocatePstreamCommunicator(int, int)' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::edgeOwner() const' /work/salmon/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt32Opt/lib/libmeshTools.so: undefined reference to `Foam::OBJstream::OBJstream(Foam::fileName const&, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, EDIT: Ok now I have again the previous error. I will kill myself. Last edited by FlyingCat; January 13, 2017 at 12:21. |
January 16, 2017, 08:56 |
#13 |
Jean bon
Rep Power: 10 |
I solved the problem by
export WM_MPLIB=SYSTEMOPENMPI I do not know what was the problem, but this command solved it. If a more competent person could explain, it would be useful for everybody I think. |
October 2, 2017, 18:25 |
#14 | |
Rep Power: 10 |
I found where the errors appear and it is stating that it cannot find libtrisurface.so (needed by linux64GccDPInt64Debug/lib/libfiniteVoluem.so, not found |
October 3, 2017, 04:31 |
#15 |
Jean bon
Rep Power: 10 |
You need to write this in the terminal before compiling. However, perhaps it is not your problem, you should give more information about it. Moreover, I do not know if you copied and pasted "linux64GccDPInt64Debug/lib/libfiniteVoluem.so" but it is written "Voluem". If you copied and pasted, you had to change something in files. |
December 31, 2017, 12:53 |
#16 |
Bruno Santos
Rep Power: 128 |
Quick answer: You can edit the file "OpenFOAM*/etc/bashrc" and change the value for "WM_MPLIB".
[swak4Foam] swak4foam 0.3.2 installation problem on Ubuntu 15.04 with OpenFOAM 2.4.0 | ptsxx | OpenFOAM Community Contributions | 1 | January 10, 2016 18:48 |
[OpenFOAM.org] OpenFOAM 2.3.1: installation problem with ParaView 4.1.0 | hjw | OpenFOAM Installation | 5 | November 17, 2015 22:14 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 02:40 |
