[OpenFOAM.org] 2.4.0: Error in the building of ParaView 4.1.0
Like Tree4Likes
  • 2 Post By rdbisme
  • 1 Post By alexeym
  • 1 Post By wyldckat
Old   November 15, 2016, 08:35
Default 2.4.0: Error in the building of ParaView 4.1.0
Alessandro
a_soli is on a distinguished road
Dear all,
I am absolute OpenFOAM novice and my Linux skills are not great either. I need to install OpenFOAM 2.4.0 on Ubuntu 16.10 and I followed step-by-step this guide thought for Ubuntu 16.04:
https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
Now, everything is fine, until point 10.3 where I experienced some issues while building ParaView. OpenFOAM itself works just fine, as I could see from the execution of the "Lid-driven cavity" tutorial. Can someone help me? I am attaching the log.makePV
P.S. : I wasn't sure if this should have been posted here or in the ParaView section.
a_soli is offline   Reply With Quote
Old   November 15, 2016, 13:52
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Originally Posted by a_soli View Post
Dear all,
I think this is related to using Gcc6.
I'm not a cmake expert but in VTK/CMake/GenerateExportHeader.cmake cmake seems to check only for GCC versions up to 5.
    string(REGEX MATCH "[345]\\.[0-9]\\.[0-9]"
      _gcc_version "${_gcc_version_info}")
    # gcc on mac just reports: "gcc (GCC) 3.3 20030304 ..." without the
    # patch level, handle this here:
    if(NOT _gcc_version)
      string(REGEX REPLACE ".*\\(GCC\\).* ([34]\\.[0-9]) .*" "\\1.0"
    endif()
Try to use a lower gcc version (e.g. 4.8.2).
http://askubuntu.com/questions/26498...-and-g-version
wyldckat and a_soli like this.
rdbisme is offline   Reply With Quote
Old   November 16, 2016, 08:37
Alessandro
Thanks tidusuper91, I installed gcc and g++ 4.7 and I can now launch paraFoam
Old   November 29, 2016, 13:47
Default Problems building OpenFOAM 2.4.0 on Ubuntu 16.10
Giuse
UDS_rambler is on a distinguished road
Hello Everybody,
I have installed OpenFoam 2.4 to run on a VirtualBox Ubuntu 16.10 machine. I compiled everything and testing icoFoam -help I did not get any error message, so I figured out that I compiled it properly.
Nevertheless, when I used HelyxOS, using simpleFoam solver, I realized that I did not complete the compiling, and some of the solvers work, some other does not.
I attach here the log file, maybe someone has an idea of what is wrong?
Thank you in advance,
Giuseppe
UDS_rambler is offline   Reply With Quote
Old   November 29, 2016, 17:18
Retired Super Moderator
Bruno Santos
Greetings to all!
I've moved Giuseppe's post to this thread, because it's related to the same issue: Building OpenFOAM 2.4.0 in Ubuntu 16.10.
@Giuseppe: The problem is that GCC 6 is not fully supported to be used for building OpenFOAM 2.4.0. Specifically, the error was this:
ensight/part/ensightPart.C: In member function ‘bool Foam::ensightPart::isFieldDefined(const Foam::List<double>&) const’:
ensight/part/ensightPart.C:54:54: error: ‘isnan’ was not declared in this scope
             if (id >= field.size() || isnan(field[id]))
In order to fix this, you will need to one of the changes mentioned here: http://bugs.openfoam.org/view.php?id=2041
I'll try to have instructions on the wiki later this week.
Best regards,
Bruno
Old   November 30, 2016, 12:13
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
In fact ::isnan problem is just a beginning of troubles with GCC 6 and OpenFOAM 2.4.x.
Then user will encounter troubles with optimisation of reference address comparison with NULL (it is assumed as always true) and all ifs bodies in, for example, polyMesh.C like:
    if (&points)
        points_.transfer(points());
        bounds_ = boundBox(points_, validBoundary);
are executed unconditionally, and it leads to rather funny things (sometimes solver runs, sometimes solver crashes). When this behaviour has reported for clang, bug was closed with comment "to much work to fix it in 2.4.x, fixed in 3.0 with nullObject".
IIRC after adding nullObject to 2.4.x and changing all "&points"-like code to "notNull(points)"-like, it was possible to get stable running build.
wyldckat likes this.
alexeym is offline   Reply With Quote
Old   December 3, 2016, 22:27
Bruno Santos
Greetings to all!
Step-by-step instructions on how to build OpenFOAM 2.4.0 in Ubuntu 16.10 are now available here: http://openfoamwiki.net/index.php/In...u#Ubuntu_16.10
Many thanks Alexey! I suspected there were more issues, but I was hoping that the other fix would be enough. I've also updated the http://openfoamwiki.net/index.php/In...ibility_Matrix wiki page accordingly, by placing a reference link to your post.
From what I could find, the closest related report and commits to what you're referring to are as follows:
The commit seems to be the closest to your description, because the bug report is a lot more recent.
As for:
Unfortunately there is no funding dedicated to maintaining the previous releases (at least as far as I know of), if there is a current release already under maintenance. And since this was a major change, it would need to go through the test/tutorial loop... which takes time to run and check
Best regards,
Bruno
a_soli likes this.
Old   December 5, 2016, 04:20
Alexey Matveichev
And this is a consequence of no strictly (or at least somehow) defined release life cycle.
Surely one can always check commit activity on github; yet, for example, can we assume 3.0.x as dead since the last commit (https://github.com/OpenFOAM/OpenFOAM...ee3b73b0f308e4) in that branch was in August (and quite bizarre commit - fixes are for 3.0.x, version in header comment is 4.x)?
Old   December 22, 2016, 14:30
Bruno Santos
Quick answer (although somewhat late):
Sorry, mea culpa on that commit. This was because there was a weird issue between OpenFOAM 3.0.x and 4.x, reported here: https://bugs.openfoam.org/view.php?id=2179 - so the commit was a direct copy of the script files in 4.x to 3.0.x, for fixing the typo in said scripts.
Nonetheless, the commit before last was also bit strange as well... although it was to make things a bit more consistent between the versions available back then, I guess...
Either way, long term support is something I'm still yet to see to be done by any provider of OpenFOAM versions/forks.
building, openfoam 2.4.0 help, paraview 4.1.0
[General] Building Paraview 4.1.0 with MPI and Python support reynoldsStress ParaView 10 July 27, 2017 09:38
[OpenFOAM.org] Building problem with Paraview 4.1.0 on Ubuntu 16.04 nigala OpenFOAM Installation 2 June 20, 2016 11:18
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
ParaView 3.8.0 problem on debian Unseen OpenFOAM Installation 4 August 16, 2010 11:26
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
