October 21, 2016, 12:26 |
OpenFOAM 4.1 on Fedora 24
Jon Elvar Wallevik
Rep Power: 20 |
Hi foamers,
I just finished installing OpenFOAM 4.1 on Fedora 24. Now it is easier than before Really, I just followed the homepage without modifications (more or less). If you are lazy, and just want to copy paste then you have it below. Hope this helps. J. sudo dnf groupinstall 'Development Tools' sudo dnf groupinstall 'C Development Tools and Libraries' sudo dnf install openmpi openmpi-devel qt-devel qt-webkit-devel zlib-devel cmake wget boost-devel gmp-devel mpfr-devel patch readline-devel ncurses-devel python python-devel sudo dnf install git gitk sudo dnf install openmpi-devel qt-devel qtwebkit-devel zlib-devel cmake sudo dnf install openmpi openmpi-devel qt-devel qt-webkit-devel zlib-devel cmake wget git gitk sudo dnf install boost-devel gmp-devel mpfr-devel patch readline-devel ncurses-devel python python-devel sudo dnf install CGAL CGAL-devel binutils-devel mercurial sudo dnf install compat-gcc-34-g77 sudo dnf install freeglut freeglut-devel flex bison cmake zlib zlib-devel boost-thread boost-system boost-devel libXt-devel libXt scotch scotch-devel qt5-qtwebkit-devel sudo dnf install qtwebkit qtwebkit-devel CGAL CGAL-devel openmpi openmpi-devel sudo dnf install zlib zlib-devel boost boost-math boost-thread boost-system boost-devel openmpi openmpi-devel readline readline-devel ncurses-devel ncurses-libs ncurses libXt libXt-devel sudo dnf install scotch scotch-devel ptscotch-openmpi ptscotch-openmpi-devel ptscotch-openmpi-devel-parmetis sudo dnf install metis metis-devel fftw ---------------------------------------------------------- cd cd OpenFOAM wget -O - http://dl.openfoam.org/source/4-1 | tar xvz wget -O - http://dl.openfoam.org/third-party/4-1 | tar xvz ---------------------------------------------------------- mv OpenFOAM-4.x-version-4.1 OpenFOAM-4.1 mv ThirdParty-4.x-version-4.1 ThirdParty-4.1 ---------------------------------------------------------- in your ~/.bashrc alias of41="export PATH=/usr/lib64/openmpi/bin/:$PATH && export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH && source $HOME/OpenFOAM/OpenFOAM-4.1/etc/bashrc && PS1='\[\e[1;31m\][4.1]\[\e[0m\]\[\e[1;32m\][$(tty | cut -d/ -f3,4)]\[\e[0m\][\W]\[\e[1;31m\]:\[\e[0m\] ' " ---------------------------------------------------------- if you havent done so already.... cd /usr/bin sudo ln -s qmake-qt5 qmake ---------------------------------------------------------- New terminal and type "of41" cd $WM_THIRD_PARTY_DIR ./Allwmake ---------------------------------------------------------- New terminal and type "of41" cd $WM_THIRD_PARTY_DIR ./makeParaView ---------------------------------------------------------- New terminal and type "of41" foam ./Allwmake -j ---------------------------------------------------------- New terminal and type "of41" foam ./Allwmake 2>&1 | tee wmake_log_file.txt (you can check wmake_log_file.txt if there are any errors) ---------------------------------------------------------- |
January 20, 2017, 18:26 |
worked like a charm for me on my recently upgraded fedora 24, many thanks, Talder
#2 | |
Tom Alderweireldt
Rep Power: 11 |
Talder |
April 15, 2017, 08:51 |
Chris Pounds
Rep Power: 11 |
Does anyone know if these instructions are current for Fedora 25?
April 15, 2017, 09:02 |
Tom Alderweireldt
Rep Power: 11 |
Hi, I did not reinstall or recompile for Fedora 25, but I have done an online upgrade from Fedora 24 to Fedora 25 and found out OpenFoam 4.1 still works.
April 18, 2017, 09:44 |
Jon Elvar Wallevik
Rep Power: 20 |
In fedora 24, I tarballed my OpenFOAM directory (i.e. "tar czf of.tgz OpenFOAM" in ~). Thereafter I did a completely fresh install for f25.
After extracting the tarball "tar xzf of.tgz" in f25, no problems so far (of course after doing the dnf install stuff mentioned above). |
November 10, 2017, 09:57 |
On Fedora 26 works also very well!
Stanislav Knotek
Rep Power: 13 |
On Fedora 26 it works also well. Only needed to fix bugs using
Paraview installation on scientific linux?? and https://www.cfd-online.com/Forums/op...dora-24-a.html where simply [34567] was used. |
[OpenFOAM.org] OpenFOAM 2.4.0 and Fedora 22: error building CGAL | macelee | OpenFOAM Installation | 4 | April 2, 2016 23:01 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 10:38 |
Qt installation in Fedora for OpenFOAM......Required Urgently...... | devesh.baghel | OpenFOAM | 1 | November 17, 2009 10:08 |
