[OpenFOAM.org] Unable to add openfoam 4 source repo location on Linux Mint 18 |
July 5, 2016, 00:24 |
Ash
FIXED: I changed
sudo add-apt-repository http://download.openfoam.org/ubuntu Code:
sudo add-apt-repository deb http://download.openfoam.org/ubuntu xenial main I am using linux mint 18 and I am trying to add the openfoam source repo to my sources repository list but I am unable to do so! I have tried adding it via the cli and the software manager interface and nothing has happened. and when I add the http://download.openfoam.org/ubuntu manually to sources.list, apt refuses to update claiming a malformed line error. Code:
sudo apt-get update E: Malformed line 2 in source list /etc/apt/sources.list (type) E: The list of sources could not be read. Last edited by aran; July 5, 2016 at 19:02. Reason: Added extra details. FIXED |
September 9, 2016, 10:37 |
edison
Rep Power: 17 |
How did you managed to get the repositories? I have linux mint as well but can't install OpenFOAM 4.0. Did you manged installing it using the ubuntu repo?
September 9, 2016, 10:45 |
Ash
Hey Edison,
I was using linux mint 18 and I couldn't get it to work with whatever instructions were given on the CFD.Direct site. So I installed openfoam 4 on ubuntu xenial and checked the sources list. I then used that entry in the ubuntu sources list for the linux mint sources list. This is the command I ran in Linux mint 18:- Code:
sudo add-apt-repository deb http://download.openfoam.org/ubuntu xenial main |
September 9, 2016, 18:43 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick note: Regarding the key error, the fix for it is in the official installation instructions: http://openfoam.org/download/4-0-ubuntu/ - and I quote:
September 12, 2016, 05:42 |
#5 | |
edison
Rep Power: 17 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
