June 5, 2016, 07:02 |
ThirdParty-3.0.x
Tobias Holzmann
Rep Power: 52 |
Dear all,
compiling OpenFoam-3.0.x lead to a problem with ptScotch. The first error: Code:
Build Scotch decomposition library scotch_6.0.3 /home/shorty/OpenFOAM/ThirdParty-3.0.x/platforms/linux64GccInt32/scotch_6.0.3 + cd scotch_6.0.3/src /home/shorty/OpenFOAM/ThirdParty-3.0.x/Allwmake: 203: cd: can't cd to scotch_6.0.3/src + exit 1 Code:
could not open file ptscotch.h for source file ptscotchDecomp.C due to No such file or directory g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -mtune=bdver1 -march=bdver1 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread -I/include -I/home/shorty/OpenFOAM/ThirdParty-3.0.x/platforms/linux64GccInt32/scotch_6.0.3/include/openmpi-system -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/shorty/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/home/shorty/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude -fPIC -c ptscotchDecomp.C -o /home/shorty/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o ptscotchDecomp.C:126:26: fatal error: ptscotch.h: No such file or directory #include "ptscotch.h" ^ So I just want to ask why it is like that? Finally I decided to compile the development repository. I am not sure if there is just something wrong with the initialization of the repository. Hence, I just wanted to report this and inform other people who are not so familiar with the compiling procedure.
Keep foaming, Tobias Holzmann |
June 17, 2016, 10:34 |
mohsen ari.
Rep Power: 13 |
Hi Tobias,
I have the same problem installing that on Centos. It is strange because this problem with ptscotchDecomp did not exist one month ago. I saw that you had already reported it. Please let us know if you find the solution. Best, M. Ariana |
June 18, 2016, 17:28 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers:
Read Henry's comments here: http://bugs.openfoam.org/view.php?id=2098 |
[OpenFOAM.org] Is it necessary compile ThirdParty? | gu1 | OpenFOAM Installation | 1 | May 27, 2017 07:37 |
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) | Milan2013 | OpenFOAM Installation | 23 | April 20, 2017 06:49 |
[OpenFOAM.org] ThirdParty packet download script for OpenFOAM 3.0.x and dev | zordiack | OpenFOAM Installation | 1 | January 26, 2016 09:52 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors | dreamilam | OpenFOAM Installation | 7 | April 21, 2013 06:43 |
