[OpenFOAM.org] Problems installing OpenFOAM 2.4.0 on Fedora 23 |
May 6, 2016, 08:23 |
Terry L. Coons
Rep Power: 10 |
[tlcoons@localhost ~]$ cd $WM_PROJECT_DIR [tlcoons@localhost OpenFOAM-2.4.0]$ ./Allwmake > make2.log 2>&1 [tlcoons@localhost OpenFOAM-2.4.0]$ icofoam --help bash: icofoam: command not found... [tlcoons@localhost OpenFOAM-2.4.0]$ I'm not sure what to look for concerning icofoam command? Thanks for your help. Last edited by wyldckat; May 8, 2016 at 14:51. Reason: Added [CODE][/CODE] markers |
May 7, 2016, 01:36 |
Terry L. Coons
Rep Power: 10 |
I started getting errors when autoRefineMesh was being compiled.
-lautoMesh -lbarotropicCompressibilityModel -lsolidThermo -lfluidThermophysicalModels -lblockMesh -lchemistryModel -lcoalCombustion -lcompressibleLESModels -lcompressibleRASModels -lcompressibleTurbulenceModel -lconversion -ldecompositionMethods -ldistributed -ldistributionModels -ldsmc -ldynamicFvMesh -ldynamicMesh -ledgeMesh -lengine -lfieldFunctionObjects -lfileFormats -lfiniteVolume -lfoamCalcFunctions -lforces -lfvMotionSolvers -lgenericPatchFields -lincompressibleLESModels -lincompressibleRASModels -lincompressibleTransportModels -lincompressibleTurbulenceModel -linterfaceProperties -lIOFunctionObjects -ljobControl -llagrangian -llagrangianIntermediate -llaminarFlameSpeedModels -lLESdeltas -lLESfilters -lliquidMixtureProperties -lliquidProperties -lmeshTools -lmolecularMeasurements -lmolecule -lODE -lOpenFOAM -lpotential -lradiationModels -lrandomProcesses -lreactionThermophysicalModels -lreconstruct -lsampling -lSLGThermo -lsolidMixtureProperties -lsolidParticle -lsolidProperties -lspecie -lsurfaceFilmModels -lsurfMesh -lsystemCall -lthermophysicalFunctions -ltopoChangerFvMesh -ltriSurface -ltwoPhaseProperties -lutilityFunctionObjects -lOpenFOAM -ldl -lm -o /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/foamDebugSwitches /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/lib/libtriSurface.so: undefined reference to `yyFlexLexer::yywrap()' collect2: error: ld returned 1 exit status /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/autoRefineMesh' failed @ 311,1 12% /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/lib/libtriSurface.so: undefined reference to `yyFlexLexer::yywrap()' collect2: error: ld returned 1 exit status /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/autoRefineMesh' failed make[3]: *** [/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/autoRefineMesh] Error 1 /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/wmake/MakefileApps:39: recipe for target 'autoRefineMesh' failed make[2]: *** [autoRefineMesh] Error 2 g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/src/dynamicMesh/lnInclude -I/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/collapseEdges.o -L/home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/lib \ -ldynamicMesh -lmeshTools -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/collapseEdges /home/tlcoons/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/lib/libreactionThermophysicalModels.so: undefined reference to `yyFlexLexer::yywrap()' collect2: error: ld returned 1 exit status @ 315,1 13% Last edited by wyldckat; May 8, 2016 at 14:51. Reason: Added [CODE][/CODE] markers |
May 8, 2016, 14:56 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Sorry, I didn't know that Fedora 23 had upgraded their Flex version. I've updated the instructions here: https://openfoamwiki.net/index.php/I...dora#Fedora_23
To fix the problem you're having, please run the following commands: Code:
#Go into OpenFOAM's main source folder cd $WM_PROJECT_DIR #Change how the flex version is checked find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_VERSION < 6 \&\& \1=' Code:
#Go into OpenFOAM's main source folder cd $WM_PROJECT_DIR # This next command will take a while... somewhere between 30 minutes to 3-6 hours. ./Allwmake > log.make 2>&1 #Run it a second time for getting a summary of the installation ./Allwmake > log.make 2>&1 |
May 12, 2016, 11:19 |
Dan Kokron
Rep Power: 14 |
Thank you Bruno! Seems a recent update to my F22 system installed to offending flex version. This post got me going again.
October 18, 2017, 10:27 |
Agustín Villa
Rep Power: 15 |
Hello
I have tried the same with OpenFOAM 2.3.X in Fedora 26 and it works |
installation issue |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 | arieljeds | OpenFOAM Installation | 6 | August 19, 2015 08:39 |
[OpenFOAM.org] Installing OpenFOAM 2.3.0 on Mac - problems with db48 | Silvester | OpenFOAM Installation | 6 | August 17, 2015 05:01 |
Problems installing OpenFOAM 1.6-ext on Ubuntu 12.04 | arashfluid | OpenFOAM Installation | 3 | July 21, 2013 07:36 |
Problem on Installing OpenFOAM 1.6 on Fedora 11 | lzgwhy | OpenFOAM Installation | 1 | August 25, 2009 12:02 |
