[Other] CentOS 6.7 - Paraview - X Error: BadDrawable
Like Tree1Likes
  • 1 Post By Vyssion
Old   April 26, 2016, 12:19
Question CentOS 6.7 - Paraview - X Error: BadDrawable
Vyssion's Avatar
Vyssion
Vyssion is on a distinguished road
Hi all,
I have been setting up OpenFOAM within a CentOS 6.7 linux system within an Oracle VirtualBox Machine and have hit a bit of a problem...
I have managed (through many hours or troubleshooting) to get OpenFOAM's processes which I use to execute correctly, however, Paraview 4.4 will not even open up a complete blank new file.
Whether I type "paraFoam" within the terminal window within the simulation directory or whether I simply open up a brand new terminal on the desktop and type "paraview", the error is the same.
(Please note that I do type "of30x" in the terminal window before I run these commands as per instructions - though this is annoying and it would be great to find a way to shell script this part or remove the need for it).
Here is the error which I receive:
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
  Major opcode: 62 (X_CopyArea)
  Resource id:  0x0
After this, I Ctrl+C to kill the process, else nothing happens.
I have tried disabling the CUDA aspect of paraview, then recompiling it, I have double and triple checked that I have all the necessary libraries, I have gone through every single forum thread that I can find to try and fix this issue, but to no avail.
I have a fully functioning Ubuntu setup already (work requires CentOS build hence the need to swap over) which has OpenFOAM and Paraview files within the /opt/ directory - however, on the CentOS machine, there are no such folders/files... Everything as far as I can tell is within the /home/<username>/OpenFOAM/ directory under ThirdParty-3.0.x or OpenFOAM-3.0.x with my own <username>-3.0.x directory containing the /run/tutorials/ . Although weird, I was copy-pasting the installation procedure from the CentOS 6.7 Installation Wiki Page and there isn't mention from what I can tell of this being an issue...
My initial thoughts were that there was some graphical error which was present between the Windows 7 native OS and the CentOS 6.7 VirtualBox VM... I had had my machine converted to a different field build since last running the Ubuntu system and figured there may be some issue there, So I installed the Windows version of Paraview, which executes and opens up just fine...
Anyhow, I am at a complete loss as to what to do. I am relatively new to Linux and so most of the time I am flying blind, so if anyone has anything they can help with, could you please be specific of exactly what I need to type etc etc... that would be a great help!!
Optimism, pessimism, f*ck that: We're going make it happen. As God is my bloody witness, I'm hell-bent on making it work.
- Elon Musk in 2008, after three unsuccessful Falcon launches.
Vyssion is offline   Reply With Quote
Old   April 28, 2016, 06:10
Talking [solved]
Vyssion's Avatar
Vyssion
Hi guys,
I figured out what the issue was. I needed to have VirtualGL installed within the CentOS 6.7 system.
I installed it, and then created an alias "pv" within .bashrc which will load the following line of code:
alias pv="/opt/VirtualGL/bin/vglrun -s paraview &"
Now, in order for me to execute my automation scripts with paraFoam as the process to execute, followed by an argument which is a .py script, I needed to replace the normal:
runApplication paraFoam --script=./<script_name>.py
with this:
/opt/VirtualGL/bin/vglrun -s paraFoam --script=./<script_name>.py
Hope this helps!! It would be good if the CentOS 6.7 OpenFOAM wiki actually mentioned this as a potential troubleshoot, rather than just stating that "... something went wrong..." and offering no links, help, suggestions, or anything.
Good luck!!
wyldckat likes this.
Old   May 1, 2016, 18:55
Retired Super Moderator
Bruno Santos
Quick answer: Many thanks for sharing your finding and solution! It's actually the first time I've seen someone rely on VirtualGL to solve an issue within a VM!
I've had on my to-do list the need to have a FAQ on issues when using ParaView and the wiki page section for it did get started: http://openfoamwiki.net/index.php/Installation/ParaView - and I do have a collection of posts on this topic on a blog post of mine: Related issues to ParaView with OpenFOAM - Fixes and solutions
Problem is that I haven't managed to get to that point in the to-do list... please do feel free to step in and help with this in the wiki, given that the wiki is built by contributors in the community.
baddrawable, centos, paraview, x error
[OpenFOAM.org] Paraview install failing (With OpenFOAM 3.0.0 and CentOS 7) davidrobinson50 OpenFOAM Installation 1 June 2, 2016 18:54
[OpenFOAM.org] Can't seem to compile ParaView 4.1.0 (OpenFOAM 2.4.x, CentOS 7) me3840 OpenFOAM Installation 2 October 13, 2015 01:05
[OpenFOAM.org] Trouble when use ParaView binary on CentOS y_jiang OpenFOAM Installation 1 January 17, 2015 12:17
Error building ParaVIEW 3.12.0 in CentOS 6.5 wjm OpenFOAM Installation 8 February 17, 2014 11:17
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
