[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster
Like Tree1Likes
  • 1 Post By hello177
Old   April 24, 2016, 08:16
Default Installing OpenFoam 3.0.1 on cluster
Alpha
hello177 is on a distinguished road
I'm trying to install OpenFoam 3.0.1 on a scientific linux cluster.
I've compiled the Third party section (except for paraview). I'm using the openmpi in this folder and had to compile gcc-5.3.0 because the version on the cluster was too old.
Running the following gives
#ldd /home/ashep/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64Gcc51DPInt32Opt/lib/libOpenFOAM.so
    linux-vdso.so.1 =>  (0x00007ffff7ffe000)
    libPstream.so => not found
    libz.so.1 => /lib64/libz.so.1 (0x00007ffff73fc000)
    libstdc++.so.6 => /home/ashep/OpenFOAM/ThirdParty-3.0.1/platforms/linux64/gcc-5.3.0/lib64/libstdc++.so.6 (0x00007ffff706e000)
    libm.so.6 => /lib64/libm.so.6 (0x00007ffff6dea000)
    libgcc_s.so.1 => /home/ashep/OpenFOAM/ThirdParty-3.0.1/platforms/linux64/gcc-5.3.0/lib64/libgcc_s.so.1 (0x00007ffff6bd3000)
    libc.so.6 => /lib64/libc.so.6 (0x00007ffff6832000)
    /lib64/ld-linux-x86-64.so.2 (0x0000003685600000)
Also, oddly enough, if I run foamInstallationTest, it errors out saying I have conflicting installations, although I only have one?
Checking basic setup...
Shell:              bash
Host:               secluster
OS:                 Linux version 2.6.32-220.2.1.el6.x86_64
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/ashep/OpenFOAM                     yes       yes
$WM_PROJECT_USER_DIR /home/ashep/OpenFOAM/ashep-3.0.1         no        no
$WM_THIRD_PARTY_DIR  /home/ashep/OpenFOAM/ThirdParty-3.0.1    yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/ashep/OpenFOAM/OpenFOAM-3.0.1      yes  yes  yes
$FOAM_APPBIN         ...1/platforms/linux64GccDPInt32Opt/bin  no        yes
$FOAM_SITE_APPBIN    ...1/platforms/linux64GccDPInt32Opt/bin  no        no
$FOAM_USER_APPBIN    ...1/platforms/linux64GccDPInt32Opt/bin  no        no
$WM_DIR              .../ashep/OpenFOAM/OpenFOAM-3.0.1/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...1/platforms/linux64GccDPInt32Opt/lib  no        yes
$FOAM_SITE_LIBBIN    ...1/platforms/linux64GccDPInt32Opt/lib  no        no
$FOAM_USER_LIBBIN    ...1/platforms/linux64GccDPInt32Opt/lib  no        no
$MPI_ARCH_PATH       .../platforms/linux64Gcc/openmpi-1.10.0  yes   no  yes
Third party software
Software Version   Location
flex     2.5.35    /usr/bin/flex
gcc      5.3.0     /home/ashep/OpenFOAM/ThirdParty-3.0.1/gcc-5.3.0/bin/gcc
g++      5.3.0     /home/ashep/OpenFOAM/ThirdParty-3.0.1/gcc-5.3.0/bin/g++
gzip     1.3.12    /bin/gzip
tar      1.23      /bin/tar
icoFoam
WARNING:  Conflicting installations:
          OpenFOAM settings        : /home/ashep/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Opt/bin/icoFoam
          current path             :
          CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for troubleshooting.
Done
hello177 is offline   Reply With Quote
Old   April 24, 2016, 09:35
Alpha
Ok, turns out I'd forgotten to change bashrc to not use the system compiler
Seems to have compiled fine now.
wyldckat likes this.
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! omid20110 OpenFOAM Installation 6 August 1, 2016 12:20
[OpenFOAM.org] OpenFOAM Cluster Setup for Beginners Ruli OpenFOAM Installation 7 July 22, 2016 05:14
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
