[OpenFOAM.com] Error build a custom version of Qt 4.6.4 on ubuntu 12.04 |
adhi makayasa
Rep Power: 11 ![]() |
Hi Foamers
after trying several times to compile qt 4.6.4 from https://openfoamwiki.net/index.php/I...M-1.7.1/Ubuntu I still get an error message like on the attachment Iam using QMake version 2.01a Qt version 4.8.1 in /usr/lib/i386-linux-gnu How do i fix it? Thanks for your help |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: Can you please try installing the packages listed here: http://doc.qt.io/qt-4.8/requirements-x11.html
Namely by running this command: Code:
sudo apt-get install libfontconfig1-dev libfreetype6-dev libx11-dev libxcursor-dev libxext-dev libxfixes-dev libxft-dev libxi-dev libxrandr-dev libxrender-dev
adhi makayasa
Bruno thanks for your help. Now qt 4.6.4 already installed. But after continuing the next step to the last , I can not run OpenFOAM and also paraview.
Take a look at the attachment. |
Bruno Santos
Greetings Makayasa,
Sorry, back when I wrote the instructions on the wiki, I failed to notice an important step. I've fixed the issue on the wiki page, but please do the following steps to solve the problem on your side:
edit: Please try running the following command, for installing Mesa's libGLU development package, which should provide at least the basis for the OpenGL drivers: Code:
sudo apt-get install libglu1-mesa-dev Code:
cd $WM_THIRD_PARTY_DIR ./makeParaView -qmake ${WM_THIRD_PARTY_DIR}/platforms/$WM_ARCH$WM_COMPILER/qt-4.6.4/bin/qmake > mkPV.log 2>&1 Best regards, Bruno
adhi makayasa
Bruno, thank you very much. Now I can run openFOAM and paraview . I am attaching a result of the installation process , please check if there is an error. Happy foaming
[foam-extend.org] error installing foam extend 1.6 in ubuntu 12.04 | christos | OpenFOAM Installation | 1 | May 9, 2016 17:20 |
paraview not working after installing OpenFOAM in Ubuntu 12.04 | Jackie Chen | OpenFOAM Installation | 5 | October 9, 2014 06:28 |
Problems installing OpenFOAM 1.6-ext on Ubuntu 12.04 | arashfluid | OpenFOAM Installation | 3 | July 21, 2013 06:36 |
OpenFOAM-1.6 install cookbook | MadsR | OpenFOAM Installation | 372 | November 20, 2010 11:57 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
