[OpenFOAM.org] OpenFoam 2.4 for Windows
Like Tree1Likes
  • 1 Post By pgh
Old   October 24, 2015, 12:27
Default OpenFoam 2.4 for Windows
Corné Moerbeek
corne_mo is on a distinguished road
Dear,
I have once tried OpenFoam on Ubuntu, but I now tried to install the official openfoam 2.4 for windows from openfoam.com.
After installation I followed the procedures to run OF_Create_Env and OpenFOAM_Start.
But after that I got lost. First of all I don't understand the instructions regarding the working directory and working directory naming.
Secondly I can't find the OpenFOAM examples/tutorials directory.
Last one is that after "exit" the VM and restarting OpenFOAM_Start, I first get an error that some key can not be opened. Then it takes longer to start the real openFOAM compared to the first time, after which I get bash: mpicc: command not found.
Now I have uninstalled everything, but still wanting to get it to work.
Any help with all of the above will be appreciated.
Thanks in advance.
corne_mo is offline   Reply With Quote
Old   October 24, 2015, 12:43
Retired Super Moderator
Bruno Santos
Quick answer: Unfortunately I haven't figured out yet how to make their installer work properly I have a somewhat unconventional Windows installation either way, so I haven't been able to figure out where the conflict was.
If no one else answers in the meantime, I strongly advise you to send an email to the address given on the first post of the first announcement: http://www.cfd-online.com/Forums/ope...m-windows.html
Old   November 1, 2015, 12:31
pgh
Pawan Ghildiyal
pgh is on a distinguished road
1 The OpenFOAM installation is under the following location and tutorial can be find
under this location /opt/OpenFOAM . Type command cd /opt/OpenFOAM
However to run tutorial , you need to copy them to workingDir and then run it
2. WorkingDir is the folder which will be seen from bash shell environment of OpenFOAM
. If you go inside the workingDir and do ls . you will see files in your windows computer
which are under C:\Users\UserName i.e C:\Users\alex . If you do not have any folder with name username as such alex in example , you need to create one with username and
then again click on Create_Env shortcut and then click on Start_Env.
3. mpicc command not found: do not worry about it if you just want to run OpenFOAM and need not to rebuild it
lavrov likes this.
pgh is offline   Reply With Quote
Old   November 6, 2015, 11:09
Alexander Lavrov
lavrov is on a distinguished road
Dear pgh,
Did you run any tutorial in your OpenFOAM for Windows instrument?
Thank you
Lavrov
lavrov is offline   Reply With Quote
Old   November 9, 2015, 06:15
pgh
Pawan Ghildiyal
Dear Lavrov
Yes, I have run tutorial. The only thing is that tutorial are in root area so you cannot run it there until you have root access , so you need to copy them to workingDir and then start working on it
Thanks
Pawan
Old   November 9, 2015, 07:01
Alexander Lavrov
Thank you. Lavrov
Old   December 23, 2015, 00:17
ghost
karmehak is on a distinguished road
Same problem here but after i opened the open foam other than env it shows that boot docker is not responding and it get closed pls help me
karmehak is offline   Reply With Quote
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
