[OpenFOAM.org] Problem with installation openfoam240 on ubuntu 14.04.03 |
October 15, 2015, 17:15 |
Lorenzo
Rep Power: 11 |
Hello, I reported errors during the installation procedure suggested by the official site. Just after typing :sudo apt-get upgrade .
I quote the error: W: Impossibile recuperare cdrom://Ubuntu 14.04.3 LTS _Trusty Tahr_ - Beta amd64 (20150805)/dists/trusty/restricted/binary-amd64/Packages Usare apt-cdrom per far riconoscere questo CD-ROM da APT. apt-get update non puņ essere usato per aggiungere nuovi CD-ROM W: Impossibile recuperare cdrom://Ubuntu 14.04.3 LTS _Trusty Tahr_ - Beta amd64 (20150805)/dists/trusty/main/binary-i386/Packages Usare apt-cdrom per far riconoscere questo CD-ROM da APT. apt-get update non puņ essere usato per aggiungere nuovi CD-ROM W: Impossibile recuperare cdrom://Ubuntu 14.04.3 LTS _Trusty Tahr_ - Beta amd64 (20150805)/dists/trusty/restricted/binary-i386/Packages Usare apt-cdrom per far riconoscere questo CD-ROM da APT. apt-get update non puņ essere usato per aggiungere nuovi CD-ROM E: Impossibile scaricare alcuni file di indice: saranno ignorati o verranno usati quelli vecchi. The language is italian unfortunately. How can I sort this out and go on installing ? I have followed the procedure in Ubuntu Deb Pack Installation on openfoam's official site( step 2). |
October 17, 2015, 12:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: You need to disable the cd-rom as an option for installing deb packages. Try following one of the sets of instructions given here: http://askubuntu.com/questions/42441...s-when-install
October 18, 2015, 11:58 |
Lorenzo
Rep Power: 11 |
Ok thank you. Is this equivalent to go on the installation procedure ignoring the warnings? In any case if I exclude the cd rom for deb packages installation I should eventually get to same results but for the appearance of the warning messages. Is this right?
October 18, 2015, 12:23 |
Bruno Santos
Rep Power: 128 |
Quick answer: If apt-get simply ended without doing anything else, than this wasn't a warning, it was a fatal error. Therefore it's necessary to disable the cd-rom entry from the apt-get list, so that it can run without this fatal error occurring ever again.
Either that, or put back in the CD-ROM or ISO used in the cd-rom drive . |
October 18, 2015, 17:00 |
Lorenzo
Rep Power: 11 |
Then I'll try on this way , thank you again !
October 20, 2015, 11:08 |
Shahabeddin
Rep Power: 11 |
Hi, I have almost the same problem with this version of Ubuntu and OpenFoam. when I follow the official website’s instruction I will face with error bellow:
----------------------- Err http://www.openfoam.org/download/ubuntu/ trusty/main openfoam240 i386 0-1 503 Service Unavailable E: Failed to fetch http://www.openfoam.org/download/ubu...0_0-1_i386.deb 503 Service Unavailable E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? ----------------------- I completely checked my network connection and there is no problem with that. Do you have any idea to solve my problem? Last edited by lllshahablll; October 20, 2015 at 11:09. Reason: missspeled |
October 22, 2015, 02:42 |
Lorenzo
Rep Power: 11 |
probably it depends on the fact that you installed ubuntu from a iso on a cdrom just like me. Did you try to follow wyldckat instructions? (The guy who replied first my post)
October 22, 2015, 16:51 |
#8 | |
Bruno Santos
Rep Power: 128 |
Quick answer:
October 28, 2015, 07:06 |
#9 | |
Shahabeddin
Rep Power: 11 |
Finally i found a new mirror for my software and the open foam is now installed. here is the link for the mirror: OpenFOAM 2.4.0 |
[foam-extend.org] foam-extend 3.2 Paraview installation problem on Ubuntu 18.04 | ordinary | OpenFOAM Installation | 3 | September 1, 2018 23:01 |
[OpenFOAM.org] OpenFOAM 2.3.0 Installation Problem on CentOS 6.6 | shenzhou1987 | OpenFOAM Installation | 1 | December 14, 2014 14:34 |
[Other] Problem in Open foam installation in ubuntu 14.04 | zannatul | OpenFOAM Installation | 2 | November 3, 2014 21:56 |
Installation problem - calling blockMesh - libblockMesh.so | aylalisa | OpenFOAM Installation | 5 | November 28, 2012 10:55 |
Installation problem on Ubuntu | gara1988 | OpenFOAM Installation | 1 | October 15, 2012 11:00 |
