[OpenFOAM.org] OpenFOAM 2.4 in Linux Mint 17.2: compiling ParaView with python-support
Like Tree2Likes
  • 2 Post By wyldckat
Old   September 3, 2015, 03:15
Default OpenFOAM 2.4 in Linux Mint 17.2: compiling ParaView with python-support
sean read
seanread is on a distinguished road
Hey Guys,
Okay, maybe I'm just a little thick, but I can't seem to be able to get paraview to compile with python support.
I go in to the makeParaView make file in my third party directory of openFoam, change with python to true, added various places that seemed correct for the library, for example /usr/lib/python2.7/, and when I run the make file I get back
No python headers found in /usr/include/python/usr/lib/python2.7/
Please install python headers or deactivate
python support by not using the -python option
Now I don't know if I have chosen the correct folder for python lib, I definitely can't see a python2.7.lib file in there, which suggests it's probably wrong (how, by the way, do I find this path?) However the path in the error message seems to be showing /usr/include/the path I wrote, which seems strange to me,
Can someone help me with this?
seanread is offline   Reply With Quote
Old   September 3, 2015, 18:20
Retired Super Moderator
Bruno Santos
Greetings seanread,
Knowing which Linux Distribution and which OpenFOAM version you're using would make it a lot easier to help you.
Without knowing which one you're using, I can at least suggest you try following the instructions provided here: http://openfoamwiki.net/index.php/In...u#Ubuntu_15.04 - it's for OpenFOAM 2.4.0 and Ubuntu 15.04, which builds ParaView with Python and MPI support.
Best regards,
Bruno
Old   September 4, 2015, 00:03
sean read
Hey Bruno, thanks for getting back to me, I'm using open foam 2.4 and Linux mint 17.2
So I originally compiled the repository version following the instructions here http://www.openfoam.org/download/git.php, and am now trying to recompile with python support, sorry it seems I didn't clearly explain the background to my problem...
Looking at the instructions on the wiki I should be able to compile except that I'm not sure on the python lib path, how do I check this?
Last edited by wyldckat; September 4, 2015 at 19:53. Reason: merged posts that were a few of hours apart
Old   September 4, 2015, 19:57
Bruno Santos
Hi Sean,
Linux Mint 17.2 seems to be derived from Ubuntu 14.04, and since you're using 2.4.x, then the following instructions should be what you're looking for: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
From the instructions, you need to at least do these steps:
  1. Install the Python packages:
    sudo apt-get install python python-dev
  2. Then follow the instructions given in step #9, including all 5 sub-steps.
Best regards,
Bruno
seanread and lukasf like this.
Old   September 6, 2015, 00:44
sean read
Thanks Bruno that worked perfectly, now all is running smooth!
paraview 4.1, python
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
[General] Using Python in Openfoam in-built paraFoam (paraView 3.8.0) Man Yue ParaView 6 November 30, 2012 07:57
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 16:39
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 04:14
