July 24, 2015, 08:57 |
OpenFOAM 2.4.x on CentOS 6.5
Kris
Rep Power: 15 |
Dear Foamers,
as the title suggests I am trying to compile OpenFOAM-2.4.x on CentOS 6.5. So far I have been following these instructions: http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL I manage to compile all the third party compilers etc. just fine but when I get to compiling OpenFOAM I get the following error: Code:
primitives/triad/triad.C:36: error: expected initializer before '<' token primitives/triad/triad.C:39: error: expected initializer before '<' token See: http://www.cfd-online.com/Forums/ope...edhat-el5.html While CentOS 6.5 does come with gcc-4.4.7, I am, however, using gcc-4.8.4 as installed per the instructions on opwnfoamwiki.net. Has anybody else encountered this issue and possibly found some kind of solution? Any help would be greatly appreciated. Kind regards Kris |
July 25, 2015, 09:41 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kris,
Something went wrong while you were following the instructions. My guess is that when you executed this command: Code:
source $HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty \ WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI Code:
source $HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI Code:
echo "alias of24x='module load openmpi-x86_64; source \$HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc Code:
wmSET $FOAM_SETTINGS Code:
echo $FOAM_SETTINGS grep "alias" ~/.bashrc Bruno
July 27, 2015, 07:50 |
Kris
Rep Power: 15 |
Dear Bruno,
first off, thank you very much for your quick response Your first hunch was indeed correct in that I was not sourcing correctly. I am forced to install in an alternative location because my $HOME directory is a network mount and thus very slow compared to my local drives. Looking back I should have just created a symbolic link in ~/OpenFOAM, thus enabling me to follow your instructions exactly, but instead I was sourcing as follows in my .bashrc: Code:
module load openmpi-x86_64 export FOAM_INST_DIR=/data/app/OpenFOAM foamDotFile=$FOAM_INST_DIR/OpenFOAM-2.4.x/etc/bashrc [ -f $foamDotFile ] && . $foamDotFile WM_NCOMPPROCS=6 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI Thanks to your hint I changed the relevant entry in my .bashrc to the following: Code:
module load openmpi-x86_64 export FOAM_INST_DIR=/data/app/OpenFOAM foamDotFile=$FOAM_INST_DIR/OpenFOAM-2.4.x/etc/bashrc [ -f $foamDotFile ] && . $foamDotFile WM_NCOMPPROCS=6 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI Code:
echo $FOAM_SETTINGS WM_NCOMPPROCS=6 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI Thank you very much for your help and for your excellent guidance. Keep up the great work Kris |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 07:15 |
Difference between OpenFOAM on Centos 7 and On Windows 10 (cygwin) | JensGoldberg | OpenFOAM Programming & Development | 0 | November 10, 2016 04:30 |
[OpenFOAM.org] Paraview install failing (With OpenFOAM 3.0.0 and CentOS 7) | davidrobinson50 | OpenFOAM Installation | 1 | June 2, 2016 18:54 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 13:46 |
