June 7, 2015, 09:47 |
ParaView intsllation problem
Srinivasa Rao M
Rep Power: 12 |
I have downloaded OpenFOAM OpenFOAM-2.4.0.tgz and Third-Party ThirdParty-2.4.0.tgz and installed as per the procedure given in Source pack installation on ubuntu 15.04.
I could run the openfoam but couldnt run paraFoam in the cavity problem the error coming is something like this FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake and i did what it said like ./Allwclean and ./Allwmake was done but the same problem repeated Please suggest me what to do inorder to run paraFoam |
June 7, 2015, 19:55 |
Pete Bachant
Rep Power: 14 |
Can you build ParaView okay? I am getting the same error because ParaView will not build:
[ 14%] Building CXX object VTK/Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/vtkXOpenGLRenderWindow.cxx.o In file included from /usr/include/GL/glx.h:333:0, from /home/pete/OpenFOAM/ThirdParty-2.4.x/ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx:31: /usr/include/GL/glxext.h:480:143: error: ‘GLintptr’ has not been declared typedef void ( *PFNGLXCOPYBUFFERSUBDATANVPROC) (Display *dpy, GLXContext readCtx, GLXContext writeCtx, GLenum readTarget, GLenum writeTarget, GLintptr readOffset, GLintptr writeOffset, GLsizeiptr size); |
June 7, 2015, 22:19 |
What is the way out
Srinivasa Rao M
Rep Power: 12 |
So what can be the way out
i just need to use paraview with openfoam |
June 8, 2015, 13:42 |
marko
Rep Power: 12 |
The same problem I am experiencing. Any suggestions on how to solve
June 8, 2015, 13:47 |
Pete Bachant
Rep Power: 14 |
See here for a temporary fix: http://openfoam.org/mantisbt/view.php?id=1734
June 8, 2015, 17:35 |
marko
Rep Power: 12 |
Thank you very much pbachant for the useful link.
Tested it and it works like a charm |
August 25, 2015, 06:27 |
Thx
#7 | |
Johannes
Sorry for digging out this older thread.
Finally I found something that works (after hours of fruitless seach!) I'm using a virtual machine (VirtualBox 5) host: windows 7 (64 bit) guest: debian 8 "Jessie" I was trying to build OpenFOAM-2.4.0 from Source. I followed the official instructions: http://www.openfoam.org/download/source.php. In the Third-Party-2.4.0 folder ./makeParaView4 created the same error message as mentioned above. |
ParaView Execute problem | insta | OpenFOAM Installation | 2 | June 9, 2014 02:37 |
[General] Problem in using paraview | meballav | ParaView | 11 | October 12, 2012 16:03 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
Yet another Paraview problem | gascortado | OpenFOAM | 5 | February 21, 2010 06:39 |
[OpenFOAM] Problem with Colors in ParaView | sven | ParaView | 1 | May 31, 2009 08:13 |
