[foam-extend.org] Error in using paraview in foam-extend 3.1 |
May 31, 2015, 07:25 |
Srinivasa Rao M
Rep Power: 12 |
I have installed openFoam extend so that i can perform FSI simulations
there are some bugs during the installation of paraview can i get some help from you in this regard Errors are when i am trying to open the paraview using the command paraFoam - paraview is opening but it is saying that - A reader for "/home/srinivas/foam/srinivas-3.1/run/cavity/cavity.OpenFOAM" could not be found. Please choose one ... and it is giving all the file formats Tried to fix this by istalling paraview again but didnt work |
May 31, 2015, 16:42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Srinivasa Rao,
A few questions:
Bruno
May 31, 2015, 21:35 |
Thank you for reply
Srinivasa Rao M
Rep Power: 12 |
Replies for what you have asked
1. Linux OS - ubuntu 15.04 2. Installation process is taken from "http://openfoamwiki.net/index.php/Installation/Linux/foam-extend-3.1" 3. I just have followed the instructions... as i am not a regular user of Linux .. am not sure how to alter environment variables. Request you to guide me i wish to say that i have previously installed openFoam 2.4 and its is working fine |
September 5, 2015, 05:43 |
Bruno Santos
Rep Power: 128 |
Hi Srinivasa Rao,
Sorry for the really late reply, but only today did I finally manage to look into this a bit more. Also because I had lost track of this thread on my to-do list The simplest solution is to install Ubuntu's ParaView version: Code:
sudo apt-get install paraview Code:
sed -i -e 's=\.OpenFOAM=.foam=' $WM_PROJECT_DIR/bin/paraFoam Bruno
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
fvSchemes in FOAM extend 3.1 | Shenan | OpenFOAM Running, Solving & CFD | 3 | December 22, 2014 09:45 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
