[OpenFOAM.org] third party installation problem |
March 29, 2015, 05:48 |
a
Rep Power: 12 |
hello
the linux distribution is opensuse 13.1 Openfoam is installed and run properly. but when I try to run the command: ./makeParaView4 this error appears after a while: Code:
gmake[4]: Leaving directory `/home/dc/OpenFOAM/ThirdParty-2.3.1/build/linux64Gcc/ParaView-4.1.0/CoProcessing/Adaptors/NPICAdaptor' gmake[3]: Leaving directory `/home/dc/OpenFOAM/ThirdParty-2.3.1/build/linux64Gcc/ParaView-4.1.0/CoProcessing/Adaptors/NPICAdaptor' [ 77%] Built target NPICAdaptor [ 77%] Built target VTKData [ 77%] Built target vtkEncodeString-launcher [ 77%] Built target QVTKWidgetPlugin [ 77%] Built target vtkParseJava [ 77%] Built target vtkWrapHierarchy [ 77%] Built target vtkWrapJava [ 77%] Built target vtkWrapPython [ 77%] Built target vtkWrapPythonInit [ 77%] Built target vtkWrapTcl [ 77%] Built target vtkWrapTclInit [ 77%] Built target protobuf-lite [ 78%] Built target QtTesting [ 78%] Built target TestingDemo [ 78%] Building CXX object Qt/Widgets/CMakeFiles/pqWidgets.dir/pqHelpWindow.cxx.o /home/dc/OpenFOAM/ThirdParty-2.3.1/ParaView-4.1.0/Qt/Widgets/pqHelpWindow.cxx:56:21: fatal error: QWebPage: No such file or directory # include <QWebPage> ^ compilation terminated. make[2]: *** [Qt/Widgets/CMakeFiles/pqWidgets.dir/pqHelpWindow.cxx.o] Error 1 make[1]: *** [Qt/Widgets/CMakeFiles/pqWidgets.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/home/dc/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 --- Done dc@linux-m93z:~/OpenFOAM/ThirdParty-2.3.1> paraFoam FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake dc@linux-m93z:~/OpenFOAM/ThirdParty-2.3.1> cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers dc@linux-m93z:~/OpenFOAM/OpenFOAM-2.3.1/applications/utilities/postProcessing/graphics/PV4Readers> ./Allwclean + wclean libso vtkPV4Readers wclean vtkPV4Readers + PV4blockMeshReader/Allwclean + rm -f '/home/dc/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libPV4blockMeshReader*' + rm -rf PV4blockMeshReader/Make + wclean libso vtkPV4blockMesh wclean vtkPV4blockMesh + PV4FoamReader/Allwclean + rm -f '/home/dc/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libPV4FoamReader*' + rm -rf PV4FoamReader/Make + wclean libso vtkPV4Foam wclean vtkPV4Foam dc@linux-m93z:~/OpenFOAM/OpenFOAM-2.3.1/applications/utilities/postProcessing/graphics/PV4Readers> ./Allwmake ERROR: ParaView not found in /home/dc/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/ParaView-4.1.0 dc@linux-m93z:~/OpenFOAM/OpenFOAM-2.3.1/applications/utilities/postProcessing/graphics/PV4Readers> ./makeParaView -mesa-lib /usr/lib/i386-linux-gnu/libOSMesa.so -mesa-include /usr/include/GL -no-qt > make.log 2>&1 dc@linux-m93z:~/OpenFOAM/OpenFOAM-2.3.1/applications/utilities/postProcessing/graphics/PV4Readers> cd $WM_THIRD_PARTY_DIR dc@linux-m93z:~/OpenFOAM/ThirdParty-2.3.1> ./makeParaView -mesa-lib /usr/lib/i386-linux-gnu/libOSMesa.so -mesa-include /usr/include/GL -no-qt > make.log 2>&1 dc@linux-m93z:~/OpenFOAM/ThirdParty-2.3.1> thanks |
March 29, 2015, 05:54 |
You should install package containing QWebPage header. I was not able to figure out what distribution you are using, here is the solution: https://www.google.com/search?q=QWebPage+package Last edited by alexeym; March 29, 2015 at 07:22. |
March 29, 2015, 07:05 |
#3 | |
a
Rep Power: 12 |
I did this: Code:
zypper install libqwebview.so Code:
cd $WM_THIRD_PARTY_DIR ./makeParaView4 Code:
[ 76%] Building CXX object Wrapping/ClientServer/CMakeFiles/vtkPVClientServerCoreRenderingCS.dir/vtkOutlineRepresentationClientServer.cxx.o [ 76%] Building CXX object Wrapping/ClientServer/CMakeFiles/vtkPVClientServerCoreRenderingCS.dir/vtkPVBarChartViewClientServer.cxx.o [ 76%] Building CXX object Wrapping/ClientServer/CMakeFiles/vtkPVClientServerCoreRenderingCS.dir/vtkPVCacheKeeperClientServer.cxx.o make[2]: *** No rule to make target `/home/dc/OpenFOAM/ThirdParty-2.3.1/ParaView-4.1.0/VTK/Common/ExecutionModel/s.vtkCompositeDataPipeline.h', needed by `/home/dc/OpenFOAM/ThirdParty-2.3.1/ParaView-4.1.0/VTK/Common/ExecutionModel/vtkCompositeDataPipeline.h'. Stop. make[1]: *** [Wrapping/ClientServer/CMakeFiles/vtkPVClientServerCoreRenderingCS.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/home/dc/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 --- Done dc@linux-m93z:~/OpenFOAM/ThirdParty-2.3.1> |
March 29, 2015, 07:31 |
Somehow missed the name of distribution, sorry. I believe, you need to install libQtWebKit-devel package for QWebPage header. Do not know if zypper was able to resolve the package from library name. |
March 29, 2015, 07:51 |
Also see http://openfoamwiki.net/index.php/In...#openSUSE_12.3 (works for 13.1), it seems you need to install even more packages.
March 29, 2015, 08:29 |
#6 | |
a
Rep Power: 12 |
libQtWebKit solved the problem. zypper was able to resolve the package. it works well for the cavity tutorial. it seems no need to install another package. best regards, ali |
qwebpage, thirdparty |
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) | LThomes | OpenFOAM Community Contributions | 7 | October 6, 2020 13:36 |
[foam-extend.org] foam-extend-4.0 openSUSE Leap 42.1 Installation Problem | icab | OpenFOAM Installation | 5 | April 8, 2017 07:09 |
Problem with installation | florvit | ANSYS | 0 | December 8, 2016 09:10 |
[OpenFOAM.com] Installation Problem | Manyway | OpenFOAM Installation | 2 | July 8, 2016 13:47 |
Installation problem - calling blockMesh - libblockMesh.so | aylalisa | OpenFOAM Installation | 5 | November 28, 2012 09:55 |
