[OpenFOAM.org] Build and install OpenFOAM Dev 64 bits |
February 16, 2015, 10:54 |
eric chin
Rep Power: 12 |
Hi
I downloaded OpenFOAM Dev from 'https://github.com/OpenFOAM/OpenFOAM-dev.git' and try to build 64 bits version of OpenFOAM. I buld gcc 4.8.4, Boost 1.57.0, Binutils 2.25 , mp 5.1.2, mpfr 3.1.2 and mpc 1.0.1 and cmake 2.8.12.1 using instruction from http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL. I set WM_LABEL_SIZE=64 in OpenFOAM/OpenFOAM-devetc/bashrc rather than using prefs.sh. I get the following error when building OpenFOAM-dev 64 bits version: Code:
. . Making dependency list for source file scotchDecomp.C g++ -m64 -Dlinux64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/cfd/apps/openmpi/openmpi-1.6.5/include -pthread -I/include -I/scratch/OpenFOAM/ThirdParty-dev/platforms/linux64Gcc48Int64/scotch_6.0.0/include -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-dev/src/OSspecific/POSIX/lnInclude -fPIC -c scotchDecomp.C -o /scratch/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt64Opt/src/parallel/decompose/scotchDecomp/scotchDecomp.o scotchDecomp.C: In member function 'Foam::label Foam::scotchDecomp::decomposeOneProc(const Foam::fileName&, const Foam::List<long int>&, const Foam::List<long int>&, const scalarField&, Foam::List<long int>&)': scotchDecomp.C:447:9: error: cannot convert 'Foam::UList<long int>::const_iterator {aka const long int*}' to 'const SCOTCH_Num* {aka const int*}' for argument '4' to 'int SCOTCH_graphBuild(SCOTCH_Graph*, SCOTCH_Num, SCOTCH_Num, const SCOTCH_Num*, const SCOTCH_Num*, const SCOTCH_Num*, const SCOTCH_Num*, SCOTCH_Num, const SCOTCH_Num*, const SCOTCH_Num*)' ), ^ scotchDecomp.C:477:79: error: cannot convert 'Foam::UList<long int>::iterator {aka long int*}' to 'const SCOTCH_Num* {aka const int*}' for argument '3' to 'int SCOTCH_archCmpltw(SCOTCH_Arch*, SCOTCH_Num, const SCOTCH_Num*)' SCOTCH_archCmpltw(&archdat, nProcessors_, processorWeights.begin()), ^ scotchDecomp.C:551:9: error: cannot convert 'Foam::UList<long int>::iterator {aka long int*}' to 'SCOTCH_Num* {aka int*}' for argument '4' to 'int SCOTCH_graphMap(SCOTCH_Graph*, const SCOTCH_Arch*, SCOTCH_Strat*, SCOTCH_Num*)' ), ^ make: *** [/scratch/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc48DPInt64Opt/src/parallel/decompose/scotchDecomp/scotchDecomp.o] Error 1 Building the 32 bits version was sucessfull without making changes other than by setting 'WM_LABEL_SIZE=32' in OpenFOAM/OpenFOAM-devetc/bashrc Any idea what might be the problem and is there a patch available to fix OpenFOAM/OpenFOAM-dev/src/parallel/decompose/scotchDecomp/scotchDecomp.C ? Any pointer appreciated. Thank you Eric Last edited by wyldckat; February 16, 2015 at 14:16. Reason: Added [CODE][/CODE] |
February 16, 2015, 14:22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Eric,
Which specific Linux distribution and version are you using? I ask this because I have both 32 and 64 Integer builds (both 64-bit Double Precision) successfully built on Ubuntu 12.04, and I didn't need any modifications to "Scotch" nor "scotchDecomp". In addition, why didn't you guide yourself by the instructions for OpenFOAM 2.3.1? Namely these: http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL Best regards, Bruno
February 16, 2015, 14:59 |
I guess it is a feature of -dev version: Code:
#if WM_LABEL_SIZE == 32 const char* const Foam::pTraits<int64_t>::typeName = "int64"; const char* const Foam::pTraits<int32_t>::typeName = "label"; #elif WM_LABEL_SIZE == 64 const char* const Foam::pTraits<int64_t>::typeName = "label"; const char* const Foam::pTraits<int32_t>::typeName = "int32"; #endif So after setting WM_LABEL_SIZE to 64, label becomes int64_t or long int while SCOTCH_Num rests int. And all List<label> which were passed to Scotch calls as lst.begin() fail to compile. But as it is Git version, guess it will be fixed. |
February 17, 2015, 12:12 |
eric chin
Rep Power: 12 |
Hi Bruno,
Thanks for the reply. I build OpenFOAM-dev on CentOS 6.5 (2.6.32-431.el6.x86_64). I have build OpenFOAM 2.3.1 successfully on CentOS 6.5 and CentOS 7 using the instruction link mentioned. I also did a quick test build with OpenFOAM-dev on CentOS 7.0 (3.10.0-123.13.1.el7.x86_64), I get the same error " scotchDecomp.C:447:9: error: cannot convert 'Foam::UList<long int>::const_iterator {aka const long int*}' to 'const SCOTCH_Num* {aka const int*}' for argument '4' to 'int SCOTCH_graphBuild(SCOTCH_Graph*, SCOTCH_Num, SCOTCH_Num, const SCOTCH_Num*, const SCOTCH_Num*, const SCOTCH_Num*, const SCOTCH_Num*, SCOTCH_Num, const SCOTCH_Num*, const SCOTCH_Num*)' ) Reading through the instruction from http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL, I pretty much do the exact steps apart from using newer boost (1.57.0) and binutils (2.25) packages. Thank you Eric |
February 17, 2015, 17:01 |
Bruno Santos
Rep Power: 128 |
Hi Eric,
Sorry, I completely forgot that this didn't work for me either on Ubuntu. Nonetheless, the feature of "stop on first error" is something new to "OpenFOAM-dev". You can bypass this by running Allwmake like this: Code:
./Allwmake -k Code:
./Allwmake -k -j Best regards, Bruno
February 18, 2015, 10:26 |
eric chin
Rep Power: 12 |
Hi Bruno,
Thanks for the tips. Able to build OpenFOAM-dev 64 bits with the '-k' flag . Thanks for your help Thank you Eric |
February 18, 2015, 16:08 |
Bruno Santos
Rep Power: 128 |
Greetings Eric,
I've finally put "two and two together", based on this bug report: http://www.openfoam.org/mantisbt/view.php?id=1537 - which essentially reports the same issue. My problem was that I used the tarball from "ThirdParty-2.3.1" and completely forgot that the repository "ThirdParty-dev" even existed: https://github.com/OpenFOAM/ThirdParty-dev/ If somehow you did something similar to me, then I suggest you do the following commands: Code:
cd $WM_PROJECT_DIR/.. git clone https://github.com/OpenFOAM/ThirdParty-dev.git ThirdParty-dev_git rsync -a ThirdParty-dev_git/ ThirdParty-dev/ cd ThirdParty-dev/ ls -l $FOAM_EXT_LIBBIN rm -r $FOAM_EXT_LIBBIN ./Allwmake > log.make 2>&1 Note: the rsync command will ensure that everything that is needed is properly copied to the current 3rd party folder. If all went well, then run: Code:
foam ./Allwmake -j > log.make 2>&1 Best regards, Bruno
February 19, 2015, 13:17 |
eric chin
Rep Power: 12 |
Hi Bruno,
Thanks for the pointer and info. I indeed use ThirdParty-2.3.1 tarball rather than "ThirdParty-dev". With your instruction, building "scotchDecomp" was successful. Thanks for your help. Thank you Eric |
June 24, 2016, 04:54 |
#9 | |
Xiaoqiu HE
Rep Power: 10 |
When I tried to compile OF 3.0.x with $WM_LABEL_SIZE of 64bit. I met the same problem. I have followed your way to compile the scotch tool. But I failed, the situation is a little different.: My operation system is Ubuntu 16.04 LTS. In the Third-Party-3.0.x file folder I download scotch 6.0.4 source code and put it in file folder of name "scotch_6.0.3". I did that because I want to use new version of scotch (I can give up this demand). When I run ./Allmake in Third-Party-3.0.x folder, I got the -DINTSIZE64. But when I run ./Allmake in folder OpenFOAM-3.0.x, I failed to getr -DINTSIZE64 Can you help me? Thanks very much! Update~! I have sucessful compile the scotch as I use scotch 6.0.3 source code. It seems that I shouldn't modify the installation steps. Thanks you wyldckat! Last edited by Democritus; June 24, 2016 at 05:00. Reason: Update the situation |
SU2 Parallel Build Install Issue | jclegg | SU2 | 4 | October 20, 2020 05:28 |
[OpenFOAM.org] Trying to build and install OpenFOAM 2.4.0 on Lubuntu 14.04 ARM7 | Hemanth | OpenFOAM Installation | 25 | November 9, 2015 05:43 |
Install openFOAM from with proxy server | Dhruval | OpenFOAM Installation | 3 | October 18, 2014 16:38 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
