[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS |
January 10, 2015, 00:58 |
Mominul MuKuT
Rep Power: 17 |
Dear FOAMers!
Recently I have installed OpenFOAM 2.3.1, earlier I have used version 2.1.1 After installation of openfoam 2.3.1, when I run e terminal following error message displayed in terminal: PHP Code:
when I ran the command: PHP Code:
PHP Code:
PHP Code:
PHP Code:
BR mukut |
January 10, 2015, 16:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings mukut,
A few questions:
Bruno |
January 11, 2015, 02:33 |
Mominul MuKuT
Rep Power: 17 |
Thanks Mr. Bruno!
Ans for 1st Q: I am using these steps to install openFOAM 2.3.1: https://www.youtube.com/watch?v=LkLgwm64jGI ans for 2nd Q: I just deleted openFOAM 2.1.1 folder..... I have informed the youtuber who has given the tutorial regarding my issue: he replied as follows: PHP Code:
PHP Code:
Regards mukut |
January 11, 2015, 03:01 |
Mominul MuKuT
Rep Power: 17 |
Dear Mr. Bruno!
Shall I have to install the OF and then a fresh installation? I am waiting for your reply. I have ran a case, it works fine. After comparing results, I will inform you. Actually what is the effect due to show link cc error??? BR mukut |
January 11, 2015, 03:03 |
Hi
Rep Power: 13 |
Hi Mukut;
You need to see if these files are installed Code:
sudo apt-get install libopenmpi-dev openmpi-bin Code:
ln -s /usr/bin/mpicc.openmpi OpenFOAM-2.3.0/bin/mpicc ln -s /usr/bin/mpirun.openmpi OpenFOAM-2.3.0/bin/mpirun Or you can use prebuild openfoam installtion script that i have posted on forum. Regards; p0kerus |
January 11, 2015, 04:38 |
Mominul MuKuT
Rep Power: 17 |
Dear Mr. p0kerus!
Thanks a lot! After running your 1st command in terminal, the installation completed by download file. Then I run 2nd two commands in the terminal: mukut@mukut-Endeavor-MR3300:~$ ln -s /usr/bin/mpicc.openmpi OpenFOAM-2.3.1/bin/mpicc ln: failed to create symbolic link ‘OpenFOAM-2.3.1/bin/mpicc’: No such file or directory mukut@mukut-Endeavor-MR3300:~$ ln -s /usr/bin/mpicc.openmpi OpenFOAM-2.3.1/bin/mpicc ln: failed to create symbolic link ‘OpenFOAM-2.3.1/bin/mpicc’: No such file or directory mukut@mukut-Endeavor-MR3300:~$ Anyway, after that I have closed the terminal and open again but there is no error as I posted here. Does it really solve? Regards mukut |
January 11, 2015, 13:56 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
FYI: Instructions for compiling OpenFOAM 2.3.1 on Ubuntu 14.04 have been available on the wiki since at least the 31st of December of 2014: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04 - therefore, there is no need to go around trying to manually replace occurrences of "2.3.0" by "2.3.1". @mukut: It seems that you jumped from some other step directly to step #5. Please follow the steps in the correct order (from 1 to 12), in order for them to work as expected. Best regards, Bruno
January 12, 2015, 01:55 |
#8 | |
Mominul MuKuT
Rep Power: 17 |
After p0kerus reply, the show link error didn't show in terminal and I am using openFoam. In this situation, I need your suggestion. Shall I continue to use openFOAM or uninstall it and then use the steps to install that the link you have given in last reply? Regards mukut |
January 18, 2015, 15:55 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi mukut,
If your OpenFOAM installation is now working, then no need to rebuild it again. Feel free to use it as it is. Either way, if you see one or more situations where you think that something might be broken in your installation, then perhaps it's best to remove the current installation and start over. Best regards, Bruno |
January 19, 2015, 01:48 |
#10 | |
Mominul MuKuT
Rep Power: 17 |
Dear Mr. Bruno Thank you so much. OF works fine, thanks again |
cc error, installation issue, openfoam 2.3.x |
[OpenFOAM.org] Problem during installation of openfoam 2.3.0 on ubuntu 16.04 | jarvis | OpenFOAM Installation | 2 | March 20, 2018 09:32 |
[OpenFOAM.org] Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04 | tareqkh | OpenFOAM Installation | 1 | September 2, 2017 11:10 |
[OpenFOAM.org] Ubuntu 14.04 LTS OpenFoam 4.1 Installation Error | behzad-cfd | OpenFOAM Installation | 2 | March 5, 2017 03:44 |
[OpenFOAM.org] OpenFoam 3.0 installation on Ubuntu 14.04.3 | tab2001ng | OpenFOAM Installation | 3 | March 8, 2016 02:38 |
[OpenFOAM.org] OpenFOAM 2.4.x installation script for ubuntu | p0kerus | OpenFOAM Installation | 0 | June 1, 2015 16:52 |
