[OpenFOAM.org] Installing OpenFOAM 2.3.1 on Mint 17 - ThirdParty stuff not seeming to compile
Like Tree1Likes
  • 1 Post By MikeHersee
Old   December 31, 2014, 14:23
Default Installing OpenFOAM 2.3.1 on Mint 17 - ThirdParty stuff not seeming to compile
Mike Hersee
MikeHersee is on a distinguished road
Having got over the problems of Paraview not compiling, the other third party resources does not appear to have completed properly:
In file included from /home/mikehersee/OpenFOAM/ThirdParty-2.3.1/build/linux64Gcc/CGAL-4.3/src/CGAL_Qt4/all_files.cpp:1:0:
/home/mikehersee/OpenFOAM/ThirdParty-2.3.1/CGAL-4.3/src/CGAL_Qt4/DemosMainWindow.cpp:33:21: fatal error: QGLWidget: No such file or directory
#include <QGLWidget>
Any suggestions gratefully appreciated.
Mike Hersee
MikeHersee is offline   Reply With Quote
Old   December 31, 2014, 15:04
Retired Super Moderator
Bruno Santos
Hi Mike,
Fortunately I managed to reproduce the exact same problem
The missing package that needs to be installed is "libqt4-opengl-dev":
sudo apt-get install libqt4-opengl-dev
I've also updated the instructions here: http://openfoamwiki.net/index.php/In...M-2.3.1/Ubuntu
For other forum readers, this issue occurred after fixing the other aforementioned problem, as indicated here: http://www.cfd-online.com/Forums/ope...tml#post525561 post #49
Best regards,
Bruno
Old   January 4, 2015, 06:32
Mike Hersee
That seems to have done it. Thank you Bruno, would never have known how to resolve this on my own. All the make files now seem to indicate successful installation. Am now having a completely different issue trying to get icoFoam to run while Paraview is displayed while doing the first tutorial, but that's a whole other issue...
wyldckat likes this.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster hello177 OpenFOAM Installation 1 April 24, 2016 09:35
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
OpenFOAM Foundation releases OpenFOAMŪ 2.3.1 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 4 February 8, 2015 06:19
