[OpenFOAM.org] what happens for OpenFOAM related codes when upgrading ubuntu |
December 19, 2014, 11:05 |
Bobby
Rep Power: 16 |
Greetings Fellows
I installed OpenFOAM 2.1.x and related codes such as paraview 3.12.0 and flameletFoam and some other codes using cantera on my ubuntu 11.10. Since ubuntu 11.10 is not supported anymore, I have problems in installing new softwares and modules like teamviewer and matplotlib. I want to upgrade my ubuntu to 12.04.5 LTS. However, my concern is the mismatch between the new version of ubuntu and the codes installed in older version of ubuntu (paraview 3.12.0, cantera based look-up table maker, OpenFOAM 2.1.x, .... ). Would some body with experience on this issue hint me that any mismatch would happen or not? Best, Bobi |
December 19, 2014, 14:57 |
davide basso
Rep Power: 14 |
Hi there,
since you are taking the effort to upgrade I'd recommend a clean install of the newest LTS 14.04. then you'll be able to install the newest releases for the needed software too. Don't know about cantera but I can guarantee for Openfoam 2.3.1 and paraview 4.1.0 |
December 21, 2014, 08:43 |
Bobby
Rep Power: 16 |
Greetings Davide
Thanks for your reply, However that was not response to my question. Best, Bobi |
December 30, 2014, 08:58 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Bobi: I vaguely remember already having answered a similar question here on the forum... let's see if I can find it... I didn't even need to Google it, because it's at the bottom of the forum for suggestions of related threads: http://www.cfd-online.com/Forums/ope...tml#post504508 Interesting, with Google I also found this one: http://www.cfd-online.com/Forums/ope...tml#post504512 The interesting detail is that those two answers of mine were posted less than 20 minutes apart! Either way, based on your description and use case scenario, I strongly advise you to rebuild the whole source code of OpenFOAM, along with the custom toolboxes you're using with it. Running the following commands should pretty much clean up your system: Quote:
5. Build everything as you did before.This is mainly because there is usually always at least one very small detail that is different in one of the system libraries when upgrading a Linux Distribution, which might affect your built OpenFOAM, either performance-wise or can lead to problems when compiling new solvers/utilities that link to OpenFOAM, as stated in at least one of the threads above. Best regards, Bruno |
December 31, 2014, 10:40 |
Bobby
Rep Power: 16 |
Dear Bruno
Many thanks for your time and experience. Best Regards Bobi |
Help! Delete the UDM codes in the UDF | Messi | Fluent UDF and Scheme Programming | 2 | January 28, 2014 10:01 |
(not-CFD related) unable to boot Ubuntu and Windows | immortality | Lounge | 9 | April 19, 2013 18:15 |
Is it worth it? | Jason Bardis | Main CFD Forum | 47 | July 27, 2011 05:52 |
if you have some related codes for mixed convectio | yousef elhassadi | Main CFD Forum | 0 | July 6, 2003 18:09 |
Comparison of CFD Codes | Kerem | Main CFD Forum | 9 | May 9, 2003 05:29 |
