[OpenFOAM.org] OF-2.3.1. on Fedora 21 environment not set |
December 17, 2014, 17:45 |
Andrei
Rep Power: 12 |
Hi everyone,
I installed today OpenFOAM from the RPM packages found here: http://rpm.pbone.net/index.php3/stat...86_64.rpm.html I then went through the steps of the installation guide: http://www.openfoam.org/download/source.php at the step of "setting the environment variables", I did as told, the line: source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc is at the end of my $HOME/.bashrc file. Then I typed "source $HOME/.bashrc" in the terminal, although in user mode, but it appeared to execute. Things like echo $FOAM_INST_DIR do work, although I do not know whether it is related or not. However, running any command like blockMesh or simpleFoam won't work: the commands are not recognized, which is the sign that something, somewhere, went wrong. of course, foamInstallationTest fails immediately saying "the environment variables are not configured". Any idea what this may be? I am sorry if this question is very simple, I feel it is, but I did not find it exactly this way in the FAQs, so... Thank you very much for your help! |
December 29, 2014, 21:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Andrei and welcome to the forum!
Don't install that RPM, because it was not specifically designed for Fedora 21. I recently managed to finish writing the installation instructions you're looking for: http://openfoamwiki.net/index.php/In...dora#Fedora_21 Best regards, Bruno
December 30, 2014, 07:11 |
Andrei
Rep Power: 12 |
Hi wyldckat,
thank you very much for this link, that I saved! However, I will have to uninstall this rpm now. I'm completely new to Fedora, and had only Ubuntu for a short time before that. Do you have any advice on how to remove this rpm properly, before installing OpenFOAM the way you suggested? Thank you very much again! |
December 30, 2014, 07:58 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Andrei,
Er, Google? I found this answer: https://ask.fedoraproject.org/en/que...#post-id-14166 Quote:
Best regards, Bruno |
December 30, 2014, 13:49 |
Andrei
Rep Power: 12 |
Hi Bruno,
yes, sorry for the stupid question. A bit new to all that, I should have done this research myself. Still, thank you for telling me, I had to have this software up and running quickly, and have very little time in between a lot of projects. Thank you again, if I find anything that I cannot solve after doing the research, I will come back to you! Happy new year, in advance! :-) Andrei |
environment, fedora, install |
set BC mass-flow-inlet via UDF and via GUI perform different result | sawa25 | FLUENT | 1 | February 25, 2015 01:51 |
OpenFOAM 1.7.1 installation problem on Fedora 14 | armonica | OpenFOAM Installation | 16 | March 31, 2011 14:16 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 05:31 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 20:51 |
Home environment must be set!! | Michael Vredevoort | FLUENT | 1 | April 1, 2002 14:59 |
