OpenFoam 2.3.0 on Ubuntu 14.04
Like Tree1Likes
  • 1 Post By alexeym
Old   October 6, 2014, 01:55
Default OpenFoam 2.3.0 on Ubuntu 14.04
Chris Hagen
CHagen is on a distinguished road
I am new to both ubuntu and openfoam. I followed the instructions found on the open foam website here
http://www.openfoam.org/download/ubuntu.php
The following is what happened up to step 2
step 1
ubuntu@ubuntu:~$ VERS=$(lsb_release -cs)
ubuntu@ubuntu:~$ sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list"
step2
ubuntu@ubuntu:~$
ubuntu@ubuntu:~$ sudo apt-get update
Ign cdrom://Ubuntu 14.04.1 LTS _Trusty Tahr_ - Release amd64 (20140722.2) trusty InRelease
Ign cdrom://Ubuntu 14.04.1 LTS _Trusty Tahr_ - Release amd64 (20140722.2) trusty/main Translation-en_US
Ign cdrom://Ubuntu 14.04.1 LTS _Trusty Tahr_ - Release amd64 (20140722.2) trusty/restricted Translation-en_US
Ign http://security.ubuntu.com trusty-security InRelease
Hit http://security.ubuntu.com trusty-security Release.gpg
Ign http://archive.ubuntu.com trusty InRelease
Hit http://security.ubuntu.com trusty-security/main amd64 Packages
Ign http://archive.ubuntu.com trusty-updates InRelease
Hit http://security.ubuntu.com trusty-security/restricted amd64 Packages
Ign http://www.openfoam.org trusty InRelease
Hit http://security.ubuntu.com trusty-security/universe amd64 Packages
Hit http://archive.ubuntu.com trusty Release.gpg
Hit http://security.ubuntu.com trusty-security/main Translation-en
Ign http://www.openfoam.org trusty Release.gpg
Get:1 http://archive.ubuntu.com trusty-updates Release.gpg [933 B]
Hit http://security.ubuntu.com trusty-security/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/universe Translation-en
Get:2 http://archive.ubuntu.com trusty-updates Release [59.7 kB]
Hit http://archive.ubuntu.com trusty/main amd64 Packages
Hit http://archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://archive.ubuntu.com trusty/universe amd64 Packages
Hit http://archive.ubuntu.com trusty/main Translation-en
Hit http://archive.ubuntu.com trusty/restricted Translation-en
Hit http://archive.ubuntu.com trusty/universe Translation-en
Get:3 http://archive.ubuntu.com trusty-updates/main amd64 Packages [336 kB]
Err http://www.openfoam.org trusty/main amd64 Packages
404 Not Found
Ign http://www.openfoam.org trusty/main Translation-en_US
Get:4 http://archive.ubuntu.com trusty-updates/restricted amd64 Packages [5,820 B]
Get:5 http://archive.ubuntu.com trusty-updates/universe amd64 Packages [208 kB]
Hit http://archive.ubuntu.com trusty-updates/main Translation-en
Hit http://archive.ubuntu.com trusty-updates/restricted Translation-en
Hit http://archive.ubuntu.com trusty-updates/universe Translation-en
Ign http://archive.ubuntu.com trusty/main Translation-en_US
Ign http://archive.ubuntu.com trusty/restricted Translation-en_US
Ign http://archive.ubuntu.com trusty/universe Translation-en_US
Fetched 611 kB in 5s (107 kB/s)
W: Failed to fetch http://www.openfoam.org/download/ubu...amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Being new this all seems pretty cryptic. The "Installation issues" section on the link above doesnt seem to provide an answer as it gives the same result. I was hoping someone could give some direction.
CHagen is offline   Reply With Quote
Old   October 6, 2014, 03:34
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
here's a quote from the site:
OpenFOAM and Paraview are currently available for the following versions of Ubuntu:
12.04 LTS, codename precise
12.10, codename quantal
13.04, codename raring
13.10, codename saucy
so "cryptic"
just means "there's no binary distribution for 14.04". I guess you should go with Source Pack installation (or maybe binary from 13.10 will work, in this case you need to edit /etc/apt/sources.list.d/openfoam.list so it points to 13.10 debs)
alexeym is offline   Reply With Quote
Old   October 6, 2014, 06:59
Y
peteryuan is on a distinguished road
nope, i tried that, using "saucy" in the .list file,
paraviewopenfoam could be installed, and openfoam230 could be found, but it says
openfoam230 : Depends: libboost-thread1.53.0 but it is not installable
               Depends: libopenmpi1.3 but it is not installable
I checked that in synaptic, ubuntu already has the latest version of the two.
so i guess the source build is the best solution.
by the way, isn't the git version better to be played with anyway??
peteryuan is offline   Reply With Quote
Old   October 6, 2014, 08:25
Alexey Matveichev
It depends. If you need to play, use whatever version you'd like, if you need to run simulations that can be reproduced by others in general it is better to use release version.
peteryuan likes this.
Old   October 6, 2014, 10:53
Chris Hagen
I havent installed Ubuntu yet so I could always just get one of the versions listed. No that part wasnt cryptic just over looked. Thanks for pointing that out Ill give it another try today.
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit keepfit OpenFOAM Installation 2 March 26, 2013 10:43
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 05:56
OpenFOAM vs Ubuntu 10.10 64 bit vkrastev OpenFOAM Installation 12 April 23, 2011 11:14
Error in apt-get update for installation of OpenFoam 1.7.1 on Ubuntu 10.10 StuntedChicken OpenFOAM Installation 1 January 9, 2011 11:43
